Question about Apple iPod nano
My ipod freezed up and it wont unlock, and on the cover a picture of a black feather is frozen on the front
  • 341 Answers
Try resenting it, with the Hold switch showing white, hold down the "Menu" and the middle button for about 7-8 seconds.
Hope this helps!
Posted on Sep 28, 2009
  • 864 Answers
First you need to reset the unit 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If you cannot remember the passcode, you will need to restore your device using the computer with which you last synced it. This allows you to reset your passcode and resync the data from the device (or restore from a backup). If you restore on a different computer that was never synced with the device, you will be able to unlock the device for use and remove the passcode, but your data will not be presentFollow the steps that i have outlined below. If this does not completely help your situation please let me know and i will be glad to assist you.According to Apple, if you have forgotten the code, you can unlock the IPod by doing the following: 1 If you can't unlock IPod using either [the code or connecting it to the computer you use to manage its songs. . . Plug the iPod USB cable into the bottom of the iPod Nano. 2 Plug the other end of the iPod USB cable into a free USB port on a Mac or PC computer. 3 Open the iTunes application by clicking on the Dock icon on a Mac or using the Start menu on a PC. 4 Click on the name of your iPod Nano under the "Devices" list in the iTunes window.
5
Click on the "Sync" button to establish a connection between your iPod and the computer.
6
Click on the eject symbol next to your iPod's name after the syncing process has finished.
7
Unplug your iPod Nano. The device will be unlocked and you will be able to access all normal features
again.
if that does not work you can restore your iPod to factory settings using iPod Updater. Please note
that this will erase all data on your iPod.
Afterwards, you can add your music and data back to your iPod.
If you want to change the primary computer that your IPod is associated with, do this:
1. Restore your iPod. WARNING: The restore process cannot be undone.
All of your songs and files will be deleted. Always make a backup of your important data.
2. Connect your iPod to the computer that you want to be the primary computer.
3. Open iTunes and synchronize.
Apple also notes that company "representatives cannot unlock an iPod if you forget your combination.
If you can't unlock your iPod and you don't have access to the primary computer, your only option is
to restore the
IPod, which will erase all music and data."
If you need further assistance please feel free to follow up with a comment and i will be here to
assist you. If this assisted you please feel free to rate the comment. thanks and have a great day.
Posted on Aug 25, 2010
Front doors wont unlock
is it below freezing outside.. doors frozen closed?? what..use regular room temp water from a gallon jug and pour it over the door seal area all the way around the door.. once opened.. take a bar of soap or vaseline and coat the entire door seal to help keep the door from sticking in the future. do this every coulpe of weeks and spray the door mechanism with wd40 or spray lube in a can so it wont stick either..
Dec 15, 2013 | 1996 Chevrolet Suburban
Ipod is on but the slide bar is frozen you cannot slide it open
Just a simple solution--try rebooting your iPod touch. To do that:
  1. Hold down both Power (button on the top) and Home (button on the front) buttons.
  2. Continue doing so even after the iPod Touch turns off and when the Apple logo appears, let go.
  3. Your iPod Touch is now going to operate smoothly, unless you have damaged your device, and if you have, go to an Apple store to have it fixed.
Apr 07, 2011 | Apple iPod Touch 8GB 32GB 64GB 3rd...
My ipod touch is frozen cant slide the unlock bar ove but the wierd thing is the music is still playing
go to an apple store or email them or go to an unlocking store and they do it for a fiver
Feb 15, 2011 | Apple iPod Touch 8GB 32GB 64GB 3rd...
What should i do if my ipod touch 32gb is freeze
if your iPod touch is frozen, hold down the sleep and home buttons for several seconds until the screen goes black. at that point it will reboot and should work fine.
Jan 23, 2011 | Apple iPod touch
My ipod touch screen is frozen on "slide to unlock" so I can't slide it.
Restarting the ipod after it has frozen is a simple 5 step process.
  1. Hold down the hold button at the top left of the touch and the home button at the center front of the device.
  2. Continue holding them even after the slider to turn off the touch appears. Do not let go at this point.
  3. A few seconds after this, the screen will flash and go black. At this point, the touch has been rebooted.
  4. Hold down the hold button at the top left until the screen lights up again and the Apple logo appears.
  5. Release the button and let the iPod touch finish booting up and you’ll be ready to rock again
Sources: http://ipod.about.com/od/troubleshootingyouripod/qt/ipod-touch-reboot.htm
I hope that information above has helped is some way.
If possible please rate this solution.
Sep 01, 2010 | Apple iPod touch
Wont unlock
if your ipod is locked with a password follow this video to un lock
Mar 11, 2010 | Apple iPod Touch 8GB 32GB 64GB 3rd...
My ipod has frozen up it does not charge on the computer or on the home base it wont even go dead its just frozen
IPOD CAN BE FIXED W/ APPLE WEB SIT they have a fix program to bring it back to its original state/ your files are corrupted and so it freezes.
Jun 06, 2009 | Apple iPod MA446LL/A MP3 Player
Apple 80gb ipod freezing/computer wont recodnise ipod
Try it on another computer and if it happens its the ipod. Or try restalling itunes with the lates version (7.7.1)
If that doesnt work try using a different program for your ipod eg Jriver media center
Aug 14, 2008 | Apple iPod MA446LL/A MP3 Player
Ipod wont respond/frozen thingy
try resetting to defaults and then updating to the latest software then download your music after that.
Jan 30, 2008 | Apple iPod MA446LL/A MP3 Player
Frozen screen
my ipod wont turn off or nothing i tried downloading music like i always do and my ipod shows that picture of the plug and it says under it "ok to disconnect" it wont turn off or nothing
Dec 27, 2007 | Audio Players & Recorders
Apple iPod nano Logo
69 people viewed this question
Top Apple Audio Players & Recorders Experts
Sean Cole
Sean Cole
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
