Question about Brother HL-2040 Laser Printer
BROTHER HL-2040 LASER PRINTER- TONER LED INDICATOR STAYS ON AFTER I REFILLED THE TONER
I RECENTLY EXPERIENCED AN LED INDICATOR NEXT TO THE TONER BUTTON STAYED ON.SO I REFILLED THE TONER.
THE LED INDICATOR NEXT TO TONER STAYS ON EVEN AFTER I REFILLED THE CARTRIDGE AND I AM NOT ABLE TO GET ANY KIND OF PRINT.PLEASE HELP ME.
  • 1 more comment
  • Anonymous Apr 21, 2009
    it seems you have a "starter" cartridge - because of that, my printer posted the same error message long ago; I took it out and shook the cartridge; it worked for a while.
  • Anonymous May 02, 2009
  • Anonymous Mar 29, 2014
    pagepro 1500w
  • Brother Master
  • 1,113 Answers
Dont recomend refills causes too many problems, like you are experencing, put in a real brother toner should fix problem.
great link to explain of lights on panel
Posted on Dec 20, 2007
One of the indicator lights stays on
HP LaserJet 2550L Printer panel indicates 4 LED's for 4 toner cartridges, 1LED for the Drum unit. one LED for the power on button. one of the cartridges or the Drum unit has a problem, it indicates from the lights shows on or flashing. By referring to the indication lights you can diagnose the problem contains in one of the cartridges or the drum unit. By replacing the appropriate item you'll be able to make the printer to the working condition.
Jan 24, 2013 | HP LaserJet 2550L Printer
My Oki C5800 is not printing any black- toner is not out, drum is new. I have restarted computer, turned off/on printer, checked cables- not giving any messages. Help?
First of all try cleaning the black LED head with an alcohol wipe, next check the connection to the black LED head and make sure there is nothing blocking the light between this head and the top of the image drum. It may also be worth swapping the LED head between colours to see if the problem moves colour or stays with black. If after moving the head the problem still happens with black then it may indicate a problem with the image drum or an electrical problem. If you have another unit you could try swapping the drum and toner between units.
Aug 25, 2011 | OKI C5800Ldn Led Printer
My newly installed Samsung CLP-310 has a red light showing next to the <...> icon. Please could you help me to resolve the problem. Thx
Hi paulette,
if the light is red and TONER COLORS LED all LEDs off
• The machine is experiencing an error, such as jammed paper, open cover, empty paper, installed waste toner container, or full waste toner container.
• The machine is experiencing a service required error, such as LSU error, fuser error, or Contact your sales or service representative.
if the light is red and TONER COLORS LED each LED lights red.
• Each toner cartridge is totally exhausted. You can not print.
• Each toner cartridge is wrong.
Aug 01, 2011 | Samsung CLP 300 Laser Printer
Hi, my old remote key pad used to lock itself so if I bumped it in my pocket it wouldnt start. I bought a new 2 way recently but the key pad stays unlocked. How do I get it lock?
Press and hold the "f" for 8 seconds to access the remote programming features. The remote will emit one long beep and the LEDs will illuminate. Press the unlock button to access the remote programming features. Two transmit LEDs will flashes and two beeps indicate the remote programming features are accessed. Press the lock button on the remote( LED on indicates auto locking on, LED off indicates auto locking off). Press and release "f" button to exit programming.
Apr 12, 2011 | 872 Responder LE keyless entry security...
All the light flashing
Try this procedure as mentioned.if any mistake in trying the procedure then retry from first step again.so read it carefully and try it. Brother ML-2040 Toner Light Reset
When replacing the toner cartridge in the Brother HL-2040 with a new cartridge (compatible or remanufactured) the user may experience a problem with the toner light staying on, even with the new toner installed. The procedure below has worked for many folks, so give it a shot.
Open the front cover of the Brother HL-2040 and leave open while completing the following steps:
1.) Turn the printer off.
2.) Hold the ‘go’ button while turning the printer on. All panel lights should be on.
3.) Release the ‘go’ button once all lights are off.
4. )Press the ‘go’ button 2 times.
5.) Pause.
6.) Press the ‘go’ button 5 times.
7.) The toner light should be off.
8.) The paper light should be on.
9.) Close cover. The ready light should be the only light on.
Once all steps are successfully completed your “low toner” light should be fixed.
------------- From Brother Service Bulletin
1. Open the Front cover
2. Press and hold the GO button
3. Power ON the printer while continuing to hold the GO button
4. Once the 3 LED’s are lit, release the GO button
5. Press the GO button 2 times. This will cause the LED’s to light solid
6. With the LED’s lit solid, press the GO button 5 times
7. Toner Life End will then reset
8. Close the front cover.
----------- Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 02, 2010 | Brother HL-2040 Laser Printer
Toner Drum coming out
I have had a few machines do this, the quick/easy fix is to make sure it latches and wedge some paper between the drum unit and the latching arm to make sure it stays FULLY engaged.
Sep 16, 2009 | Office Equipment & Supplies
Brother HL-2040 toner led stays on, won't print
There is a window on each end of the toner cartridge that you can cover with electrical tape and keep printing, it shines a light thru and when the toner is too low it says it's empty. The weight can be misleading.
Sep 02, 2009 | Brother HL-2040 Laser Printer
Red Priner LED Wont stop flashing
it is problem paper jum.please chack it then solve your problem
Jul 24, 2009 | Brother HL-2040 Laser Printer
Replaced toner cartridge and light stays on the printer will not
how do i set the toner reset lever on a brother hl 5250 printer
Mar 31, 2009 | Brother HL 5250DN Laser Printer
Brother HL-2040 Laser Printer Logo
1,269 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
