Question about Canon PowerShot SD500 / IXUS 700 Digital Camera
Canon a95 when you turn on the camara the lens opens and closes , and then you get e18
  • Canon Master
  • 4,738 Answers
The following blog outlines some repair options for a lens error:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Dec 23, 2007
Switch on camara, lens opens then closes leaving lens error ! on screen. them camara switches off ??
The systems control board has detected a malfunction in the lens "probably the ccd circuitry" in the lens housing and should be checked out by a camera technician, but you will find it is more than likely not cost effective to repair.
Jan 31, 2011 | Nikon Coolpix S3000 Digital Camera
Canon A540 E18 error
You don't want to take it apart. Wayyyyyy too many parts and steps. I bought a used one with the same problem, lens was stuck half open and out of alignment, it was dropped. I got it working well in about an hour.
I tried all the described tricks, plus a few others.
#1 get a strong canister vac or shop vac, and put the end of the hose right over the front of the camera and turn it on for a few seconds, and turn it lens side down. This will remove any grit in the gears and may pull the lens itself all the way out.
#2 if the lens is still stuck try rotating the outer collar gently both ways until you hear it click into place. If it does, look at the alignment of the inner barrel to the case. the lens will never fully retract if it is out of alignment, if it is you will have to force it back onto the gears it should be on.
If it was dropped resign yourself to the fact you must at some point nearly break those plastic gears inside to get them back where they need to be, and there's a fine line between forcing and breaking it.
Just remember you'll have to get the lens closed and aligned before it will work, closing it is a proces of both rotating the outer collar and gently wiggling the inner sleeve closed. Before it will close it has to be straight. Once it its closed put a fresh set of batteries in.
This whole E18 issue is not as complex as people might think, you just have to be reeeeal gentle with that lens assembly when it's extended.
Oct 03, 2009 | Canon PowerShot A540 Digital Camera
Lens open can not shut down E18
Sometimes it just gets stuck - With the camera on go to the view mode and give it a little jiggle with your thumb and finger. Also - a can of compressed air can loosen up what ever might be stuck in there.
Sep 05, 2009 | Canon PowerShot A95 Digital Camera
Canon camara was dropped and now it reads e18. Camara still shows pictures on the display screen
Hi
The Canon E18 error happens when the lens gets stuck while trying to extend. When your camera was dropped the lens mechanism was damaged resulting in this error for a jammed mechanism.
If the camera is still under warranty you should see if Canon are willing to repair it. If not you can view this link which is a very good walkthrough with pictures on how the error was resolved with a Canon SD300.
As you can see from this the process is intricate enough and involves opening the camera so should only be attempted if you feel confident about taking it on.
http://members.shaw.ca/gregs_space/Canon_E18_repair_guide_for_SD300.pdf
Hope this helps. Please remember to rate my answer. Many Thanks.
Jul 28, 2009 | Canon Cameras
TURN ON AND OFF
there is something in ur camara under the cage broken, very small pice, open it & take it out & close it again & it will work.
Dec 27, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
E18 error on Canon ixus40 - lens stuck
The E18 error is an error message on Canon digital cameras. The E18 error occurs when anything prevents the zoom lens from properly extending or retracting.[1] The error has become notorious in the Canon user community as it can completely disable the camera, requiring expensive repairs.
A quick internet search for "E18" + "canon" quickly reveals hundreds of similar complaints.
ConsumerAffairs.com reports that the "lens has a feature called bellows claw, which is a gear that physically extends and retracts the lens. A piece that holds the lens, the barrier plate, is not large enough and can sometimes cause the bellows claw to malfunction, resulting in a stuck lens". The result is a black screen that only contains the error message, E18. Another problem mentioned on the site blames a sticky iris in the lens, caused by grease entering inside from the microphones built into the lens. The buildup freezes up the ability of the lens to open.
Nov 13, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
My canon A95 comes on and goes off after few seconds.
Try to reset your camera using a command in the set up menu. An error message followed by turning itself off, usually means lens jam. Replace the lens.
Nov 12, 2008 | Canon PowerShot A95 Digital Camera
E 18 problem
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're still worth a try. Good luck! :
Feb 13, 2008 | Canon PowerShot S500 IXUS 500 Digital...
Canon PowerShot SD200 E18 Error
The "E18" error code indicates an error that involves the lens unit or lens cover. The grinding noise you hear-to my regret- means that len's mechanism is malfunction. This type of problem could be fixed by professional only.
Jun 23, 2007 | Canon PowerShot SD300 / IXUS 40 Digital...
PowerShot A70
This comes up when the lens sticks. Try removing the colar around the lens, then turn the camera on/off and give it a "little help" to open or close, it's probably just a little stuck
Dec 14, 2006 | Canon PowerShot A70 Digital Camera
Canon PowerShot SD500 / IXUS 700 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
