Question about KEF Audio PSW 2150 Speaker
My kef psw 2150 subwoofer is making a buzzing
My kef psw 2150 sub woofer is making a buzzing sound at the back down low on the box. it still produces bass, but the sound is distorted and I can hear the buzzing coming out of the speaker too.
2 Suggested Answers
SOURCE: my kef psw 2150 sub
is probably faulty capacitors
you should check out this link: http://lug.demon.co.uk/kefrepair/?cat=1
Posted on Dec 05, 2010
The amp on my kef sub woofer amp is making a consent buzzing noise it sounds like a kettle boiling. Help
Ok so no guarantees this will work, but it did for me and I knows it's very late but hopefully it will help someone else with a similar problem.
I had the same problem and as clmrt5000 said a very long time ago there could be an issue with a ground loop, although this is likely to give a high pitched buzzing sound.
This can easily be fixed by adding a switch to disconnect the mains earth from the back plate, or you can just unscrew the earth and tape it up, this fixed my ground loop, (some models already have a ground lift switch)
As for the "boiling" sound I also got a saw tooth wave sound (like a strange squeak or beep that changed frequency) this is caused by faulty components, and thanks to Frank Johnson (http://lug.demon.co.uk/kefrepair/?p=60) who suggested that you can simply and easily replace 3 capacitors on the main amplifier board (c58 - 47uF 63v or 100v) + (c52 & c53 - 220uF 25v) but stand them away from the board on the length of the capacitor leads to prevent them from absorbing heat from surrounding hot components (with heat shrink tubing to prevent shorting)
Now my sub works as good as new, apparently these 3 capacitors can cause all kinds of problems it's a common fault, so if you are handy with a soldering iron, or know someone who is you could save yourself a lot of money by repairing you faulty KEF sub.
p.s. if you have ANY of the KEF PSW subwoofers they all have similar issues, you can find a guide to fixing them at the link above, Frank is a brilliant and very helpful man.
Jan 07, 2011 | KEF Audio PSW 1000 Subwoofer
My KEF (PSW 2150) ruffer speaker buzzes even with no input connection?
Your amplifier is bad. I sent mine to KEF in NY and they fixed it for $100 US.
Dec 08, 2010 | KEF Audio PSW 2150 Speaker
Im having trouble with connections from kef psw 1000 sub to onkyo tx sr506 amp. sub is making a bit of a humming noise but not getting any proper sound through. dont know what im doing wrong. can anyone...
Have you got the sub defined to the Onkyo correctly? Try conencting the sub's input to one of the Tape Out connectors and play some FM through it. That will prove if the sub is alive. The nwe can troubleshoot the correct failing device.
May 03, 2010 | KEF Audio PSW 1000 Subwoofer
Loud buzzing from Kef PSW1000 Subwoofer
yes. A good idea. Kill power to the sub, then unplug and remove everything from the sub. go ahead and plug it in again and check for buzzzz.
That is test one. if you have buzz still, its the sub assembly. bad luck, but not impossible. If the buzz is gone its one of the signals to the sub. They can produce a buzzz without any signal coming from your stereo equipment. Replace the feed line, enjoy! BTW...Kef sure does sound clean. good choice.
Nov 09, 2009 | KEF Audio PSW 1000 Subwoofer
HUM noise at PSW3000 if i connect the Yamaha RX-V995
the conections some where are dirty you need to unplug everything clean all connections and the hum will go away
Nov 06, 2009 | KEF Audio PSW 3000 Subwoofer
Kef PSW2010 Subwoofer common problem DIY repair
The relay buzzing fault is caused by a faulty electrolytic capacitor.
You need 47uF 100v 105C radial.
C52 on the corner of the board near some power resistors.
May 10, 2009 | Audio Players & Recorders
KEF KIT 100 Sub woofer continuously buzzing
send me a request to my email address axel_g@mail.com and I send you a fix, Axel
Aug 03, 2008 | KEF Audio KIT100 System
Open Questions:
See all KEF Audio PSW 2150 Speaker Questions
KEF Audio PSW 2150 Speaker Logo
793 people viewed this question
Top KEF Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Greg Cann
Greg Cann
Are you a KEF Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
