Question about Microwave Ovens
The door spring broke and in the process of pulling the dishwasher from underneath the cabinet I broke the copper water tubing. That's not a big deal, but in moving the dishwasher around with the broken, sharp tubing coming up from the floor I then noticed yellowish-green oil underneath the dishwasher. I'm afraid I punctured something...is there anything that would contain oil in a dishwasher that I may have punctured?
  • 1 more comment
  • BoulderScott Sep 28, 2009
    Could i have punctured a motor housing? I didn't notice this stuff before I pulled the dishwasher out and then tried to move it...any other ideas?
  • BoulderScott Oct 01, 2009
    Hi...disconnected my dishwasher and pulled it out to diagnose the yellow-green oil. Flipped the dishwasher on its side and it turns out that I punctured the capacitor that is attached to the motor. It was very easily visible and easy to remove. I have a new one on order from Sears: approx. $57 before tax and shipping.
    LESSON: always detach electrical, water, and drain lines before yanking dishwasher out. Also, don't pay $75 for appliance guys to diagnose problem when you can do it yourself. Put this in your library of response for future poor saps.
    Best...BoulderScott
    First comment was not useful, but second one was.
  • 986 Answers
I have never heard of a yellowish green oil in a dishwasher. Go ahead and reomve the washer and post up what it is... Its all new to me. So in short, NO go ahead and repair the copper line and get the dishwasher working.
Posted on Sep 28, 2009
  • Roger Campbell
    Roger Campbell Sep 28, 2009
    On some dishwasher there are coolant sysytems to aid in the cooling of the pump and motor, to reduce the noise while operating. If you punctured that you will have a problem. I have never seen anyone damage that before....Thats all I can think of.
Door will not stay close
Not much data to go on here. The latch on the door has a spring that holds it down in the locked position. when you pull the handle the latch goes up and you pull the door open. You will have to take the door apart and see if the spring broke or the plastic tab that holds the end of the spring is broken.
Feb 25, 2015 | Maytag Appliances Over-the-Range Microwave...
Why will door not stay latched ?
Check the door latches that stick out from the door. Push them up. Is there any resistance? If not, then the spring that pulls them downward either broke or came of its catches. You will need to call a repairman who will have to take the door apart and either replace or re-fasten that spring.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Jun 22, 2014 | Kenmore Microwave Ovens
Door will not latch
Why will my Kenmore model 401.85053010 mocrowave door will not latch?
Jun 11, 2014 | Kenmore Microwave Ovens
Pushed in spring loaded latch on the microwave. Need to pull it back out. Spring is not broke.
No, you don't have a new problem to fix, and consider yourself and anyone else that uses that microwave lucky.
Depending on where that crack is you need to know that the screen like structor in the door is actually a choke to stop and microwave energy from escaping, including anything around it. They are designed to stop any stray microwave energy from leaving the microwave. This could harm you so if it is anyware near that door choke, if I were you I would order another door. The same goes for the gasket around the inside of the door it to is a choke.
You are also causing yourself some potential danger because the door must never be circumvented to keep the light on or off because if you should accidently start the microwave then you will have problems.
Apr 09, 2014 | GE SpaceMaker Microwave Ovens
I have an older model kelvinator dishwasher and there is water in the bottom of the dishwashwer and the diswasher will start and then stop but will go through all of the cycles. It just doesn't do the...
Pull the dishwasher out of the slot. There is a motor underneath that runs the pump to drain it. The usual cause is the it has a bad connection.
May 28, 2011 | Microwave Ovens
Hi hope you can help, I have a 2 door fridge with a bottom draw freezer purchased new 2008 and I have lost the instructions.The prolem I need diagnosed is water leaking from the freezer draw. thanks.
Sounds to me like you have a leak, probably from an ice maker tubing connection or vinyl water supply tube itself. Have someone get a good flashlight and get a good closeup look at where the water is coming from. The water supply to the fridge's icemaker comes from the house wall, floor, or cabinet area of sink. Often they are connected to fridge, then someone moves the fridge to clean and the line gets run-over or tugged on too hard causing a leak. If that is cause, install a new line (hardware stores have these specific to ice makers, 1/4" vinyl or copper tubing) and it should be coiled several times in mid air near the wall, so if fridge is moved out it just uncoils not incurrs damage from un-noticed tension (full amount of water pressure in that little line).
2nd possibility for newer type fridge. All frost free fridges have a pan underneath that catches condensation from coils, from the pan the water evaporates into the air where balance is achieved and pan is never full. On rare occasions, like during moving, on some the pan isn't fastened down and can fall out of place, then condensation water from the coils falls to floor (not any great amount but some).
Jan 15, 2011 | Microwave Ovens
Do the lighbulbs underneath the microwave screw in or pull out- in the process of trying to change the burnt out bulb- i broke the bulb off of the base.
Most moderately new microwaves have a two prong pin type connector that is simply pushed strait in and pulled strait out. I presume the you tried turning it out when it broke?
Oct 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Does not heat food but appliance cabinet gets very warm, some warpage of appliance liner.
One solution could be that the vents of the microwave need cleaning out.You can do this by just pulling out the blockage.
Then see if it will heat food.
Oct 19, 2009 | General Electric PVM1870DMWW 1100 Watts...
The door latch broke, and I can't get the door open, or the food that was in there before the latch broke!!!
Remove the cover --- you shuld be able to release the lock from withinthe cabinet.
While you are there, you may want to replace the door safety interlock switch(s)
You may have to disassemble the door to get the latch fixed.
Oct 19, 2009 | Microwave Ovens
Microwave Ovens Logo
22 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
