Question about HP LaserJet 1300 Printer
I can't open the printer case to replace cartridge on hp laserjet
I can't find themaual and can't work out where the release levers are to lift the top so that I can replace the print cartridge.
Hey, I am really at my last wits with this printer.I have a color LJ 3600N. I received the 10.92.00 error. So i replaced the left and right lever lock. After the repair it worked for like half hour.
You replaced the lever locks but did you replace the actual cartridge locks. Chances are either the left or right cartridge lock for the black toner cartridge has broken. Remove the toner cartridge and then lift the transfer belt to the closed position. You should see a lever drop on both left and right side. If the are missing or broken you will need to replace them.
Oct 23, 2016 | HP LaserJet 3600n Printer
HP Laserjet 1020 will not respond - warning light is on (not blinking) and the ready light is off.
Hello, remove the cartridge and check inside the printer, on the left side of the sponge roller about 1 inch/2.5 cm down, there is a lever that engages a flag at the back of the printer ( the sensor in case tells the printer that the cartridge is in the printer) check that lever and make sure it moves freely. If there is a pice of paper behind that lever, when you insert the cartridge the lever will not go all the way.
Jul 29, 2014 | HP LaserJet 1020 Printer
Cartrige lever can't release the cartrige for replacement
when the cartridges are still locked after the front cabinet is released(opened) usually means the cart lock lift cam is broken- common fault on this machine- although the part is not much to buy the availability is what your main problem will be,good luck
Aug 13, 2013 | HP Color LaserJet 2600n Printer
Show paper jam without actual paper jam hp laserjet p2055
1.check the back cover is open and the green levers are down.
2.open the front cover remove the cartridge ,you can see a green lever ,just lift it up and see any paper pieces are there.
Aug 05, 2011 | HP P2055DN LaserJet Monochrome Printer
How to replace the ink cartridge for an HP Laserjet 5 ( C3916A )
Thanks for using Fixya.
Click Here and you will get a pdf document in which all the necessary steps are given to install a cartridge.
Or you can follow the following steps:
1. Turn off the printer and wait for the fan to stop. Unplug the printer and open the top cover by pressing the top cover release button.
2. Open the left-side printer cover and locate the used developer cartridge that you wish to replace.
3. Press the release lever on the used developer cartridge and pull it one-third of the way out.
4. Pull the used developer cartridge out, using a horizontal motion. Take care to support the weight of the cartridge during removal.
5. Shake the new cartridge up and down and side to side so the toner within is evenly distributed.
6.Slide the new developer cartridge into the printer until the release lever locks. Use a horizontal motion and take care to support the cartridge's weight.
7. Close the side cover, then the top cover. Plug the printer in and turn it on. When the printer displays the message "Press On Line To Continue," press the On Line button and wait for the setup sequence to complete.
Aug 04, 2010 | Computers & Internet
Paper is jammed in the printer and cant move it
Remove the cartridge, lift the plate below the cartridge, open the rear door and lift the green lever on the side and release the paper.
make sure the setting in the toolbox is set to
Tray 1: Any size / Any Type
tray 2: A4 size / Plain Type
Rgds,
Nikhil
Dec 12, 2008 | HP LaserJet 1320n Printer
Grinding Sound - Orange Paper Jam Light
You have a broken gear main motor. I had the same problem, bought $5 part and after the replacement of the gear,it runs like new
Dec 04, 2008 | HP LaserJet 4L Printer
DRUM Q3964A FOR HP 2840
10.000x Supply error Description E-label can’t be read or print cartridge is not properly installed. Solution
  1. Reinstall print cartridge.
  2. Power cycle device.
  3. If the problem is not solved, replace the cartridge. NOTE: The software CD-ROM that came with the HP Color LaserJet 2820/2830/2840 all-one includes an animated tutorial that shows how to replace the print cartridges.
    1. Remove any media from the ADF, and then push the scanner-release button to open the scanner assembly.
    2. Open the cartridge door.
    3. Make sure that the correct print-cartridge slot is in the access position.
      • If the correct print-cartridge slot is not in the access position, close the top cover and the scanner assembly, and then press ROTATE CAROUSEL until the correct print-cartridge slot is in the correct position. Pinch together the two large blue tabs on the first cartridge, and then lift the cartridge straight up to remove it from the carousel.
    4. Remove the new print cartridge from its packaging, remove the orange cover from the print cartridge, and then pull the orange tab straight out to remove the sealing tape.
    5. Squeeze the blue release levers on the print cartridge, holding it with the roller facing you. Lower the cartridge straight down into the carousel until it is firmly in place.
      • To replace another cartridge, close the top cover and the scanner assembly, press ROTATE CAROUSEL , and then repeat the previous steps. NOTE: If a black print cartridge was replaced, then the device prompts to have a cleaning page ran, unless the device page count is less than 100 pages.
    6. Close the top cover, and then close the scanner assembly.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=445194&prodTypeId=18972&prodSeriesId=445194&objectID=c00414128
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 05, 2008 | HP LaserJet 2840 All-In-One Printer
Hp 1600 laserjet locking up
It could be the release gear on the bottom right side(as your facing the printer) You can try removing the right cover and re seating it.
Jun 26, 2008 | HP Color LaserJet 2600n Printer
HP Laserjet 1320 Paper feed malfunction
Solution,
 take out the tray
if you look on the bottom of the machine there is a metal plate.
in the middle of the plate there is a bump
turn the tray upside down and look at the bottom, there is a small hole with a plastic lever. it is probably broken.
when the tray is slid into position the lever hits the bump and releases the lifting mechanism.
replace that part or the tray. I can get you a new tray e-mail me at
pakapala@gmail.com
Oct 14, 2007 | HP LaserJet 1320n Printer
HP LaserJet 1300 Printer Logo
23 people viewed this question
Seeker5211
Seeker5211
