Question about Home Security
How can I download from a Ecomark dvr-8204sv that records in compressed mjpeg to my computer via flashdrive
3 Suggested Answers
SOURCE: download movies from explorer 8300 hdc dvr to computer to burn
Not gonna happen. SA uses a proprietary file system. The USB is only designed for a keyboard or mouse when in a special diagnostics mode. The best you can do is use an eSata drive to the port on the back. IF you have the Mystro software on the box (most do) it won't even allow you to move programs to the storage drive until the box's drive is mostly full. Even then, I'm not sure that it gives you the option to choose what you want to offload.
You are best off buying a DVD burner (stand alone unit) or output the video to your PC. and re-encoding it to the file you want. Alternately, wait for the Series 4 TiVo with tru2way.
Sorry to be the bearer of bad news.
Posted on Jun 28, 2009
yooperbud
  • 8637 Answers
SOURCE: webcam's color compression format is mjpeg, said to be not compatible with yahoo messenger
Normal 0 See section B. Yahoo Messenger in the info below to setup the Audio & Video.
Also send this to your family and friends so they have their computer setup properly.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/) set it up as follows:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if Installed Properly will come up and show a video picture.
  4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://ca.messenger.yahoo.com/download/ ) set it up as follows:
  1. Click on Messenger at the top left and then go down to Preferences and then the Preference Window will come up.
  2. Next click on Calling and Devices. In the Calling & Devices on the right and set the Microphone and Speakers to the computer Audio Card or sound device installed in the computer.
  3. Just below that, go to the Test Audio section and (in blue writing) click on Open the call setup assistant” and follow the instructions on the left window.
  4. Then after completing the Audio Setup, go to down and click on Webcam.
  5. After make necessary settings, click on APPLY, then on OK and it should be ready to use.
Hope this helps. Bud
Posted on Jun 29, 2009
Why can't I record on my DVR?
Check all your connections and configuration between decoder to DVR and TV. I find it is more practical to use the DMI connectors for this purpose. Between my LG TV, LG DVR, LG Blue Ray Player and Decoder I use 3 DMI connector cables. Ideal for me because my TV has 3 DMI points, I just connect each of 3 items to TV via a DMI cable. Now connect decoder to DVR via video-audio cable (red-white-blue). This setup allows each unit to be used individually (i.e. tv viewing, recording, blue ray playing and when recording live TV the TV can be switched off while recording. Just remember to select the appropriate DMI connected unit on your TV remote (on "input" button).
Feb 16, 2016 | Panasonic Televison & Video
Hello-I have a 19" Philips flatscreen LCD television set model#19PFL3504D/F7. After attempting to upgrade current software via a USB flashdrive I reversed the disconnect instructions. I removed the...
connect a laptop to the set, using the usb port contact phillips on line download the old flash to the computer save the old flash download as a file and, to the usb flashdrive connected to your laptop reload the set either with the laptop or, the flashdrive unplug the set first then: remove the flash drive
Jul 17, 2010 | Philips 19PFL3504DF7 19 in. TV
What do i need to connect my canon zr500 camcorder to my pc?
IF, your camcorder has FIREWIRE, than you can use that, and suitable DVR software. IF not, then I always recommend that, one use a TV/Video "Capture" card or USB "Dongle", either way, you simply connect that up, via, the AV, leads, usually S-VHS, or Composite, Or Component, or Firewire, Use a DVR, and basically, "Play" the "Video" and "Record" on the PC, with Digital Video Recorder, DVR, and save as a "Digital Format" then you can do whatever you wish, after recording. You can get propretory software from the manufacturers website, and download, drivers, and software to do as you wish. I recommend a program called Dscaler, it is the BEST DVR there is.
Apr 28, 2010 | Canon ZR500 Mini DV Digital Camcorder
Record xbox to archos 604
The dvr station must sit in the middle of the signal transfer from the box to the tv, so connect the Xbox to the dvr station and then connect the dvr station to the tv. You will have to enaure that the DVR station is always powered on so that the signal will pass through it. to record simply select the record option on the 604
Apr 09, 2010 | Archos 604 Digital Media Player
How do I transfer recorded programs from my 622 DVR to my home computer?
http://www.dishnetwork.com/downloads/user-guides/receivers/622_UserGuide.pdf
User guide. above.
You would have to connect up, using a PC & DVR software and some form of TV/Video recording Card, or USB device. Then connect up via AV, Composite, Yellow, Video. White & Red Audio. and "Capture" either live video & Audio, so basically whatever was viewed on the screen, would be "Recorded" on the PC, via the TV/Video interface device, if using a laptop, then a USB "Dongle" & software would be the best. In a Desktop, a PCI-I card would be Best, Then using the Software that comes with the devices, you "Record" with that and "Play" with the Dish DVR, and save, the Streamed Video & Audio to the PC. Now, If you have Component Out, on the Dish, then this is the one to use, If you choose this way, remember the Device you are going to use Must have a Component INPUT as well, as A Stereo Audio Input, so ensure the device you get has that feature.
Mar 30, 2010 | DISH Network ViP622 DVR DTV Receiver /...
Trying to put I-DVD movie on my digital photo frame
Re-edit the movies and pictures following the formats below: Video:
File Format: MOV
Video Compression: MPEG-4 ASP, MJPEG
Audio Compression: MP3, G.711, PCM, ADPCM, 8-bit linear
File Format: AVI
File Format: MPG / MPEG
Video Compression: MPEG-1
Audio Compression: MPEG audio Picture:
File Format: JPG / JPEG
Video Compression: Baseline JPEG
Music:
File Format: MP3
Video Compression: PCM, ADPCM, MPEG 1 layer 1,2,3
Apr 02, 2009 | Kodak EasyShare SV811 (8858946) Digital...
How do i get my video to play....i am following the directions in the book....when i hit play...i get nothing....i am frustrated ....could someone let me know the step by step directions to get the video...
Make sure that you have the correct video format and compression. Video:
File Format: MOV
File Format: AVI
Music:
File Format: MP3
You will need to re-edit the video files you have for the frame to recognize it.
Feb 21, 2009 | Kodak EasyShare SV811 (8858946) Digital...
Home Security Logo
165 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
