Question about Mitsubishi WD-65833 65" HDTV
Mitsubishi green screen
Mitsubishi powered on. All I get is a green screen . Sat system is direct tv. I've reset direct tv but don't know which is problem. I get menu directions on tv screen but it reverts back to green
  • 1694 Answers
SOURCE: Mitsubishi WS65513 with blinking green light
Download Chris@ChrisAndNat.com .........T.
Posted on Nov 09, 2007
SOURCE: Mitsubishi 50" Projection TV (Model VS-50603) Has sound but no picture
MJBNATL:
I reluctantly scheduled a technician to come out next week and take a look at my set. I was going to pay, at minimum, $65 for the service visit. I was then blessed with the intutition to do a bit more research regarding the PIP box being stuck on my television and other input functions (Inputs 1,2, and DVD) being unavailable.
I stumbled across a post on the internet that mentioned that the VS50603 can reset certain error conditions by pressing and holding the Input and Menu buttons (simulatneously) on the front panel on the TV while it is off. At some point after initiating this internal reset the LED light should starting flashing at defined intervals. The number of flashes correlate to a particular error code. Please go to the Mitsubishi website and download the owners manual (VS50609 in my case, couldn't locate VS50603) to lookup what the various error codes mean.
It seemed to me that that the LED flashing did not start immediately after pressing the Input and Menu buttons. In fact, I awoke the next morning to find the TV off but the LED flashing 10 times, pausing briefly, then flashing 10 times again. The sequence of the flashes mean something. Here again, consult your owner's guide for specifics.
Long story short, after awaking to find the LED flashing, I then turned the TV on and voila-my big screen was back minus that pesky PIP box prominently displayed.
I hope this helps someone like it helped me!! Truly a Blessing for sure.
Michael in Atlanta
Posted on Dec 30, 2007
SOURCE: constant green blinking light Mitsubishi tv WS-65513
A quick fix for this is to use a hair dryer to heat up the capacitors and then plug the tv back in.  It should only take about 90-120 seconds to heat them up depending on how hot the dryer is.  The cap's are located on the right side.  Take the front cover off the TV, and heat up the box that is about the size of a small cable box on the right side.  Once the cap's are warm, they will stay warm as long as the TV stays plugged in.
Scott out
Posted on Jan 31, 2008
  • 126 Answers
SOURCE: I have a Mitsubishi WD52525. Green timer light
You are not going to like this one little bit. The reason the LED won't stop blinking is because the digital module is not booting up. I have been fighting this model Mitsubishi for over five years now and the only solid fix is to send the entire chassis back to Mitsubishi for rebuilding. Pulling the chassis is a major job and with shipping costs and Mitsubishi's charges this repair usually runs around $750 to $850. However many owners that contacted Mitsubishi about this problem have gotten that portion of the repair bill coverd. That still leaves $300 to $400 for the tv shop that pulls the chassis and reinstalls it once it is rebuilt.
Posted on Jun 14, 2009
Slinteriors
  • 8617 Answers
SOURCE: Mitsubishi TV green flashing timer light after power outage.
You will need to cahnge the capacitors on the DM board, very common problem. The V21 V19 DM repair kit at the following link contains the replacement capacitors and detailed instructions. Its listed under the repair kits catagory at the following link.
http://servicemanuals.vstore.ca/
Posted on Aug 29, 2009
Hello, I have a Mitsubishi LT-46151. When I power the TV ON I'm getting a blue screen and the GREEN power light is flashing. The blue screen continues to show and then the GREEN flashing power light
Hey it sounds like u have did everything, so check and make sure u downloaded the right firmware on a good USB drive such as a 4GB and make sure format it with Fat32 before u download. Have seen that before with jump drive device and follow directions from Mfg website. If does not work then the CPU or Eprom has been corrupted and main board needs replacing.
Dec 08, 2014 | Mitsubishi LT-40148 40 in. LCD TV
Blinking Green Light on Mitsubishi DLP 52525
the circut that detects the bulb has been also failing in these sets
and the conversion chip that controls the picture , and the transformers are not putting out the full power they are supposed to.
this set will need to be tested to determine the exact cause or causes
Oct 18, 2008 | Mitsubishi WD-52525 52" Rear Projection...
I have a Mitsubishi WD-73737 and when I turn on the tv the power light flashes very fast for a minute then stays a steady green and the screen is a solid blue. There is no sound as well. I have tried the...
