Question about NetGear WGPS606 (WGPS606NAR) Print Server
Computer can's see Print Server in Add Printer Wizard The WGPS606 installation -- part 1 -- seemed to go fine. It sees our wireless network, we assigned it an IP address, it sees the printer connected to it via a USB cable. When running part 2 of the installation software, to configure the computer for the printer, the print server comes up in the initial list and displays the right IP address, and on the next screen, it sees our printer. But on the next screen, it launches the add printer wizard (Windows Vista) and there the troubles begin. The add printer wizard cannot see the printer. We are assigning the IP address of the print server to a new, local TCPIP port, per the instructions. Tried this on more than one laptop, both running Vista. Next steps?
Make sure the printer has been connected locally first and that the print drivers have been installed. This should then allow you to add the printer via the set up.
Regards gaz
Posted on Oct 15, 2009
Wgps606 sets up printer and is connected to bt homehub but when trying to set up laptop on network the print server is not recognised. Any suggestions?
Hi
You can add your laptop manauly to your network(wgps606)
please let me know operating system so that i can write ,how to fix it
Thanks for using Fixya
prakash
Mar 22, 2010 | NetGear WGPS606 (WGPS606NAR) Print Server
My print server is working with a Epson DX4400. It is all setup correctly (according to Netgear) but when I print wirelessly, it only prints half the test page and then the printer stops with an error...
U need to manually add the Printer ports ..
Install the printer driver to the computer first and make sure that we are able to print directly. Follow the steps below after putting the printer and computer back to your network.
  1. Click on Start, then Control Panel, then Printers and Faxes. Right click on the Printer and select Properties.
  2. On the printer properties window, select Ports tab and click on Add Port.
  3. Select Standard TCP/IP Port and click on New Port
  4. This will bring the Add Standard TCP/IP Printer Port Wizard, click Next
  5. In the field for Printer Name or IP Address, type the IP address of the print server and click Next
  6. Select Custom and click Settings button
  7. Under Protocol field, select LPR. For Queue Name, type P1 depending on what print server port is the printer connected to.
  8. Click Ok, then Next, and Finish.
And this will resolve the issue
Feb 06, 2010 | NetGear WGPS606 (WGPS606NAR) Print Server
Windows 7 and Linksys wireless print server
Step for installing Network print server in windows 7.
Click Windows "Start button"
Select "Devices and Printers"
Click "Add a Printer" button
Select "Add a Network, Wireless or Bluetooth Printer"
Printer wizard will searhc for all network printer including wireless.
Select "The printer that i want is not listed"
Select "Select a shared printer by name"   (Make sure you have shared the printer you want to connect)
Type the IP address of the printer if it ia a printer.
If it is printer that is connected to a PC then type like this below
\192.168.0.50printer shared name where 192.168.0.50 is the IP address of the PC where the printer is connected.
Click Next and if you want to Send a test print you can try that too,otherwise click "Finish".
That's it.
Jan 02, 2010 | Dell Inspiron 1545 Notebook
I cannot conect with the default ip for the WGPS606 netgeat print server!?
Check the IP address of your computer and see if it's on the same range of the IP address of the printer server.
Ex. print server IP: 192.168.1.4
Your computer must have 192.168.1.XXX
Note: X can be any no. from 1 to 254
To assign an IP address on your computer:
Start > Control Panel > Network connection
Go to the properties of the local area connection then click on TCP/IP tab.
You can now assign an IP address on your computer with the same range of the print server.
Jun 27, 2009 | NetGear WGPS606 (WGPS606NAR) Print Server
Netgear ps121 won't print
Possible reason why you cannot print with the print server is because the computer is not getting a valid IP from the router or a firewall is installed in the computer. You have to disable all firewalls installed in the computer.
For the print server setup, please follow the steps below:
Note: Before setting up the print server, make sure that you can print when printer is connected directly to the computer.
1. Wire the print server to router. Check the lights on it. It should have the ACT light on and the Error light off.
2. One way to test if the printer would work with the print server is to reset the print server for 3 to 5 seconds while it is powered on and after you release the button, the printer should automatically print the IP address of the print server.
Note: If the printer did not print, there is a possibility that they are not compatible. However, you may still continue to try to set up the print server.
3. Install the PS121 software.
a. Power on your computer, let the operating system boot up completely, and log in as needed.
b. Insert the Resource CD for the PS121 into your CD-ROM drive. The CD main page shown at the right will load.
c. Click Install Software.
d. Click Next and follow the software installation utility prompts to complete the software installation.
e. When prompted, restart your computer to complete the installation.
f. When your computer restarts, click Finish to run the Print Server Setup Wizard.
4. Run the Print Server Setup Wizard to Set Up a Fixed IP Address for the PS121.
a. The Print Server Setup Wizard screen should be displayed.
b. Click Next to proceed. The Print Server Wizard will now search your network for the PS121. If the Print Server Setup Wizard cannot find your PS121, check the network connections and status lights on the PS121.
c. The “Server Name” and the “IP Address” your network assigned to the PS121 are displayed. Click Next to proceed to the device name screen.
d. You can enter a descriptive Device Name and Domain Name or accept the defaults. Click Next to proceed to the IP Address configuration screen. The Print Server Wizard displays a recommended static IP address setting for the PS121. This is usually fine.
e. Click Next to proceed.
f. Click Finish to exit the Print Server Setup Wizard. This completes the configuration of the PS121 for operation on your network.
g. Click Yes to run the Add Printer Port Wizard. Follow the instructions in the next section for using the this wizard to set up each computer to use the PS121.
