Question about Polaroid I533P Digital Camera
It shuts off
When i try to cut it on it makes three beeping noises shows a pic. then shuts down.
I have a dial tone, the operator can speak to me, but I can not dial. I get a three beep noise. The function key and all keys just make a three beep noise. The only keys that do not give the three beeps...
see this pdf file this will guide u sir.............
http://pdf.textfiles.com/manuals/FAXMACHINES/Brother%20IntelliFAX%20770%20Home-Office%20Fax%20Machine.pdf
Jul 17, 2008 | Brother Office Equipment & Supplies
I cut my ps3 on and it beeps three times then cuts off
There is a malfunction with the hard disk, or internal proccessor board or chip itself. The hardware is not booting properly so it shuts down so it does not damage itself further before repair is performed.
Oct 08, 2012 | Sony Playstation 3 (PS3) Console
My ps3 goes to boot up an then shuts down beeps three times shows a blue light then a quick yellow light then goes to blinkin red light
You could try pressing the power button and holding it down. You will hear the first beep when you press it but hold it down until it beeps a second time it will take 5 to 10 seconds. This will reset the console and it may boot up. If this does not work you can go to www.us.playstation.com and check the user knowledgebase and/or support for a solution.
Apr 04, 2011 | Sony Playstation 3 (PS3) Console
It makes noise then the tower cuts off but the power still blinks alot..the model number is T6532...it has been this way for a week. It just shuts everything down. The yellow light blinks alot.
Hello
Possible bad power supply,or step down transformer.If the noise your talking about is a beep or a series of beeps then this is called a beep code or codes.
Refer to the manufacturer for reasons for beeps.
Mar 10, 2011 | E-Machines eMachines Desktop PC
I can view my pics but when I try to take a pic it beeps 3 times then auto shuts down...I have a WB550... can anyone help?
Mine just started doing the exact same thing all of a sudden today! Have you found a solution for this yet?
Nov 27, 2010 | Samsung WB550 Digital Camera
C-350 zoom keeps showing low battery and beeping when opened to take pic, but in menu mood shows full, 2 new batteries
I have the same problem but not as grave.
The set can click two to three pics before low batt.
Seems to be a problem with the flash capacitor.
Try with flash turned off the thing should improve.
Nov 22, 2010 | Olympus Camedia C-350 Digital Camera
Three beeps when i try to turn it on
i had the same problem a while back. I fooled around with my camera lens a bit and it turned out that one side of the lens was sticking out a bit. I pressed down on this and pushed the power button and it worked. The next time I turned it on the same thing happened but if you keep doing the same thing it should work.
Hope this helps!
Aug 21, 2009 | Samsung L100 Digital Camera
Shuts down and beeps
The first place i would look is for an improperly seated ram stick or add-in card, also checking all the cables ( both data & power) inside the case.
Then i would inspect the system memory to make sure they are completely compatable.Take the two screws out of the back of the side cover and remove the side from the computer and physically inspect everything i mentioned above.
This is step ONE, dont rate yet , there will be step two and three ime pretty sure..
Oct 20, 2008 | E-Machines eMachines Desktop PC
Polaroid I533P Digital Camera Logo
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
