Question about Hand Tools
I am missing the part that brings the guard back when you lower the saw blade
    Problem Solver:
  • 14 Answers
I am assuming that you have some type circular saw?
Most popular saws use a spring to return the guard,with the saw unplugged raise the guard and see if the spring is there(you may need to take off the blade) if it is not there,replace with proper spring.one end of the spring will hook onto the fixed 1/2 of the guard the other to the front of the moving guard(consult manual if possible).once this is done insure that the guard mover freely and is not in the way of the blade.Replace the blade in proper direction check guard again for proper travel,make sure everything has been re-tightened .
If the spring is there check for material build-up or debris that is causing
guard not to move,remove blade clean debris or obstruction,replace blade and check for proper operation.Also visually inspect where the moving guard is attached to the saw for any unusual marks or wear this could be a sign that some type of unsafe situation exists,if this happens refer to a pro to fix or buy new never use a saw without a properly working guard,it took 141 stitches to repair my friends leg.
Posted on Nov 21, 2009
Replacing blade guard on a 1700W sliding mitre saw
There is an upper (fixed) blade guard and a lower (moving) blade guard which has the added complication of being connected to a linkage or mechanism to swivel the guard away from the workpiece as it approaches the cut.
Mostly careful inspection, once the blade has been removed, will show removal of the guards to be a faily intuitive process. It is inevitable some makes of saw will be more complex and in the absence of official detailed instructions, it will mean a process of removing clips and screws until the part falls off and then remembering what you did so you can put it back together with no parts left over.
Jun 12, 2016 | Saws
How do I fix my spring loaded lower blade guard on my circular saw
I need to know the make and model of your saw in order to help you.
Jan 05, 2015 | Saws
Why is my blade hitting the blade guard
Hard to say without seeing it but....wrong sized blade, bent blade, clamp missing or installed wrong, bent guard, or bent blade shaft. I'd look in that order. Hope that helps.
Jul 26, 2014 | Skilsaw 5150 Circular Saws
How do u life up the saw sleeve (the thing u move to cut the wood) on my Kobalt 10-in 15-Amp Sliding Compound Laser Miter Saw
If your saw is completely intact, meaning no missing or damaged parts, the blade guard should rotate out of the way of cutting as the saw head is lowered to make a cut. You didn't give your model number but there should be a push rod or link plate from the pivot point on the base to the blade cover that pushes the guard out of the way as the head is pivotted downward. If you have the cutting head locked down to make sliding cuts the guard should be up and out of the way. If this isn't happening you may have broken or missing parts of the guard system.
Feb 17, 2013 | Saws
I have a Porter Circular Saw, 18v, Cordless, 6 and a half inch blade. I'm a novice, so I unhooked the wire latchet that held the lower guard on. I figured out how to put the saw blade on, yet I have the...
Remove the battery, take the blade back off and you will see the holes for the torsion spring. what you will have to do is start putting lower guard on but pretenstion the spring so it will fit back into the proper holes, it might be a benefit to remove the small bumper so that you can move the guard more. when installing the blade you don't remove the lower guard just retract it and slide the blade in place. Usually there is a retaining ring to hold the guard in place but I looked at a breakdown and didn't see one. Let me know if you need more assistance before voting please. Thank you
Feb 02, 2011 | Porter Cable Portercable Pc186cs 18v...
Sabre saw- craftsman - 17256 - change blades
This saw uses a tool-free blade change. 1. Unplug the jigsaw 2. Place your finger on the lower edge of the see through blade guard, and pull it forward until it locks up in place 3. Lift the tool-free blade change holder (bright yellow piece above the blade), and insert the blade into the slot of the tool-free blade change holder. 4. Release the tool-free blade change holder to lock the blade in place. 5. Pull down on the blade to verify that the blade is securely locked in place. The teeth of the blade should be pointing forward and down. 5. Put the blade guard back down.
You can use with both 'T' & 'U' shanked blades.
Feel free to ask me any other questions about this saw.
Jan 06, 2011 | Craftsman Evolv 45 amp Jig Saw 17434
Can't find my owners manual. How do I change the blade. Bolt hits on a guard that covers the arbor. On a DW713 combination saw.
Removing the Blade
1. Unplug the saw.
2. Raise the arm to the upper position and raise the lower guard as far as possible.
3. Loosen, but do not remove guard bracket screw until the bracket can be raised far
enough to access the blade screw. Lower guard will remain raised due to the position
of the guard bracket screw.
4. Depress the spindle lock button (Fig. 3) while carefully rotating the saw blade by hand
until the lock engages
5. Keeping the button depressed, use the other hand and
the wrench provided to loosen the blade screw. (Turn
clockwise, left-hand threads.)
6. Remove the blade screw, outer blade clamp, and
blade. The inner blade clamp may be left on the
spindle.
Installing a Blade
1. Unplug the saw.
2. With the arm raised, the lower guard held open and the
guard bracket, place the blade on the spindle against
the inner blade clamp with the teeth at the bottom of
the blade pointing toward the back of the saw.
3. Assemble the outer blade clamp onto the spindle.
4. Install the blade screw and, engaging the spindle lock,
tighten the screw firmly with wrench provided. (Turn
counterclockwise, left-hand threads.)
5. Return the guard bracket to its original position and
firmly tighten the guard bracket screw to hold bracket
in place.
WARNING:
• The guard bracket must be returned
to its original position and the
screw tightened before activating
the saw.
• Failure to do so may allow the guard
to contact the spinning saw blade
resulting in damage to the saw and
severe personal injury
you can download a manual at: http://www.dewalt.com/tools/machinery-miter-saws-dw713.aspx
Jul 20, 2010 | Garden
Replacing the blade guard spring
there is a hold in the lower guard for the loop and the other end wraps around the guard slightly and there is a hole in the back of the upper guard. You can go to Milwaukeetool.com and download a breakdown for the tool Also when you have the blade off I would try using compressed air to clean the area and spray some lubricant on the hub to lubricate. The guard should "snap" back when done sawing. Let me know if you need more help
Mar 24, 2010 | Milwaukee 6378 Saw Circ 8 1/4 15A Worm
The spring for the blade cover has come off how do you fix it? my dad has given me his saw to fix the spring that brings the blade safety cover around, how do you fix it the the mounting post. When I do...
if it a Makita saw it will rub on the guard slightly, What is the model number or you can go to Makitatools.com and type in your model number to see a breakdown for this tool. The post is on the back side of the upper guard and there is a hole in the guard itself for the other end.
Oct 03, 2009 | Makita Saws
Lower Blade Guard on a Miter saw
If you haven't fixed them yet, give me the model and brand and I will see what I can do. Dave
Jun 20, 2008 | Bosch 12" Dual - Bevel Compound Miter Saw...
Hand Tools Logo
200 people viewed this question
Top Hand Tools Experts
Don Numinen
Don Numinen
Bill Boyd
Dan Apthorp
Are you a Hand Tool Expert? Answer questions, earn points and help others