To set up each computer to use the PS121, please follow the instructions below:
1. Use the NETGEAR Add Printer Wizard to set up each PC to use the PS121.
a. When the Print Server Setup Wizard finishes, you are prompted to run the Add Printer Port Wizard. Click Yes to proceed. Alternatively, from the Windows Start menu NETGEAR Print Server program group, you can run the NETGEAR Add Printer Wizard.
b. After a short delay while the software searches the network for your PS121, the Printer Select window opens and displays the PS121 you have set up.
c. Click Next to proceed to the Port/Printer name screen. Take note of the printer model number listed.
2. Set up the correct printer driver for the printer port.
a. Click Next to proceed to the Port/Printer name screen. Take note of the printer model number listed.
b. Click Next to proceed to the Select Printer screen. If you see the exact printer model number listed as the printer model number from in the previous screen, click it to select it from the list.
c. If prompted, print a test page to verify operation of the printer and the PS121. Then, close any remaining Add Printer Port Wizard or Windows Add Printer Wizard windows.
Use the NETGEAR PS121 Mini Print Server Resource CD to run the Add Printer Port Wizard to set up each PC on you network that you want to use with the PS121. Select the port you added
You may also use the links below as your guide to troubleshoot the print server:
http://kbserver.netgear.com/kb_web_files/n101269.asp
http://kbserver.netgear.com/kb_web_files/n100033.asp
However, if this does not resolve the issue we will need to get some additional details from you to be able to assist you further. I have summarized my questions below:
1. Model number of router
2. Model of printer
3. Operating system of computer/s
May 01, 2009 | NetGear PS121 Print Server
How do I add a printer to my wireless network?
You would have to install a wireless print server, like a Netgear WGPS606... It has USB ports that you would connect your printer to... You could actually replace your current wireless router with this one or chain one with the other!! Or your other option would be to buy something like a TRENDnet TEW-P1UG wireless USB2.0 print server, with this you can make use of the router you have now... But either way they basically cost the same! Hope this helps!!
--Joshua79
Apr 05, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
NetGear PS121 Print Server Problem
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
2. Model of printer
Apr 26, 2008 | NetGear PS121 Print Server
Installation assistant cannot detect print server
Results of attempting to connect the Netgear Wireless Print Server WGPS606 and the Canon MF6550 multifunction laser printer. I was on the phone for several hours last evening (March 9, until about midnight EDT) with a very competent support agent from Netgear (actually in the Philippines). The Netgear setup Wizard software would not connect the Print Server to my Verizon FiOS wireless G router automatically, so the Netgear support agent walked me through it manually. The Print Server connected that way, for sure. Then we manually attempted to connect the Print Server to my Canon MF6550 and subsequently, my HP 932C Deskjet. Neither printer is on the WGPS606 compatible list, nor is either on the known incompatible list. Now we know - both printers are INCOMPATIBLE with the Netgear WGPS606. I bought both the Netgear Print Server and the Canon MF6550 at Staples on Sat., March 8, 2008, based upon the assurance from Staples staff that it would all work. The question now is whether ANY brand of wireless Print Server will work with the Canon MF6550, or do I have to return this printer and get either a Canon with built in networking (ethernet or wireless) or switch to the Brother equivalent (MFC 8870DW). If I get a (multi-function) printer with built-in Ethernet networking, does the Ethernet capability bypass the USB incompatibility problem, or will the problem remain?
Mar 10, 2008 | NetGear WIRELESS PRINT SERVER 54MBPS...
Problem printing to wireless print server
I have a lexmark z715 printer that won't work my pc is a emachine windows xp please contact me at noahmackey@bellsouth.net
Jan 15, 2008 | IBM Lexmark Z715 InkJet Printer
Netgear Wireless Print Server WGPS606 won't install correctly
I finally got my WGPS606 installed - unfortunately, it's just on one computer so far, but that computer is on the network and is not wired. Here are a few tips:
1. hold the reset button (little pinhole) until you see some action going on with the lights (I forget exactly what happened, but after a while there was a change) - this served to "reset" my WGPS606's IP Address, which I had changed during setup.
2. connect your computer to the server with an ethernet cable and type in http://192.168.0.102 (the default IP Address of the server)
3. login with the default username and password:
username: admin
password: password
4. once logged in, you will see all of the WGPS606's information. At that point, you should be able to change the IP Address of the server to what you want it to be, but I think you can proceed to run the setup on the installation CD (or the installation program from the WGPS606's Netgear website) and it should be recognized on the wireless network.
In my case, I want to mention that when the initial setup failed for me, I used the MAC address on the back of the server. After steps 1-4, my server was finally on the wireless network by the installation program, however, the MAC address was 1 digit off from what was on the server. The MAC address on the back of the server was the PHYSICAL MAC address, whereas the WIRELESS MAC address was one digit higher (last set of numbers. For instance, on the back of the server, the MAC address ended in ":01" and I found out that this was the physical MAC address. The wireless MAC address was exactly the same, except the last 2 digits were ":02."
Another thing to note was that after the server was recognized, it told me to reserve a specific IP Address other than what I had previously set - I didn't realize that it chose it for you. Anyway, just keep that in mind. After this, everything worked like a charm - well, I have yet to set up the other computers to connect to the server, but at least I have one!
Hope this helps!
Jan 11, 2008 | NetGear WGPS606 (WGPS606NAR) Print Server
Open Questions:
NetGear WGPS606 (WGPS606NAR) Print Server Logo
283 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