Do you have the input turned on that you use the xbox for? Try different inputs as well. If you are getting the menu to come up, the blue screen is telling you that you don't have a signal being run through that particular input.
Mar 21, 2013 | Televison & Video
1 have a 6 year-old Mitsubishi model WS-48511 series 1080 rear projection TV that now won't turn on. A few days ago we shut the TV off, and now when i plug it in the blinking green power light...
This is called the blinking green light of death-----only one of two things can cause this problem.
First: remove front speaker grill (IT PULLS OFF) AND remove inspection plate behind it; look for the two bundles of wires coming down and to the right from the front keyboard of the set.
Unplug both plugs you find (different and marked so you cannot mix them up-----the idea is to take the front keyboard out of circuit-----set will still function with remote as receiver is behind front screen)
Try (after 70 seconds) to turn on with remote
If it comes on---defective reset button on front keyboard----use set only with remote or remove and remove actual reset switch---it is located behind and part of frame for screen----entire front screen would have to be removed to get at it.
Second: if disconnection of the front keyboard does not help, the DM unit is bad.
As you look from back of set it is large metal box at extreme left side.
The blinking light is the unit trying to "Boot" up-----these have a problem where caps and a few other parts in that unit fail-----kits on the net are available----Mitsubishi no longer sells or services these units but PTS Electronics does repair them.
Let me know if you have questions and try disconnection of the front keyboard FIRST.
REGARDS, SD TECH
Jan 20, 2012 | Mitsubishi WS-55613 55" Rear Projection...
I OWN MITSUBISHI MODEL WD-73C9 TV AND THE POWER ON INDICATOR LIGHT RAPIDLY FLASHES GREEN WHEN YOU TRY TO TURN IT ON. SOMETIMES THE WELCOME SCREEN WILL COME ON FOR A SECOND AND THEN THE TV SHUTS OFF OTHER...
Is there audio and is when was the last time a welcome screen came on (in other words, are you even getting that anymore)? I have the same TV but I only get the Mitsubishi Splash Screen only comes on when the TV powers off so I'm a little confused by that. Also how bad were the vents and filters when you cleaned them out and how is the ventilation behind the set? Have you checked the lamp? That's a two year-old set, now so I'm kind of leaning on you needing a new lamp. I had to have mine replaced last summer. You're supposed to get 4,000 - 6,000 hours out of them but depending on your environmental conditions, that lifespan can be dramatically reduced as dust buildup and poor ventilation will cause it to overheat the lamp and normally before it's going to go bad, the TV knows this and starts getting hinky as you described (will come on but then shut-off, etc.). In my case between the wife and three kids and the dad (me) who only gets to watch his shows on the DVR after all the kids are asleep, our set is on 8 - 11 hours a day and longer when I watch the kids at home two days a week so I easily blew through the lamp lifespan in 18 months.
You should check the lamp. Refer to your manual, but it's only two screws in the lower right of the back of the TV, Use rubber gloves as well. If it is the lamp go to Mitsubishi's website and order them. They're OEM and only $100 and cheaper than any of the after-market ones. Also Mitsubishi warranties them and if you need it immediately, you can call them to place the order and just pay an extra $50 for overnight delivery. I've had to do this my TV and my in-laws and I've been very satisfied with the Mitsubishi customer service.
Let me know how it turns out.
Apr 22, 2011 | Mitsubishi MBS73A Base for WD73C9 WD73837...
Green status light FAST blinking and does not shut-off.
SORRY, NO ANSWER.>>> AFTER TURNING MINE OFF FOR THE NIGHT THEN BACK ON IN THE AM, STUCK ON THE WELCOME BLUE SCREEN W/BLINKING GREEN LIGHT BESIDE THE POWER BUTTON. TRIED HOLDING DOWN THE POWER BUTTON FOR 10 SEC., BUT ALL IT DOES IS SHUT OFF. I CAN NOT GET IT TO PERFORM SYSTEM RESET. PLEASE HELP, IF YOU FOUND A FIX FOR YOURS. THANKS! please EMAIL ME AT scottsphoto2@aol.com
Nov 17, 2010 | Mitsubishi WD-82837 82 in. HDTV DLP TV
I have a WD-65737 Mitsubishi DLP TV . Last night it was working great and then this morning it didnt come on . I mean its like it isnt getting any power . The green light isnt even coming on . Please help
iI just had the sMe isuue. your tv needs a system upgrade. Contact Mitaubishi and they will email the upgrade link. You will need Aa thumb dri.ve upto 4gigs to downlaod...ensure its empty. They directions will guide u. thru.
