Acer Aspire  5610-4648  PC Notebook
Problem for Acer Aspire 5610-4648 (LX.AXZ0X.097) PC Notebook
Aspire 5610-2762 Orbicam not working
By Lizza on Dec 18, 2007
I receive an error stating :
ACER ORBICAM APPLICATION HAS STOPPED WORKING
A problem caused the program to stop working correctly. windows will close the program notify you if a solution is available. Close Program.
I do not use messenger so it is not due to this being downloaded. There is nothing on the Acer troubleshooting and technical support to help with this.
Thanks!!
Clarification Request
Posted by amarmatrik on Jun 02, 2009
Try this solution link . . . http://www.Laptop.com/problem-solution
To find your best solution.
6
Same Problem
May 25, 2009
-   receive an error stating :
the only way that i can use the web cam is in messenger
please help
-   Guest
Apr 21, 2009
-   my bluetooth does not work on acer laptop 5920 -   d17nnb
Apr 11, 2009
-   mine has stopped working too havent really used it at
all no answers to problems ugh!
Cathy uk-   Guest
Apr 05, 2009
-   orbicam not working-   mark-tan-20
Mar 12, 2009
-   same as yours-   Guest
Best Solution
posted on Feb 02, 2008
Helpful)
ComputerDave
Rank: Guru  Acer Expert
Rating: 88%, 407 votes
** Note ** When the My Pictures or Pictures folder gets full, camera will not work - Cut and Paste all pictures in that folder to another folder and restart Orbicam program.
If that does not work then do this:
Start - Programs - look for Acer Empowering Technology then Acer E-Recovery - The look at the bottom and you will "Backup", "Burn disk" and Restore" choose Restore - choose Apps and Drivers at the bottom of Restore tab (it will say extracting) - once extracted - click Install - click Vista or (XP) on the left - click Drivers - click Camera or CCD - on the right side of the screen, click a phrase that has something like "Install now", follow on screen instructions.
Was this helpful?
Yes
No
4 people thought this was helpful
Solution #2
posted on Dec 18, 2007
Somewhat Helpful)
owaari
Rank: Guide
Rating: 81%, 15 votes
Hi Lizza, Do u get this message when you double clicks on Acer Orbicam (Desktop icon)? And which Windows You are using? However you can try following steps...
First of all, You need to check that your webcam is still working, the device does not have problems. You can check this quite easily by opening Messenger -> Tools -> Webcam Settings.
Another way is to check the folder:
C:\windows\BisonCam\
There you will find the application “LiveCam.exe”. Run this to check that the webcam device is working fine.
If you don’t have the “BisonCam” folder, this means that your webcam is a different model; I don’t yet have a complete list of all the devices and their relative folders but all notebooks and webcams have some folder so if you look hard enough you’ll find yours.
The problem
There appear to be two factors that can create this problem:
1] The Orbicam application needs the correct orbicam driver to work correctly;
Windows Vista has its own internal driver to install the device, naming it “Acer Orbicam” (great Windows!!) but in this way the application cannot find the correct driver, so Vista returns the error message.
2] If some pictures are present inside “My Pictures” folders, the Orbicam application will fail to start. It seems to be a Vista issue and still needs to be fully clarified.
The problem seems to have been caused by the Vista Upgrade software, which causes the OrbiCam application on certain models to malfunction. However, as explained above, the OrbiCam camera works fine, the software just can’t control it correctly after the upgrade.
Another issue that has added to the confusion here is that there are “more than ten” different types of OrbiCams installed on Acer notebooks. Again as mentioned above Windows Vista has its own internal driver to install the device, and simply calls it “Acer Orbicam” which makes distinguishing the correct driver from wrong one an almost impossible task. If you replace your driver with the wrong one, the application cannot find the correct driver and you get the error message
Solutions
Currently only 2 notebooks have complete solutions available online. This is because - so far - they are the only “problems” Acer support technicians in Taiwan have been able to fully replicate, analyse and repair.
