Question about GE WJRR4170E Top Load Washer
Washer Problems Washer dont agatate or spin out or stop running
  • 1 more comment
  • korky2 Mar 04, 2008
    washer does not spin out all the water. does not seem to spin as fast as it used to.
  • bossman1050 Oct 09, 2008
    I have the exact same issue on my ge washer
  • Anonymous Nov 30, 2008
    this product is a pos ... seven repairs and not fix from this pile of **** company.... no help from them, just ignorant customer service people.. should have not bought an american built product.. really disappointing trying to buy american....do not make the same mistake.
I have the same problem with my GE washer (GJXRP080B2WW). We started the washer before going out and when we came back home. The cycle finished and the cloths were clean but all wet! I then tried again and it did fill water and drain but didn't agitate or spin. I checked the lid switcher, the timer and the agitator which are fine. However, the motor belt doesn't move and it seems the motor doesn't work when power was on. There are a lot of wires connected to the motor and I don't know which one to check to be sure power goes to the motor. Could you please help me? Thanks.
BTW, I didn't find any Reset button or the start capacity...
Posted on Jun 28, 2008
  • czq8 Jun 28, 2008
    Sorry, I wanted to say I have the same kind of problem but accidently post as solution! Could you please remove it? Thanks,
Model #110.49962600 water fills agates will not spin
And the code is!? Gee I hate when that happens! OK look at these:
F1--Water supply/low water fill.
o 1. Check water supply to machine.
o 2. Replace water inlet valve.
• F2--Water level too high.
o 1. Plugged/Bad water pump.
o 2. Faulty water valve.
• F3--Pump problem.
o 1. Check pump trap and clean.
I go with the last one..Common, then the pump is bad then the valve. But You didn't tell Us!
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
Jan 16, 2014 | Kenmore Elite 45986 Front Load Washer
Hi my washer will not drain or spin Please help
lid switch or pump 1st start washer is the washer agatating lift the lid if it stops you need to ck the water pump all wasers need to drain the water befor thay will drain
Jun 24, 2011 | Maytag Performa PAV2200
AGITATOR NOT SPINNING WHEN THERE IS A LOAD IN MACHINE. IT SPINS WHEN NO LOAD IN MACHINE. (GE TOP LOADER)
Check to see if the nut on top is loose if it is tighten it up by holding the agatator with one hand then screw the cap back down, if it is still not working you will need to see if the agatator is stripped if it is you will have to buy a new agatator and you can find them at this web site. www.appliancepros.com
Nov 13, 2009 | GE WBSR3140DW Top Load Washer
Agitator problem
Check to see if any thing is under the agitator. If not then maybe the bearings going out or other part of machine . Besure the cap is tighten so agatator don't come off. Check for ware on agatator top to the tighting nut.
Jun 02, 2009 | GE WPGT9360E Profile Harmony 4.0 cu. ft....
Kenmore 90 series washer, wont spin, coupler?
my washer wouldn't spin or drain and it was a baby sock stuck in the pump! unplug everything and then take the hoses off and look in the pump! hope this helps!
Mar 10, 2009 | Washing Machines
Maytag Top Load Washer - clanking noise when spinning
no spin cycle or agatator movement , fill cycle and pump cycle works
May 31, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Kenmore washer 80 series 4 years old
my washing machine is not rinsing and spinning
Jan 20, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore washer 80 series 4 years old has prob
You may not have the coupling seated properly. However, if the unit is agitating and spinning at the same time, you may have a more serious transmission problem.
GE WJRR4170E Top Load Washer Logo
200 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
