Question about Hitachi Televison & Video
HAVE A 51G500A MODEL AND ALL OF SUDDEN IT SHOWED RED LINES AND SHADOWS ITS NOT BEEN MOVED OR TOUCHED I TRIED MAGIC FOCUS ON AUTO AND MANUAL CANNOT FIX IT CAN YOU HELP
    President:
  • 788 Answers
Your symptom sounds like a damaged convergence IC.
There are two and large IC’s that control the convergence in a big screen set. They are secured to a very large aluminum heat sink. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110, and they are located on the signal board (on the left as you look into the back of the set).
Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
There are also two resistors on the front of the board located in the middle that are fusible link resistors, these should be checked for opens and replaced if they are found so.
I would suggest that you contact a service center in your area for a complete diagnosis and repair, as this type of repair can get a little tricky. But if you want to repair the set yourself, just remember to be careful. The capacitors and CRT’s can hold a charge and may shock you.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Posted on Sep 28, 2009
    Top Expert:
  • Hitachi Master
  • 14,553 Answers
The 51G500A uses two convergence chips(IC chips) for convergence output.
Most of these sets use a STK-392-110 AND a STK-392-150----not often you see a set with two different number chips used---the 150 is a higher current device than the 110 chip----You need to replace both(a good idea is to replace both with the 150 chip---they last longer)
You will find them (as you look from the back of the set) on the right side on either one large or two separate metal heat sinks---the chips each have 18 pins and are black in color with the STK number printed in white on the face of them(they are about 2 1/2 inches wide x 1 1/2 inches tall).
Usually just both chips need to be replaced and the set adjusted--sometimes there will be a resistor near them discolored or burnt--you need to look for this if you do this repair---You can buy both the chips on Ebay for less than 15 dollars plus shipping.
If you are not able to do this yourself shop around your area---most shops charge 300-400 for this type of repair----I have done hundreds of them here and charge 200-250 and do the repair in the customer's home----if a shop tells you it has to go to the shop keep looking---any good tech can do this repair in your home in about a hour.
I am here to help people---if you need help or advice or have ANY questions reply to this posting here and I will try to assist you.
REGARDS, SD TECH
I have a 65 inch Hitachi projection TV and all of a sudden lines apperaed on the screen that runs across the upper part of screen. I tried using the"Magic Focus" setting to get rid of these lines...
The tv Magic Focus button don't solved these R,G,B colors lines mis alignments problems.Mean ur tv have a convergence pictures problems,it is dead.Ur tv now have any colors lines like R,G,B mis alignments,have a colors shadows picture or a 3D pictures look alike?Yes,mean ur tv convergence board it is dead to causes all of these pictures problems.The tv convergence board must have to repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
Sep 24, 2011 | Hitachi 65S500 65" HDTV-Ready Rear...
Ghost image in red and alot of red color. This occurs all the time. I have tried magic focus and manuel focus. No change
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?This tv have a dead convergence board.The tv convergence board must require replacing 2 STK convergence ICS and some or all of it resistors too.Fixing the tv convergence board,will solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Feb 09, 2011 | Hitachi 51F500 51" Rear Projection...
Have Hitachi 50 inch Projector TV, model 51F500A. Built 6/2004. Picture has shadows, primarily in red color, on objects or writing. Top 6 inches distorted as well as bottom 2 inches. Tried Magic Focus...
that is come from your convergence panel theres
2 ic call stk - xxxx
youe have to replace it and then remake alignement for your convergence you should have it in the menu adjustement then magic focus will finalized and you can replace the 45 volt regulator transistor
hope that give you a idea//and should not be to expensive if you get an honest
good luck
Mar 22, 2010 | Televison & Video
I have a Hitachi HDTV Model No. 51G500A
Replaced convergence ics. This set is old and if colors especially red are flagging crts are going bad . I would not repair a set this old .
Aug 15, 2009 | Hitachi 51F59 51" HDTV Projection...
Screen prob with Hitachi 51UWX20B red square
Maybe the best way to adjust the screen is with the manual magic focus..instead of letting the tv do the auto change it to manual and see if you can adjust the convergence yourself. I have this same model and once in the manual adjustment you want to make sure you see all white lines....if you seen any blue or red that is the color that needs to be moved towards the white line closest.
Once you think you have it lined up nicely hit "exit" on your remote and option 1....
Hope this helps you.
May 05, 2009 | Hitachi 51UWX20B 51" Rear Projection...
Looks like the picture is in 3D...magic focus won't adjust green
Replace Both of your STK ICs they are Big Black ICs Also CK and replace these resistors RK42 3.3 /RK46 1.8 /RK50 2.7/ RK54 1.5 RK54 1.5/ RK58 3.9 /RK62 2.2
Feb 15, 2009 | Hitachi 57F500 57" Rear Projection...
Red and blue shadows
Did you ever get the solution to this? I'm having the same problem on my 65 incher.
Sep 15, 2008 | Televison & Video
Hitachi 46f500 convergence?
a common problem wich i also have with convergence with blue and red convergence.
the image converge amplifiers are burnet out wich in turn blow out resisters that control individual color convergence.
Jun 19, 2008 | Hitachi 46F500 46" Rear Projection...
Open Questions:
Televison & Video Logo
128 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
