I have a very old 13 inch Signature 2000 television. The remote does not have a menu button. It has numbers from 1 to 0, sleep, sleep call, channel, volume, mute, quick review and power buttons. I would like to know how to program the channels with the remote. The buttons on the t.v. only control volume and channels. There is not a menu option.
  • 3,741 Answers
You cannot program without the menu button.this option is required to program the tv.you can get the universal remote for this tv in which there is menu option.it can be easily available.but before getting confirm whether it will work with your tv.
you can get the remote from
www.repairclinic.com
or from
www.bestbuy.com
This will help. Thanks please keep updated.please do rate the solution if helped.thank you for using fixya.
Posted on Sep 28, 2009
My tv is stuck in a closed caption screen
CLOSED CAPTION SELECTION SLEEP 10 To cancel the sleep timer: Press the SLEEP button repeated-ly until "SLEEP 0" is displayed. You may view specially labeled (cc) TV pro-grams, movies, news, prerecorded tapes, etc.with either a dialogue caption or text displayadded to the program.1) Press the MENU button so that the menudisplay appears on the TV screen.2) Press the CH(annel) ▲ or ▼ button to pointto "CAPTION".3) Press the VOL(ume) ▲ or ▼ button to selectthe mode you wish.4) When done, press the MENU button to exit the menu
Then turn OFF.
I also include your user manual below. It's easier to read in there.
www.symphonic.us/pdf/om/ST413C.pdf
Aug 21, 2010 | Symphonic ST413C 13" TV
Power light blinks 13 times
need replaced A-BOARD
Manufacturer Panasonic Part Number TNPH0716ABS Description A- BOARD
After the installation of a new A board, unit has the characters "CHK" on screen. The usual reset procedures of [VOL -] and [MENU] or [OK] or [SLEEP] will not get rid of "CHK".
1. Enter the service mode by holding down the [VOL -] button on the TV (main unit) and simultaneously pressing the [INFO] button on the remote control three times.
2. Press the number [2] key on the remote to highlight [SRV-TOOL].
3. Press the [OK] button on the remote control to select [SRV-TOOL].
4. Use the [DOWN ARROW] on the remote control to scroll down to [PCTC].
5. Use the [RIGHT ARROW] button on the remote to open the box to the right, then press and hold down the [MUTE] button on remote to display Time/Count.
6. Press and hold the [RETURN] button on the remote control until the TV turns off.
7. Immediately press and hold down the [VOL -] button on the TV (main unit) and the [MENU] button on the remote. The TV should come up in the Self Check mode.
8. Remove AC power.
Jul 06, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
JVC 40 inch LCD digital inputs (1 and 2) no longer works. Standard video and component cable inputs work, but not HDMI. Please help
This TV has a sensor that deactivates the inputs when light is sensed. perform this procedure to correct it:
1. press "Sleep" button on the remote
2. while "Sleep timer 0" is showing, simultanuously press "display" and "video" button on the remote
3. you should be in the Service menu of the TV....if not you should do the steps again
4. select "self check" from the displayed options.
5. when the "self check" menu is displayed, Power off the TV.
6. unplug and replug the TV.
7. Check the digital input.
if the input never worked for you, it is possible that you have the DVD/Bluray/whatever set up incorrectly. I don't think this TV accepts 1080P resolution so make sure it is set to 1080i or lower
Jun 23, 2009 | JVC LT-40X776 40 in. LCD HDTV
Gdex-2000 remote control codes and/or user manual
Good morning , I need a remote control code for the Memorex TV Model # MT 1091. I have in my possession a GDEX-2000 remote
Jun 05, 2009 | Quasar VV-1302 13 in. TV/VCR Combo
TV will not come on with remote or power button
The following instructions are for the Emerson EWC1303/1903 tv/vcr. That's the closest match I could find to the Spongebob Squarepants 13' TV
If it's actually in Sleep mode, do the following:
TO CANCEL THE SLEEP TIMER
Press the WAKE UP/SLEEP button on the remote
control until “SLEEP TIMER” appears.
To view the time left for sleep timer press the WAKE
UP/SLEEP button twice, then press the MENU button
on the remote control to exit the sleep timer setting
If unsuccessful, try unplugging the TV for 1/2 hour, then plug it in and try turning it back on either manually or with the remote. Either of these should solve your problem. Best of luck to you!
May 08, 2009 | Emerson SpongeBob SquarePants TV
Sleep Timer on remote does not work
First try to access the sleep timer menu from the controls on the TV to verify the TV is working.
If that works then the remote has the problem.
Now try this;
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
If this does not work, then you may need a new remote unit.
Mar 10, 2009 | Olevia LT37HVS 37 in. LCD HDTV
Durabrand 13 inch tv
the remote need to clean pcb board ..... the chroma section pcb need to resolder loose parts such as resistor, capacitor or transistor that you may see on it.....
Feb 27, 2008 | Durabrand DWT1905 TV
Insignia 42 in plasma tv
cableman try this exactley to the "T" with the instructions in front of you. The procedure resets your monitor to factory settings. On step 13 use the factory setting on the right side menu block not the left. It may or may not work if you have a bad board or eeprom. 1. Using the Volume button (Remote or Monitor) turn the volume all the way down.
2. Hold the Menu button on the Monitor.
3. Press the Menu button on the Remote.
4. Press and hold the Volume button on the remote for 5 seconds and then release the Menu button on the Monitor. After this step the date will appear on the left side of the screen within 10 seconds.
5. Click the Menu button on the remote.
6. Click the Left Arrow button on the remote.
7. By using the Down Arrow button, scroll to Settings and then click the Left Arrow button.
8. Highlight "Eepreset" and click the Left Arrow button. (The monitor will turn off at this time)
9. Push the Power button on the remote, the unit will turn back on.
10. Click the Menu button on the remote.
11. Click the Left Arrow button on the remote.
12. By using the Down Arrow button, scroll to Settings and then click the Left Arrow button.
13. Highlight Factory and click on the Left Arrow button to select "Off"
14. Click Menu on the remote.
15. Click Menu on the remote.
Jan 06, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
