Question about Canon PowerShot A590 IS Digital Camera
My mac won't import my pictures
My mac won't imports my pictures
    Brigadier General:
  • 11,967 Answers
Use a card reader to download your pictures to a folder you create on your desktop.
Posted on Sep 28, 2009
Photo transfer to pc
Transfer Photos from iPhone to MacIn almost all cases, the fastest and simplest way to copy pictures from an iPhone to a Mac is with Image Capture and Preview. We'll discuss how with both apps:
Using Image Capture to Import Photos in OS XThis is a fast and efficient way to pull photos off the iPhone, which treats the device as a digital camera:
  • Open Image Capture from the /Applications/ directory (or through Launchpad)
  • Connect the iPhone to the Mac through USB
  • Select a folder from the menu (default is Pictures folder) and then click "Import All"
  • OR: Select individual photos, and click "Import" to only copy those pictures over
You can also transfer pictures to your Mac with iPhoto or Preview, which is just as simple and actually has a virtually identical interface for initiating the transfer. Here is how to import with Preview:
Copying Photos with PreviewThough Preview is usually thought of as an image viewer, it can also serve as a fast importer:
  • Plug your iPhone into your Mac
  • Launch Preview
  • From the File menu navigate down and select "Import from iPhone..."
  • Select "Import All" to get all the pictures, otherwise individually select pictures and click 'Import'
  • Look in your ~/Pictures/ folder for the photos from your iPhone
Optionally: Click the checkbox with "Delete after import" if you want to delete the photos after they have been copied over to the computer.
The benefit of using either Preview or Image Capture is that these apps are on virtually every version of OS X since from the very beginning of the OS, so you won't find a Mac version without them. iPhoto on the other hand is generally limited to the consumer model Macs, thus making it not always available on pro models, but it does work as well, and iPhoto will also serve as a photo manager of sorts.
Transfer Photos from iPhone to PC (XP)Using Windows Plug & PlayThis utilizes the pop-up that shows by default in Windows when a device is connected to the computer by way of USB.
  • Plugin your iPhone to the computer without iTunes running
  • Wait for a popup asking you what you want to do with the device
  • Select "View Content"
  • Find your photos through the folders that are displayed
  • Copy the images from Windows as usual
Note that in Windows 7 and Windows 8 you will often find the iPhone mounted under "Portable Devices" but it can also be found listed under "Digital Camera". Opening either will work to copy the pictures over, but typically Digital Camera opens directly to the DCIM directory whereas Portable Devices will sometimes require minor navigation within the folder to copy the files.
Using iPhone as Digital Camera in Windows ExplorerIf your iPhone is already plugged into the PC, you can also try this method:
  • Open "My Computer"
  • Find the iPhone, it will appear as any other camera would
  • Open iPhone to find your Photos
  • Select the pictures you want to copy to your computer and copy/paste them into the desired location on your PC
The Windows approach treats the iPhone more like a file system, just like it does with standard digital cameras that are connected to a PC. That generally makes Windows even easier for moving pictures back and forth if you like to cut & paste things directly from one folder to another in My Pictures or My Documents. Nonetheless, you can also use your favorite photo importing application to pull the pictures from the device as well.
Remember, if the iPhone pictures are not showing up in Windows, make sure the iPhone is unlocked first. Otherwise the iPhone will be found in 'My Computer' but all of the content on it will be invisible and inaccessible. If you run into that, all you need to do is touch the iPhone, unlock the screen and enter the passcode, and all of your stuff will be visible as expected.
Finally, you can also sync your photos using just iTunes on either Mac OS or Windows but that is more for iPhone backup purposes and doesn't really serve as a means of accessing individual pictures.
On a Windows PC the easiest way to get pictures from your iPhone is to just use Windows Explorer, but there are two ways to go about this. In either case, unlock the iPhone before beginning, or else the photos may not be visible.
Jul 19, 2013 | Cell Phones
How to put an MP4 onto iMovie?
You can use Pavtube HD Video converter for mac to transcode MP4 video to Apple InterMediate Codec (AIC) for iMovie editing, this method you don't need to render.
Nov 06, 2012 | Video Cameras
I am trying to make WYSISWYG PDFs of Mosaic Music which runs on an OS 9 Mac Tower. I was told that QuarkXpress 4.1 might work, but I am not sure that it will. PrinttoPDF didn't work. I am desperate!...
Did you make a picture box, then use the "get picture" function to import the pdf? The first dialogue box you see should have tabs at the bottom, one of which says "color management" and the other, "PDF Import." Click on the latter and you should be all set.
