Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Imperial Model #LA6800XTWO
My washer is old but it was working just fine, went to put my laundry in the dryer and realized that the water was still in the tub. Checked the knobs, restarted the cycle and nothing. It simply won't drain and spin. I read some people saying that they hear a humming noise... I hear silence. I expelled the water by using a cup and bucket and tried again. The water fills the tub and does a little agitating, but then that is the end of it... It does nothing thereafter. That was a good washing machine. It really performed, hate to face the fact that it is at the end of it's life. I saw no use in buying parts and trying to have it repaired because it is such an old model. Better to just buy another, so I had to go to Home Depot to purchase another washer. I got the Maytag Centennial washer and it will be delivered on Tuesday. I know Maytag is a subsidiary of Whirlpool so I pray that this machine is as good at the Whirlpool Imperial.
watugot
  • 290 Answers
SOURCE: whirlpool gold top load washer (7 months old) won't agitate or spin
It sounds like the motor drive coupler has broken. This means the motor is no longer turning the gearcase, but it is turning the pump. It will be repaired under warranty if it is only 7 months old. You should have a full one year warranty on the washer. If not, he can probably fix it, but it will need a new coupler. He can tilt the machine back and see the coupler between the motor and transmission from underneath. I can walk you through replacing it if you want, but I wouldn't recommend it if it is still under warranty. There could possibly be something more major wrong that has caused it to break and some of the factory servicers are real picky about customers working on a machine under warranty. If you need it running tonight, he may be in trouble.
Post back if you need further help or have more questions.
Thanks/mike
Posted on Oct 21, 2007
  • 1314 Answers
SOURCE: whirlpool ultimate care II topload washing machine
Well I'm going to do my best to fix your washer. First unplug the washer and turn off the water. If you have a shop vac take the drain hose out of the drain,and through the drain hose vacuum the water out of your washer. If you don't have a shop vac go to the auto parts store and buy a pair of radiator hose clamps . Then facing the washer locate the two screws. They will either be in the front or rear of the control panel and back them out far as you can. Once you have done that pull the control panel slightly forward, and tilt it back on the hinges. Now unplug the lid switch wire but don't forget to plug it back when your done. Next locate at the rear of the washer body the two gold clips then push forward, and take careful note of how they fit. Then pop them out with a screw driver tilt the washer body forward at 45 degree angel and walk forward with the body, and set it down. Now you will see the white pump and motor assembly. You should see two clips holding the pump to the motor pop them off, and pull the pump off the motor shaft. Now if you fell the need to remove the pump use the radiator hose clamp. take them and clamp the hose coming from the tub but its not necessary for the repair. Next disconnect the wiring harness from the motor (note the position of the harness for reassembly). Remove the two 5/16 inch screws from the motor clamps and pop the clamps off. Once that is complete, remove the motor put the new coupling on the motor and transmission shaft. I use a socket and a hammer
Posted on Jan 26, 2008
SOURCE: agitator will not work on wash cycle
Order the upper aggitator clutch/dog kit $15. Now top half of the aggitator is doing its thing just like the bottom half. Hope this helps someone else too.
Posted on Oct 28, 2008
michiganfan9
  • 179 Answers
SOURCE: Whirlpool Washer - Imperial Series Quiet Wash 2
your washers drain hose is too far down the drain pipe which is causing a siphoning action pull the washers drain hose out pipe some you should be able to hear water dropping into the pipe the reason it only happens in the rinse cycle is because the water from wash is being drained and before the water vacuum is broken the rinse water comes in causing it to keep draining
Posted on Dec 30, 2008
  • 97 Answers
SOURCE: Whirlpool washing machine makes grinding noise
Hello Friend, Your solution is a real quick fix. The problem you are having is very common, your motor coupling has broken and that is what's making the grinding sound, also in this condition it will always pump out the water. Go to your local appliance parts store and purchase a new motor coupler, your cost should be under $25. It's very simple to remove old and install new coupler. First remove two screws from control panel and tilt control panel backwords exposing area under panel. You will see a metal clip on each side of cabinet under panel. Remove these clips, and unplug wires from plug in on cabinet. Remove cabinet by lifting up in back and tilting forward. Once removed you will see the innerworkings of your washer. Lay washer on it's back and remove the two spring clips that hold water pump in place and remove water pump. Leave water pump hooked up just move to side out of your way. Then you will remove the two screws that hold the motor clips in place and just snap the motor clips off. Be sure to unplug the wire harness plug from the motor. Just simply lift the motor straight up and off of the transmission. There you will see the motor coupler broken and to replace, just pry old one off transmission and motor with large flat head screwdriver. You will notice that one half of coupler is attached to the motor and the other to transmission. In the coupler kit you will receive both pieces and the rubber center connector. Just replace all the old with all the new and your problem will be solved. Happy to help, Tim.
Posted on Jun 24, 2009
Water won't drain and washer does nothing
pump is stuck or bad located under washer most are not hard to change
Dec 06, 2009 | Dryers
Whirlpool Thin Twin WET3300SQ (water stops coming in)
  • We are sorry to hear of the problem with your Whirlpool washer. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Digital@Whirlpool.com with your name, phone number, address and the model and serial number for your washer.
Apr 07, 2017 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool LA6800XTWO will not drain or spin
Need a new drain pump. I just had this problem. found a drain pump on ebay for 60. Replaced and running mint again. don't keep trying or you will burn out your motor.
May 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Dryer was working fine then quit heating
go to www.repairclinic.com enter your model number and your parts will come up for you to see. And to see what they look like good luck
Jan 13, 2009 | Whirlpool GEW9250 Electric Dryer
Dec 30, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Imperial Electric Dryer won't start
I have a problem with my Whirlpool IMperial electric dryer, not a Duet gas dryer.
Jul 12, 2008 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I just purchased a New Maytag washer, Model MTW5800Two, it is the loudest washer I have ever heard. It is so loud you can hear it thru the house. I tried putting very few clothes in the largest amount of...
this washer is built by whirlpool and is not the old maytag machine that you have been use to using, the whirlpool family of warshers are not the quietest washer on the market just the best in my opinion,
if you can live with the difference in the noise you will be happy with the wash results
Apr 19, 2008 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
177 people viewed this question
Dan Webster
Dan Webster
Sal De
