Question about Tilia FoodSaver V2240
How do I turn on my tillia foodsaver my friend lent to me?
    Problem Solver:
  • 3 Answers
Put food in bag. Open lid using latch to right if necessary to release. Put bag in sealer. Close lid. Close latch. Push vaxuum or seal to activate
Posted on Nov 15, 2012
2 Suggested Answers
  • 2976 Answers
SOURCE: Tillia Foodsaver VAC 370 won't stop vaccuming to seal
I had to take mine apart and clean the vacuum line out. It got tiny amounts of liquid in it over time and did the same thing. Before you take it apart, try setting the adjustment screw on the back. It's for altitude but, a slight turn could get you the results you need.
Posted on Feb 18, 2009
How can I get an operating manual for the Tillia Foodsaver compact ii? I have misplaced it ; I'm aware this is an older model.
Do you have a model 550? If so here is the manual.
http://dl.owneriq.net/f/ff986967-66a2-4265-848b-6c97c727f883.pdf
Jun 12, 2011 | Kitchen Appliances - Others
I have a tilia foodsaver mdel # 204029 --don't have a owner manual and can figure out how to pull a vaccuum
The Quick Start Guide for the FoodSaver V420/Mini Plus is available here:
http://www.foodsaver.com/Manuals/MANUALS/FSMiniPlus_V420QuickStart_3_44.pdf
The guide had complete instructions on how to use.
You may wan to to browse the website so you are familar with other available resources:
http://www.foodsaver.com/Support.aspx
Apr 26, 2011 | Tilia FoodSaver VAC420
Can't open my foodsaver for cleaning
I had the same problem and got this information from Foodsaver:
Turn Foodsaver unbit on and press the cabncel button. That should release the unit for cleaning.
It worked for me!
Feb 02, 2010 | Tilia Foodsaver V835 Vacuum Sealer
My Tilia Foodsaver 370 won't turn on. A light
you have to press hard to make it close than it should work
Aug 22, 2009 | Tilia Foodsaver V835 Vacuum Sealer
My Foodsaver 820 wouldn't stop vacuuming, and after fiddling with it and doing a little research, I located the vacuum switch on the circuit board and de-soldered it (verry simple, only 2 solder points). On the underside of the switch it looks kind of like an allen head screw. NOTE before attempting this, make note of how far the screw is recessed into the housing and/or count how may turns it takes to remove it! I removed the screw and spring and sprayed electrical contact cleaner in the holes and in the hole where there is a little brass disc. (Wear safety goggles for this) The little brass disc is what makes the contacts that turn the pump off after reaching the necessary vacuum. Mine was gummed up and stuck so it would never make contact to shut off. I reassembled it, and re-soldered it back on the board. I then put the whole thing back together and it works like new.
You could probably make the same repair without removing the piece from the board since there is a hole in the circuit board where you can gain access to the screw, but it will be messy. If you have any experience with soldering, it is about as simple as it gets
Feb 16, 2009 | Tilia Kitchen Appliances - Others
Find a replacement light bulb for the foodsaver vaccuum sealer
Foodsaver has a toll free number that you might call to see if they can provide the part. 877-777-8042 is what is listed.
Apr 25, 2017 | Tilia FoodSaver V2240
Tilia FoodSaver V2240 Logo
172 people viewed this question
Top Tilia Kitchen Appliances - Others Experts
Lee Eismann
Mike Squire
Bonard Allen
Are you a Tilia Kitchen Appliances - Other Expert? Answer questions, earn points and help others