Sep 09, 2011 | QuarkXPress 4.1 for mac
I m using canon IXUS 130..and i having problem in importing the images to my mac..it says failure to import
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
Mar 30, 2011 | Canon PowerShot SD780 IS / IXUS 100 IS...
All my pictures on camera are gone! How do I "see" the card on my mac computer to find them again?
When you import pictures into iPhoto there is a setting for deleting the imported pictures from the camera. Be sure to uncheck that setting if you want to keep the pictures on the camera after importing them into iPhoto.
To see the pictures (if any) without iPhoto, obtain a SD card reader (as little as $2 on Amazon) and plug the card from your camera into it, and the adapter into a USB port on the camera.
Oct 15, 2009 | Canon PowerShot A710 IS Digital Camera
Jumpy Video in Flip Video Ultra HD
If you recorded a few video clips with the Flip Mino or Flip Ultra , and when you tried to import the video files from flip video camcorder to into iMovie ‘08, only to find out that you couldn’t. Apparently, you’re not alone, because you’ll find there are plenty of other people with the same problem.
Some Flip video camcorder will record video in mp4, but some in mpeg-4 formatted AVI files, the problem is iMovie won’t recognize AVI, you will need to convert AVI to DV Stream before import into iMovie.
Fortunately, there is a simple yet effective way to work this out, check it out: Flip video converter for Mac [/url] is a program specially designed to make Flip Mino and Flip Ultra work well with iMovie, iTunes and QuickTime. It can convert flip video to DV, m4v for iMovie, and convert flip video to QuickTime. mov for QiuickTime. Mac Flip video converter is Mac friendly program, which is compatible with PowerPC and Intel Processor. You can count on it.
How to use Mac Flip Video Converter
Step by step to import flip video to iMovie files on Mac OS X.
Step 1 Download and install flip video converter for Mac
Flip video converter for Mac released its latest version 3.3.8 recently, and there are two folders included in the program, one is for Intel Processor, the other is for PowerPC, please choose wisely.
[img][/img]
Step 2 Import flip video to flip video converter
You will need to convert flip video files to DV or M4v that to be importable by iMovie.
If you have many video clips and want to load them at one time, just go ahead, the batch mode will let you do without any problem.
[img]http://www.iorgsoft.com/how-to-import/Flip-Mino-Flip-Ultra-video-file-video-file-to-iMovie/import.jpg[/img]
Step 3 Select the output format and output path for the video need to convert
In your case, you can select .DV as the output format. On the bottom of the panel, select .dv in the drop down list menu next to Profile…
Select a location in the drop down menu next to Destination.
Click Open…button will let you directly locate where the output file is stored.
Step 4 Convert flip video to iMovie compatible format
Hit Convert…button, this will instruct the program to convert the list of flip video immediately
Please wait patiently till the progress bar says conversion done.
[img]http://www.iorgsoft.com/how-to-import/Flip-Mino-Flip-Ultra-video-file-video-file-to-iMovie/conversion.jpg[/img]
Step 5. Now open up iMovie ‘08, and go to File > Import Movies, browse for them, and import to your heart’s content. That’s it!
[img]http://www.iorgsoft.com/how-to-import/Flip-Mino-Flip-Ultra-video-file-video-file-to-iMovie/import-to-imoive.jpg[/img]
Jul 18, 2009 | Pure Digital Flip Video Ultra Camcorder
We have some videos we want to transfer to the computer. We are running Mac OSX with the Leopard software. When I attach the camera, I see the point and shoot icon for a short time and then I hear a beep...
Put the batteries in the camera, then connect via the USB flip connection. The camera will show up on the desktop like a flash drive does. Open it when it shows up. Drill until you find the avi movies and drag them to your desktop. You may have to convert them to quicktime files. If you cannot use the software that came with the camera (it does work), you can import the sections into iMovie.
Jul 14, 2009 | Pure Digital Flip Video Ultra Camcorder
Can't upload videos to Imovie
Kodak series cameras capture videos in MOV files. iMovie will only import codecs that it can edit. iMovie can import MP4, DV, Apple Intermediate Codec, H.264, Photo JPEG, Motion JPEG, Apple Animation, and perhaps others. MOV is a multimedia container file, not a codec. It can contain any of the above codecs, but it could contain other codecs that are not editable by iMovie, such as MPEG-1 or MPEG-2 so that sometimes iMovie cannot recognize Kodak videos directly.
please try this video converter, good luck. kodak video to imovie
http://www.kodak-video-converter.com/how-to-importedit-kodak-video-into-imovie-on-mac.html
May 04, 2009 | Kodak EasyShare V603 Digital Camera
Canon PowerShot A590 IS Digital Camera Logo
299 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
