Question about Pentax K10D Digital Camera
Slow to autofocus and sometimes will not focus at all with my pentax k10d slr digital camera with a pentax 16-50 da lens. when I switch to manual focus the camera works fine.
    Brigadier General:
  • 11,967 Answers
Clean the contacts on the camera body and the lens where they connect with a cotton swab lightly dampened with rubbing alcohol.
Posted on Sep 28, 2009
I have a Pentax 1stDL. It focuses (lens movement etc) but the picture comes out as a blank, darkness only.
I experience same thing on my K5 recently. The reason is the shutter and needs to replacement.
You can try to set the camera on "continuous shooting mode", and shot three or more frame consequently. By this way you could miss one or two frames but you may have one or more frames ok.
Sep 02, 2013 | Pentax *istDL 6.1MP Digital SLR Camera...
K100D AF/MF SWITCH STUCK IN AF
Can you be more clear with your problem . When you are facing this problem ?
Have you done basic troubleshooting techniques like replacing new batteries, gentle tapping on camera
Oct 04, 2008 | Cameras
I want to do macro photography and have a bellows lens but will not work? Need settings or old lens will not be suitable.
All K, KA, KAF, KAF2 mount lens should work on your camera.
If the lens is manual focus than you set from the camera closest lens value upon turning on the camera (like 50, 100 etc).
Aug 31, 2013 | Pentax K10D Digital Camera
I have a Pentax K10D from the time they were first sold. I have not installed any firmware as not very technically talented. Have recently bought a Sigma 120-400 zoom.( no zooms of this range from...
Only Pentax DA and FA J lenses and D FA/FA/F/A lenses having an "A" position on the aperture ring can be used with this camera.
The lens you have is HSM DG
Jun 10, 2017 | Pentax Cameras
I have a trouble with my digital camera. When I put a lens on the camera I cannot get the shutter to open. I am using some older lens that I had for my manual pentax. Could this be the problem. When I have...
Hi Noodle
One of Pentax's strengths is that that you can use lenses from the late 1960s on them (via an adaptor). However, I'm assuming that you have a bayonet fitting lens - but as you say 'my manual pentax' could it be that they are not autofocus lenses?
If autofocus is switched on and you have a manual focus lens, you have to have something in focus in order for the shutter to fire. (with no lens fitted it doesn't seem to matter). Switch the camera to manual focus (where you can shoot out-of-focus stuff) and see if the problem is still there.
If it is then it spounds as though there is something amiss with the camera to lens coupling.
Jul 07, 2011 | Pentax *ist DL Digital Camera
What does smcp -fa mean
SMCP- means: Super MultiCoated Pentax (a term that refers to the anti-relctive coatings that Pentax has been using on its lenses for years F-means it is a lens designed to cover the larger area required of a lens for Film camera use versus the smaller sensor of the Digital SLRs Pentax also makes. Pentax also makes DA lenses , which will only work with their digital SLRs. A- means it will work in fully automatic mode on cameras that have the ability to set shutter speed and F-stop automatically (most modern Pentaxes) It should also be noted that all DA and FA pentax lenses have a modified version of the original Pentax K lens mount, which replaced their first lens mount, the universal M42 used by so many early film SLR manufacurers- this concluded todays pentax lens history
Jun 02, 2010 | Pentax Zoom Wide Angle SMCP-FA 28-105mm...
Can lens assemblies normally used with Pentax 35 MM cameras be used with Pentax digital cameras? My 35 MM camera is a Program Plus.
not realy,,, the digital camera is tottely difrent
anyhow they would all be supper long lenses,,,
Oct 14, 2009 | Cameras
Pentax *ist DS digital SLR Autofocus problem
Being an SLR camera, you should try another lens. It may be a servo fault in the lens. If the lens is okay, then it can be anything in the lens sensing, lens control drive circuits, and or lens to camera interface area. This would have to be properly diagnosed and serviced.
Jerry G.
Oct 11, 2008 | Pentax *ist DS Digital Camera
I BOUGHT A PENTAX K10D THAT CAME WITH A VERY NICE AUTO ZOOM LENS. I OWN SEVERAL OLDER PENTAX LENSES THAT I USED ON MY K1000 CAMERA AND I WANT TO USE THEM ON THE K10D. I CANNOT FIGURE OUT THE SETTINGS THAT...
I don't own a K10D, but I do own a K100D which I have successfully used both manual focus & auto-focus lenses from my old Pentax stash!
1) If it is a manual focus lens, you need to turn off Autofocus on the body of your K10D. On my K100D, there is a switch on the side of the lens mount that says [-MF or -AF]. "-MF" is manual focus mode & "-AF" is autofocus mode. Since your lens doesn't have autofocus capability, turn it to the "-MF" mode.
Also . . . When I press "Menu" and go to "Custom Setting", I change two settings . . .
1) I change "Using aperture ring" to "Permitted". This allows you to use manual lenses (M lenses) that do not have an auto(exposure) setting, and also lets you use Auto lenses (A, KA, KA2, FA, etc.) in either the Auto or manual aperture setting modes.
2) I change "Fl with S lens used" so that even with a manual focus lens, although I don't have autofocus capability, my K100D beeps and shows a little red square in the viewfinder when I have successfully focused manually!
The K10D should have the same options.
This should get you up and running!
I have had a load of fun with my old lens on my new digital Pentax!
Take care & Happy Imaging!
Glen
Jul 14, 2008 | Pentax K100D Super Digital SLR Camera
Pentax K10D won't work with lens from Pentax K100 (film0
The lenses are probably manual focus lenses,
  1. Make sure that the apature ring is set to 'A' or automatic,
  2. if these are manual focus lenses then switch the focus switch on the left side of the camera body to MF
  3. If this still doesn't work, or you are having trouble with the apature ring then press the menu button to go to the  menu then press the right arrow key untill you are in the  Custom Settings, scroll through the custom settings with the up and down arrow keys until about the 2nd from bottom there is an option called "using aperture ring" set this to 2 (Permitted) This will make the camera take a image when lens is on any f-stop manually.
Try this and everything should work fine. If all this hasn't worked then try seting the mode dial on the camera to M manual mode. Cheers
Feb 12, 2008 | Pentax K10D Body Only Digital Camera
Pentax K10D Digital Camera Logo
146 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
