Question about Singer 1120 Mechanical Sewing Machine
Feed dog problems
Sewes in reverse
  • Singer Master
  • 1,388 Answers
Has anyone in the family tried to fix your machine ?
For this scenario, the timing is exactly wrong by 180 degrees.
Bargain Box
Posted on Jan 27, 2008
My Steelmaker SW A 2000, recently acquired, sewed fine when I got it home, now it won't feed the material through so it can sew properly.
That sounds like a problem with the height of the feed dogs. Can you see them raise and lower? My advice with any newly acquired sewing machine is to have it cleaned, lubricated, serviced and the timing checked.
click on the link
sewing machine servicing near me Google Search
Jun 09, 2018 | Sewing Machines
Can't drop the feed dogs on my Bernina 1260
Could it be that the feed dog mechanism has not been oiled for a long time? I have a 930 and perform frequent all-over oiling including the feed dog mechanism (all-over refers to a couple drops of good quality sewing machine oil every place where metal rubs on metal). To get them working faster, try directing hot air from hairdryer into the internal mechanics to loosen things.
How can get the reverse lever to work Sewing Machines
It was working now it seems to be frozen the needle part wont move
Feb 08, 2016 | Sewing Machines
I have a White model 3900N. Why does it only sew in reverse?
Hello Jan, I have run into this problem many times. The reason your machine only sews in reverse is caused by old sticky oil at the feed dog pivots. Oil your machine with only high quality sewing machine oil. Pay close attention to the two pivots under your machine where the feed dogs attach to cross journals. Oil them several times and work the reversing lever until the feed dogs move freely and easily. It will sew in reverse if you oil the pivots. Good luck.
May 02, 2015 | Sewing Machines
Reverse button broken
the reverse button that makes the machine sew in reverse is not the feed dog, the feed dog is in the needle plate area. under the needle
when the reverse button is broken the machine must be taken apart and another put in it's place, at a sewing machine repair shop.
Mar 04, 2014 | Euro-Pro Sewing Machines
I have a husgvarna Designer1and the reverse botton is not lighting up and is not going in reverse
The reverse button doesn't light up until the feed dogs reverse their rotation (feed rearward). The problem probably relates to the drive thats shifts the linkage to reverse the feed dogs (although it could be the linkage itself is out of wack). In any case, I doubt that you are doing anything wrong or that this is something you can fix yourself.
Jan 27, 2013 | Husqvarna Viking 1
Hi, have tried to use buttonhole feature on singer 4423. Dog feed teeth have dropped - won't come back up and the material isn't feeding though. Any help greatly appreciated.
Re: Reverse feed dogs on Singer 4423 Remove extension table so you can see switch on BACK of machine @ left side. Flip switch to raise feed dogs up. If machine actually sewing in reverse - check n Buttonhole adjustment. Reset it (located bottom right side machine) Jimmy
Apr 04, 2012 | Singer 4423 Sewing Machine
Feed Dog
Is it in the button hole setting? If so that could explain it.
Jan 17, 2009 | Kenmore Drop-In Bobbin 16231 Mechanical...
Singer model ce100 does not sew with pedal
Check your feed dogs. On the front, left at the bottom is a manaul switch. If you push it to the right it drops the feed dogs, for embroidery and when you push it left it lift the feed dogs. Just remember to turn the handwheel towards you after switching it to the left, until you hear a clicking sound and the feed dogs engage. Hope this solves your problem.
Nov 06, 2008 | Sewing Machines
Singer 1120 Mechanical Sewing Machine Logo
57 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