These “fixes” are not general solutions and ARE NOT OK FOR ALL NOTEBOOKS. This explains why some readers have been getting error messages with the new drivers/applications. The new drivers and applications can be found at the following addresses:
Aspire 9300 at the following link:
http://support.acer-euro.com/drivers/notebook/as_9300.html
Aspire 5570 at the following link:
http://support.acer-euro.com/drivers/notebook/as_5570.html
If your notebook is not one of the two above, read on:
For all notebooks with Acer Orbicam the repair procedure is the same:
1] identify the specific webcam device you have inside your notebook
2] get the hardware description (hardware id) of your notebook’s webcam
3] get the full serial number of your notebook (long alphanumeric code in the bottom side)
4] send this information to your local support centre who can then walk you through the procedure for your specific notebook.
All steps are important because only with the above information can Acer correctly identify the right driver and application for your notebook. Simply sending “Acer Orbicam” as the description, does not help because all the different webcams Acer installed are called “Acer Orbicam” (again, thanks Windows)…
So how do you identify the right one ?
How to get the webcam device information:
Go to “Control Panel”, switch to “Classic View” (the support team still find this way easier and better to work with than the default one) and double click on the “System” icon; to the right you will find Tasks list and below “Device Manager”, click on this.
Now you have the full list of devices of your notebook, look for “Imaging Devices” and double click on this. Here you will find the Acer Orbicam.
Double click on “Acer Orbicam” and the Acer Orbicam Properties window appears. There are three tabs : General, Driver, Details
Click on “Driver” tab, the important information listed here is:
“Driver Provider” and “Driver Version”
Copy this info onto a word / txt file or take a screenshot of this window. Just make sure you write down this information. Then click on “Details” tab
Under “Property” you have a scrolling list, click on it and open the drop down menu.
On the drop down menu look for “Hardware Ids”. Click on this.
In the Value box, you should find something similar to:
USB\VID_5986&PID_0102&REV_0100&MI_00
USB\VID_5986&PID_0102&MI_00
As before, copy these two lines or make a “screenshot” of the window
At the end of all this you will have:
Your Notebook’s Serial Number
The OrbiCam Driver Provider
The OrbiCam Driver Version
The OrbiCam Hardware IDs
Send all of this information to Acer with your support request/telephone call. This should cut down the time it takes them to get you back up and running.
HOPE THIS WILL HELP YOU...LET ME KNOW THANKS
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
posted on Feb 13, 2008
Helpful)
TonyPanti
Rank: Apprentice
Rating: 88%, 2 votes
there is a fully funtional solution available in the downloads and updates section of acer.com.. It is a fix, and works so far as i can tell.
Was this helpful?
Yes
No
Solution #4
posted on Aug 07, 2009
Somewhat Helpful)
elsebn
Rank: Master
Rating: 75%, 13 votes
Try the link . . . www.laptop-problem-solution.com
For find your best solution.
Was this helpful?
Yes
No
Solution #5
posted on Jun 30, 2009
Somewhat Helpful)
ialme
Rank: Master
Rating: 88%, 6 votes
Acer Aspire 5610-4648 PC Notebook main problem is Web Cam Problem, Windows XP Problem etc.
For these problem you can visit a link by just Click Here .
For any other problem with this Notebook you can Click Here
Was this helpful?
Yes
No
Solution #6
posted on Aug 17, 2009
Not Rated)
szy3r
Rank: Apprentice
Rating: 0%, 0 votes
i had the same issue and its weird but move all your pic out of the pictures folder in to a new one and thats it when that folder gets to full the cam will not work
Was this helpful?
Yes
No
Popular Solutions for Acer Aspire 5610-4648 PC
Questions and Unsolved Problems for Acer Aspire 5610-4648 PC
Do you recommend Acer Aspire 5610-4648 (LX.AXZ0X.097) PC Notebook?
Answer
Answer
MyWinLocker geeft problemen. Wil zoom herstellen van verwijderen!
Answer
do this series come with a webcam. if so, or if not, how do i access it.
Answer
Extensa 5420-5687 Acer Crystal Eye Webcam works but says need to update driver and when I check... (More)
Answer
my Acer Lap model is Aspire 5571AWXMi. Bought it before 3 yrs during its life i could'nt use its... (More)
46 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Mar 05, 2009
My Webcam is not Working on yahoo thought it works on the acer Crystal Thing When i take Pictures how do i get this to work on yahoo Messenger.?
