Question about Whirlpool Duet GHW9150P Front Load Washer
We went on vacation and turned off the water.
We went on vacation and turned off the water. Came home and forgot to turn water back on to use washer. Loaded clothes closed door and turned on.. It flashed the "F & H".The door is still locked and we can't get it to finish a cycle and open.. Any ideas.
  • 29 Answers
Turn on the water, unplug machine and plug it back in.
Posted on Sep 28, 2009
The instruction manual states that the water must be turned of between uses. This is practically impossible for most dishwashers, is this essential, can we run with the water permanently connected?
This is a catch 22, or the washer manufacture does not want to take any responsibility if the fill valve or hose, if supplied by them, should fail and cause water damage in your home!!
During vacations we turn the hot water to off and shut the water off. Water damage in the home is a major expense usually dish or clothes washer hose failure. Other case is burst frozen water line.
If you have a concern add a gate valve in a very convenient location in the cabinet closest to the dishwasher and turn the water off when not being used. These vales open and close with a 90 degree turn. Be sure to hard plumb the connection from the supply to the valve.
Locate the valve in the cabinet at the top in the front so you do not need to bend down to operate.
26289604-aijh2gaskzldpbknmbmiwtzb-3-0.jpeg Hope this helps?
Sep 23, 2016 | Dishwashers
Was away on vacation, shut water supply off, got home and went to do a load, but forgot to turn water back on. Got h and f error code, now door will not unlock, cannot reset with holding the cancel button,...
Hello & Welcome to FixYa
FH error is displayed when the control detects no water entering the machine. To clear this error press and hold the PAUSE/CANCEL button twice. You can then check if the water inlet valve is fine and not clogged with foreign particles, try to clean it. If the water inlet valve appears to be fine then check if the pressure switch hose is properly connected to the pressure switch & tub. Please get back to me if you have any questions.
Kevin
Mar 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Went on vacation and shut water off in house. Came back from vacation and frig. stop making ice. What do I do?
fill tube is probably clogged with ice you will have to melt the ice in the tube that goes thru the back wall to the ice maker, if you shut off the water turn off the im too
Feb 21, 2011 | Samsung RF265AA Bottom Freezer French Door...
My computer appears to be freezing and then over period of few minutes will ''unfreeze'' but cannot connect to internet or get my email--just keeps saying connecting. Was away on a long vacation and forgot...
This can be caused my many different problems, my best guess as the pc was on while away is that you may have a virus. If you have anti virus do a complete scan with updated virus definitions. Also check that your hard disk is not full. If you need detailed instructions or these suggestions did not clear the problem please post back.
Please rate this solution if it has helped you.
Thanks, Gary
Jul 13, 2010 | Dell Computers & Internet
My 32HLX95 won't turn on. Went on vacation, TV
Unplug,replug an hour later see what happen.Power Supply board might need to replaced.
Feb 24, 2010 | Toshiba 32HLX95 32 in. LCD TV/DVD Combo
Water won't stop after removing a electronic water timerfrom hose
turn off water ar meter
remove valve or guts fron tap on wall and replace ruber washer
option 2 go to wallmart and buy a mini ball valve screw it on wall facet and turn it off voila it now turns off 3.99 and your grass is no longer a swamp
Jul 25, 2009 | Garden
Front loader wont agitate or spin, but it fills with water and pumps water out
The timer is failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 01, 2009 | Kenmore 43042 Front Load Washer
Ran HE3 without Water, it's now locked up
Unplug the washer and wait 30 minutes, sometimes the next morning for the machine to reset. Make sure the water is on because it while find multiple failures and lock up, Secondly you can try putting the machine into diagnostic cycle to ensure it is ok. Press drain/spin and select no spin for spin speed finally press prewash quickly two or three times and let it run, any flashing codes?, hit prewash again after writing the codes down.
Jun 15, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Icemaker will not was dispense ice
My icemaker stopped producing ice. We turned off the water line to it when we went on vacation for a week. We turned the water back on when we got home and since that time it won't produce ice. We can still get water from the door dispenser though.
Nov 02, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool Duet GHW9150P Front Load Washer Logo
211 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
