Question about Samsung L100 Digital Camera
My Samsung Camera Doesnt focus to take a clear picture at all. can someone help me out please? I've tried chnging various settings with no real improvement the pictures are all blury.
SOURCE: Camera says "memory full," but there's no pictures...
I had this problem, I don't know how it happened. I have the samsung digimax s500, this is what I did. 1 press menu 2 go to 'setup' 3 scroll down to 'format' 4 click right and scroll down to 'yes' that fixed mine, good luck
Posted on Feb 21, 2007
SOURCE: Auto Focus Not Working
Mine did the exact same thing and i hav only had it for 3 months; there is nothing i could do exept for taking it to the professionals
Posted on Mar 16, 2007
Gwenivie
  • 39 Answers
SOURCE: Autofocus not working
When the camera is OUT OF FOCUS, these are the steps that you could try:
1 Power Reset
- Turn off camera
- Remove batteries for a minute
- Reload batteries
- Turn on camera
2 Distance
- When the distance between the camera and the subject is too close,
the strength of the light can cause the picture to overexposed and
be blurred. On the contrary, if the distance is too far,
the beam is too weak to shed enough light on the subject.
Allow yourself enough space between you and your subject.
3 Shutter
- If you press the shutter before the flash is fully charged,
the flash will not be able to emit enough light and therefore
the image can be blurred.
4 Surrounding Light
- Use the fill-in flash mode to create a balanced shot when
the surrounding light is very bright.
5 Backlight
- Use the backlight control feature when the background
is brighter than the subject.
6 Cleaning
- Clean the lenses with a smooth piece of cloth.
7 ASR (Advanced Shake Reduction)
- Put in ASR mode to prevent any blur
8 Master Reset
- Press on MENU button
- Press on the right button until you see SETUP
- Scroll down until you see RESET
- Press the right button to pick up on YES or NO
- Press on OK/MENU button for changes to be saved
- Turn off camera for a few seconds for changes to be saved
* If it still does not work, you need to send the camera for repair.
Just contact the Manufacturer so they could tell you how to send camera safely.
Posted on Jan 19, 2008
  • 370 Answers
SOURCE: my samsung digimax s500 camera still says card locked every time i go to take a pic.Someone kindly sugested holding the rest button, but i
THe SD card inside has a lever to its left Side .... Move it upwards ..... That is the lock on the Memory Card ...
Posted on Oct 16, 2008
  • 11 Answers
SOURCE: Near light, Camera takes white pictures
Try putting it on the daytime setting.
Posted on Jul 21, 2009
How to fix the camera lens focus?
A phone is a phone
If a camera with a zoom lens focuses as it stops
Using a phone for a camera you will have limitations
Regards
Sir J D Hamilton Taylor
IQ 397
Apr 21, 2017 | Samsung Cameras
My connon xti 10.1 mp takes many out of focus pictures even though its on auto focus how can i solve this problem
I think its reqiure to do the focusing adjustent or you can try to clear all camera setting from menu option four. clear both settings and try to take picture and check out of focus problem.
Dec 29, 2009 | Canon Digital Rebel XTi 10.1MP Digital SLR...
Camera not taking real clear pictures
Please go through this pdf file, page 156 will help you to Reset Initial Default Setting of the camere: http://casionz.co.nz/Site/Pronto/Files/user_manuals/EXZ100.PDF
Mar 19, 2009 | Casio Exilim EX-Z100 Digital Camera
Every picture I take is blurred
Try to reset your camera.
Press Menu.
Go to Set Up.
Go to Reset.
Select Yes.
Press Menu.
Dec 16, 2008 | Samsung Digimax D53 Digital Camera
Pictures are blurred around the edges
Have you tried to change the settings like to scenery or adjusted for lighting that could have an effect. The only time it's blurry for me is when I don't adjust for the picture I am taking. The camera itself focuses so maybe there hasn't been enough time for it to focus. Try those things and if it doesn't work I would take it in to a camera shop maybe it has internal problems.
Sep 27, 2008 | Nikon Coolpix S51c Digital Camera
Out of Focus
if your still having a problem with focus, it has to be sent back to samsung for reprograming i had the same fault whilst i was on holiday! another fault with the camera is that it turns its self off when you zoom in, that also has to be sent back to samsung! i dont know how much it would be if its out of warranty, i never found out just bought a new camera!
Sep 16, 2007 | Samsung Digimax S600 Digital Camera
Samsung Projection HDTV BLURRY!
Each projection set has focus controls in back, usually they don't move or go out of focus unless someone moves it, but in your case if you open the back you will see a focus block with 6 knobs 3 are for screen,I would highly recommend that you don't move this. Look for the focus and you will have to set each with the one color. Cover the other two and adjust.
Sep 07, 2007 | Toshiba 36A40 36" TV
Focus
This camera has TTl auto focus so it can't be switched to manual so that idea is quickly stomped on. A silly question, are you half pushing the shoot button down first to activate the auto focus. If you don't and just hit the shoot button you'll definitely get out of focus shots. Have you sat down and read the manual on how to correctly focus. A number of things can crop up which can fool the autofocus into a wrong setting. Have you dropped the camera or has someone else done so? The lens assembly could be damaged. Try pointing the camera at something about three feet away whilst half pushing the shoot button then still holding the button half way point the camera at something a long way off. Can you hear the mechanism trying to focus and does the picture in the LCD change. If it's all quiet and the picture doesn't change then it could be a damaged focus motor or a connection to it is broken. Are you sure the camera isn't switched to Macro. A lot of people get caught with that one. You'll never shoot a focussed picture in macro unless it's less than a foot or so away. BMW
May 31, 2006 | Samsung Digimax A400 Digital Camera
Samsung L100 Digital Camera Logo
66 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