Comment by Guest, posted on Feb 03, 2009
Aspire 5610z
I have the same problem .OrbyCam has stopped working
Same problem on Aspire 5103WLMi
Comment by Guest, posted on Jan 31, 2009
I have the 5610 & downloaded Driver Detective to "fix" the problem. All I got was overcharged for no reason.
Comment by luvspets13, posted on Jan 30, 2009
acer orbicam program missing?
Comment by j_sweetz, posted on Jan 09, 2009
when i am using msn messenger i try to use the webcam but it says that it is in use or unplugged... and it doesnt want to work.
Comment by Guest, posted on Dec 09, 2008
my orbicam is not working and i am unable to take still photos and save them . is there a programme that i can get to have this up and runing again?
Comment by dmalibiran, posted on Dec 03, 2008
when my laptop reformat my orbicam got lost
Comment by jewelltran, posted on Nov 29, 2008
my webcam not working at al.........just all black..........
Comment by Guest, posted on Nov 17, 2008
hi
it is about days i have this problme
can you help
Comment by titat, posted on Nov 17, 2008
my orbicam not working
Comment by Guest, posted on Nov 05, 2008
need the drivers for my webcam
Comment by jal_3333, posted on Oct 18, 2008
i want driver for web came
Comment by Guest, posted on Oct 18, 2008
mine doesnt work
Comment by vrkny, posted on Sep 26, 2008
everytime i open acer orbicam it says acer orbicam is not working
Comment by ipers, posted on Sep 24, 2008
everytime i open acer orbicam it says acer orbicam is not working.sometime no webcam detected it appears on the screen.sometimes its totally gray.can acer will do something about this?
Comment by Guest, posted on Aug 18, 2008
orbycam stoped workig
Comment by deborahIdowu, posted on Aug 06, 2008
Acer OrbiCam application has stopped working
A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available.
Rev. Obembe
Comment by daudasenator, posted on Jul 18, 2008
my orbicam has stopped working.
Comment by jeannafoote, posted on Jul 12, 2008
I have the same problem, it says camera is unplugged.
Comment by egoldie_22, posted on Jul 05, 2008
computer just doesnt find a camera. says make sure cam is plugged in.
Comment by Guest, posted on Jun 29, 2008
hmm, that honestly is strange, i really di rely on Acer Corp. But my orbicam is screwed up too. I have an Aspire 5570.
Comment by nickieakin, posted on Jun 19, 2008
Same problem. It says windows is trying to find a solution, but doesn't show anything. I have an Aspire 5610Z
Comment by Guest, posted on May 26, 2008
acer orbicam not working
Comment by Guest, posted on May 24, 2008
my orbicam does not work at all, what can I do to restore or fix it?
Comment by foxhound27, posted on Apr 21, 2008
I have the same problem. I have an Acer Aspire 5100 and the camera was working fine until two months ago for no reason whatsoever. And it's a new laptop.
Comment by Guest, posted on Apr 17, 2008
Comment by Guest, posted on Apr 14, 2008
my camis not working
Comment by Guest, posted on Apr 13, 2008
my laptop is Acer n modl no is Aspire 5610 n my orbi cam is not working
Comment by ronan_javier, posted on Mar 25, 2008
i did not anything coz i dont know much about computer.i dont want to worsen the problem
Comment by Ripton, posted on Mar 15, 2008
Acer orbicam is not working. a problem caused the program to stop working correctly.
Comment by Flashboet, posted on Mar 02, 2008
Thanks!!
Comment by Guest, posted on Feb 27, 2008
my orbi camera is not working
Comment by pk ken, posted on Feb 20, 2008
the orbicam will work on two other windows on this computor but not mine
Comment by aisha631, posted on Feb 17, 2008
i have deleted my orbicam because i thought i might be able to install it again but i can't hiw do i?
Comment by onephatdj, posted on Feb 17, 2008
orbicam not working
Comment by Guest, posted on Feb 17, 2008
i have the same problem
Comment by Guest, posted on Feb 09, 2008
my acer orbicam not working
acer Orbicam not working
Comment by Guest, posted on Jan 08, 2008
mi web cam doesn´t work
Comment by Guest, posted on Jan 07, 2008
aspire 9300-3716 and my orbicam stopped working. the prompt said windows would give me a solution. hasn't happened.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Acer Aspire 5610-4648 PC...:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 712
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
