Coffee and Espresso Makers
Problem for Coffee and Espresso Makers
Generic problem for all Coffee and Espresso Makers
Hello- I have a Saeco Italia machine, abo...
By 2dede on Sep 27, 2009
Hello- I have a Saeco Italia machine (not the Starbucks, but a regular one in red), about 4 years old, and today it simply would not push the grounds through after making a lot of grinding noises. We did the regular cleaning routine to see if that was it but it still won't work. the center light flashes as if it is dirty. It has plenty of beans, but we tried putting in fewer in case it was too many. Still won;t work
Solution #1
posted on Sep 29, 2009
Not Rated)
EsWorld
Rank: Guru  Kitchen Appliances  Expert
Rating: 86%, 325 votes
Try this press the pre ground button then the coffee brew button, if water flows from the spout then the grinder chute is blocked, if no water flows then the brew unit is screen blocked.
If grinder, then remove the brew unit and check the chute from the grinder.
Was this helpful?
Yes
No
Popular Solutions for Coffee and Espresso Makers
Questions and Unsolved Problems for Coffee and Espresso Makers
Answer
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop... (More)
Answer
overflowing can't calibrate half brew
Answer
just purchased the B145...we already own the B70 for the past year...the B145 reservor, there is a... (More)
Answer
kuerig b2003 has yellow & green lights on and red light flashing what's wrong with machine
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Coffee and Espresso Makers:
Top Coffee and Esp... Experts
Rank: Guru Guru
Solutions: 898
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Coffee and Esp... Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
