Question about HP f1905 19" Flat Panel LCD Monitor
HP f1905 monitor problem. The monitor does not
HP f1905 monitor problem. The monitor does not turn on after going into the sleep mode. I then have to either restart the computer or turn the monitor on and off button on several times before the monitor gets a picture again.
There are 3 low ESR Electrolytic capacitors in the power supply that fail. They are 1000uF 25V and can be replaced with RS Components opart number 315-0619
Posted on Mar 01, 2011
  • carl_watts Mar 01, 2011
    No power problem or intermittant power. there are 3 low ESR Electrolytic Capacitors that fail in the power supply. They are 1000uF 25V and can be replaced with RS Components part number 315-0619. There are 5 caps in this area so just replace all 5 with the Panasonic part.
Hp f1905 drops down
Contact HP by phone and they should help you getting another stand for your monitor.
Mar 26, 2012 | HP f1905 19" Flat Panel LCD Monitor
Auto adjust flashes all time
davidfoun435, Possible that unit's internal power supply is about to fail! Go here first and do some reading: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ Remember this! Your cold cathode fluorescent lamp, back-lit, lcd monitor isn't any different than any other brand in it's basic engineering design and mode of operation, and when "strange stuff" appears on the screen the first thing to investigate is the "switch-mode-power-supply"
12fixlouie
Sep 30, 2010 | HP f1905 19" Flat Panel LCD Monitor
When I wake up my computer from sleep mode, the monitor rarely turns on. The on/off button does not work either. I have to unplug and replug in the monitor. Any suggestions?
More likely to have dying power suppkly due to bad caps, look for that first.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Sep 01, 2010 | HP f1905 19" Flat Panel LCD Monitor
Hp l2208w going sleep
Hi
I am sorry that the Monitor is going to sleep mode. Are you experiencing the same issue with different Tower or CPU? Turn OFF the monitor and power cycle it after a minute and check if the same issue persists. Also, reinstall the Video Driver.
Jul 16, 2010 | HP L2208W Monitor
I have an HP w2207 flat screen monitor. I have to
I stoped the monitor from sleeping by going into the montitor's menu, management, then sleep. Turn on the never allow to sleep mode. We were having some of your mentioned issues with the icons and with the monitor not waking up. This fixed that. Now the computer will go to sleep and when started the monitor comes on instantly.
Mar 23, 2010 | HP Computers & Internet
Monitor goes to sleep
go to control panel, display properties, screen saver, turn off,
than go to power options, turn off the "turn off display" option.
Jun 06, 2009 | HP Computers & Internet
Monitor willnot come out of sleep mode
turn off everything and restart computer in safe mode,do this by holding down f8 as you reboot,then go in your setting and remove time limit on sleep mode.
Apr 10, 2009 | HP w1907 LCD Monitor
Multiple monitors, hp f1905 image auto adjusts to upper left corner
You are not looking for the driver for your monitor. You need the drivers for your video card. It is probably running with the defualt Vista drivers as well and needs to have the correct manufactures drivers installed.
With the correct drivers you should be able to control 2 different settings one for each monitor.
Mar 22, 2008 | HP f1905 19" Flat Panel LCD Monitor
HP f1905 19" Flat Panel LCD Monitor Logo
421 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
