Question about Maytag Washing Machines
When I pull the dial out to start nothing happens. I checked the lid relay and it is fine.
  • 15,935 Answers
The timer has failed.
Please reply with the exact model # from your washer, and I can point you to a replacement.
Really simple to install - if you own a screwdriver :)
Please us the "Continue with this expert" option so we are connected in the future.
Thanks!!
Posted on Sep 28, 2009
2000 Ford F250 Disel: Nothing works on the panel for the a/c heater. The fan does nothing when you change speed there is nothing that comes out, there isnt any heat or cool, and when you turn the dial...
Pull the wires from the blower. Throw 12 volts and a ground to it(red is B+). If it comes on, it is good. Replace the controller. If it was the relay, some sort of blower speed would have happened. There are other wires to check, but you would have to loose other things to go this direction. Like accessory and ignition.
Jan 10, 2015 | Ford Cars & Trucks
What is wrong and how do I fix my kenmore 600 series washer?
If this is a top load washer; then the "LID Switch" is broken. Go to www.sears.com/parts, enter your model number and you'll see the switch listed.
Aug 26, 2014 | Kenmore Washing Machines
Maytag stacked unit LSE7806ACE. dryer is fine , the washer will not fill or run, if I manually turn the timer to drain the tub spins and the lid switch works fine. But the unit won't do anything f
You have a timer problem, the contacts are welded in spin mode.
This is almost always caused by advancing the timer by hand when the dial is pulled out in the "ON" position, causing arcing of the contacts.
Sep 22, 2017 | Maytag LSE7806A Top Load Stacked...
HVAC airflow dial only works on high setting
the relay may be fine, it could be a resistor pack that is bad (if it's like what happened with my 2001 Cav [low and med1 did nothing, but med2 and high worked fine] there's a little modular board in the blower fan housing wedged at the front of the passenger side floor (waaaay up there) you'll probably have to pull the blower motor out to get to it, it's not a difficult thing to do yourself, but it's in an awkward position -- the cost (again if it's the same as for a 01) was ~$35+shipping online, and $65 from a local parts store (probably best to call to ensure prices)
Jan 25, 2010 | 2003 Chevrolet Cavalier
La9500xtw1 washer won't run. set dial, pulled out, and nothing happens. checked circuit breaker, and there is power in the outlet. where do we start with troubleshooting?
It doesn't work at all If your washer doesn't seem to work at all, check these: No power Lid switch No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped? Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Jan 21, 2010 | Washing Machines
Says lid and won't work
Check the lid switch... sometimes if something heavy or someone sits on the lid, it can tweak it just enough so the lid switch loses contact and will keep the machine from turning on. You can sometimes bend the lid back. Check the lid switch by sticking a credit card between the lid and the switch with the lid closed... does that solve it? let me know.. KEN
May 08, 2009 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
GE TOP LOAD WASHER DOES NOT AGITATE OR SPIN
ck lid switch can be acessed by pressing clips at front edge of front anel and pulling panel off
Nov 20, 2008 | GE WWSE5200B Top Load Washer
Does not agitate or spin - fills and drains - checked belt & pulleys seems fine
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
The washer is equipped with a lid switch failure detector. If the lid switch
should malfunction, the detector will stop operations for your safety.
Read below
First,turn the control dial to proper cycle and pull dial out to start the washer. If
equipped with buttons, be sure they are fully depressed.
Close lid and pull dial out to start the washer. For your safety, washer will
not agitate or spin unless the lid is closed.
should malfunction, the detector will stop operations for your safety. Call for
service.
Pauses are normal. Wait and see if the washer will start again.
Please remember to leave a rating before you go!
Thank you
Sep 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
15 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