Sep 30, 2010 | Mitsubishi WD65737 65" DLP TV
Does not receive 110 side
Hi a_mizrahi! I will be more than glad to assist you in thhis concern. If your model 510 dvr receiver dont get the sat 110. Lets check 1st the cable connection on the back of the receiver, make sure that the cable connected on sat in is connected hand tight and check as well if the cable is going to the wall with a connector as well. Then press the menu button on the upper left of the remote, it will pop up the main menu, once you got it, press number 6-system setup, 1 installation, 3 system info, It will show the system info one. check on the field letter g, you will see sat number, ex only 119, bcoz you cant get 110, check if sat 119 is green on the buttom box, if its green then select cancel on the screen, then select 1 pointdish, select on check switch then once you are on the install summary, select test on the buttom portionof the screen. It will run a test it could be 1 of 2 or depends on the situation of your sat dish.. wait till it finish. once its finish, it will show the install summary, check if you have, input1-119-all- device name, input2-110-all-device name, or it could show this way, input1-119-odd-even, input2-110-odd-even, if you got 110 on the input after the test it means that we are almost there to fix the problem.. select cancel on the screen, cancel all the way out of the menu until it will pop up attention 015, it should show a progress up to 5 of 5 then it will download the programming guide, wait until it finish the download and it will pop up a picture right away on the tv. let check if the 110 is ok, most of the channels broadcast under 110 is your local channels and some upper channels from the sat.. press menu and then main menu willshow, press 6, 1, 3, back to system info one, check on the field g if sat 119-green, 110-green, if there is no 110 showed on the field g, cancel alll the way out of the menu, then press the power button on the front panel of the receiver for 10secs to reset the system, it should show on the front panel of the box that the power light will turn off and turn back on by itself, then it will acquire the sat signal again, it will go to the process of finishing the progress and download the program guide again, just incase the front panel reset didnt work, do the hard reset by unplugging the power of the receiver to the wall outlet for 1minute. then plug it back in, it will go to the progress again and download the programming guide.. check again the sat on the system info one, by pressing the menu button on the remote, press 6,1,3, check sat 110 is there and 119, it should be green on the button. granting still no 110 sat, select cancel, then select on the screen updates - option 4 I think, once your there, check if without my permission is selected or check, then save , cancel all the way out of the menu, once you got a picture, press the power button on the remote to turn off the receiver, leave the tv on, wait for a few secs and it will pop up attention 061, downloading vital program information, this msg will appear if your software version is outdated.. wait until it finish and once its finish the tv screen will turn black or snowy screen and no lights on the front panel of the box. push the power button on the front panel of the receiver for 10secs to reset the box and wait till it acquire the sat signal and download the programming guide, this should fix the problem, if there is no changes, please call dish network tech support @ 1-800-333-DISH, to check your sat system, there is a possibility that there is a problem on the alignment of the dish, switch or lnbf..
Sep 02, 2009 | DISH Network DVR 510 DTV Receiver /...
MIT WD-62525 DLP TV blinking green light on front won't stop
Hi!
It means your TV needs to reset. Although you have reset it previously, now again reset the TV as per procedure given below:
Please press the SYSTEM RESET button on the front panel with a pointed item such as the point of a ball point pen or end tip of a paperclip.
The TV will turn off and the green LED will flash quickly for about one minute. After the green LED stops flashing, turn on the TV again. The changes you made while the TV was most recently on, before you used the SYSTEM RESET button, may be lost; the changes you made previously, however, are not lost. Only those changes since the last power on may be lost when the system reset button is pressed. All other settings are retained.
TV Reset Menu
Read on-screen warnings before proceeding, as some user data or settings may be erased.
1. Press TV MENU and then 1, 2, 3 to see the RESET SERVICE MENU to reset the TV.
2. Select Reset System Defaults (CAUTION: All settings, except V-Chip, will be reset to the original factory defaults.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 20, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi VS50605 rear projection TV won't come on
The power supply caps in the light engine power supply were faulty when they were installed. You need to remove the power supply and take it to your local electronics shop where they can remove the (7) faulty 1000uf 16v electrolytic capacitors and insert new ones. If you remove the power supply yourself (takes only a philips screwdriver) and reinstall it yourself, the electronics shop shouldn't charge you for more than an hour worth of time. The caps would be about $10.
Here's a photograph (thanks Don Crawford).
Nov 13, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi WD-65833 65" HDTV Logo
700 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
