Question about Whirlpool LEQ8000JQ Electric Dryer
Dryer heats for about 1 minute then stays cool for rest of time. Any ideas?
  • 22 Answers
Is it possible that the problem you are experiencing may be caused by a worn heating element or the fuse associated with the forementioned component?
Posted on Sep 28, 2009
Heat wont stay on
Replace the 2 gas valve coils, check the link below to have an idea of how they look like.
Maytag Dryer Gas Valve Ignition Solenoid Coil Kit 279834
Jan 14, 2014 | Whirlpool LGB6300 Gas Dryer
Dryer won't stay running, shuts off after a few minutes.
Maybe the timer or wires not hooked up right or motor if u hear like a buzzing sound when u push start it's the motor
Oct 30, 2009 | General Electric DWXR463EGWW Dryer
When I start my dryer, I have heat at first, but it shuts off after a short time for the rest if the cycle.
It sounds like you have a gas dryer . The coils on the burner valve need to be replaced . They get hot from the electricity going thru them , and one opens (shorts ) until the dryer cools down . It should then heat again for a few minuted , then stop heating but still run . Your timer will not advance either , if set on auto , unless dryer heats . Without the model number , cannot give you the part number , so take it with you to get the part . It comes with both coils in a pkg .
Oct 11, 2009 | Whirlpool Dryers
Gas dryer not maintaining heat. 70 Series Kenmore/Whirlpool 76722
Fuse is ok . Problem is the soils on the burner valve . If the dryer heats when started , the electricity goes thru the coils to open the valve . Once the coils get warm , 1 will open (short) until it cools back down . The coils can be replaced just by removing the front panel . Only 2 screws hold the coils in place . No turning off gas , dissasembling dryer .
Jul 14, 2009 | Whirlpool Dryers
Dryer not drying due to lack of heat
Check the following text to address this issue.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
Jun 11, 2009 | Whirlpool GEW9250 Electric Dryer
GE Harmony electric dryer model DPGT750EC1PL- very little heat - small rattle - takes hours to dry load of laundry... any ideas?
Check the following to address this issue.
1. Venting
2. Thermostat
3. Heating element
Jun 06, 2009 | GE Profile Harmony DPGT750EC Electric...
Dryer heats up and then cools off, won't stay hot.
sounds like either the heating element or limit switches are going out on you
Feb 21, 2009 | Kenmore Dryers
Kenmore Electric dryer runs on cool down forever.
Call the mfr and ask them about it. This problem may be pretty complicated. There may be a problem with your board that tells it to go to cool down. Can you set the timer for 45-60 minutes and it stay on heat for that long?
Feb 11, 2009 | Kenmore Dryers
Dryer won't stay hot....
change your coils at the burner.
check the vent for blockage.
Nov 17, 2008 | GE DBXR463GB Gas Dryer
TGDX64OEQ1 Gas Estate Dryer
Sounds like the hi-limit temp switch is sensing too high a temperature and is shutting off the dryer. This is a safety feature and is usually tripped because the outlet air flow is restricted, and resets itself after it has cooled down. Check to see whether the rest of the vent in your house is clogged and clean it. It could also be an inlet fan or blower which introduces air into the drum. If this is not working, there will be no air flow into the dryer, causing excessive heat in the non-moving air in the dryer.
Feb 01, 2008 | Estate TGDX640JQ Gas Dryer
Whirlpool LEQ8000JQ Electric Dryer Logo
67 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
