Question about Sony Playstation 3 (PS3) Console
I used my ps3 on hdmi now I cant get it to work with rca cables
How do i set the ps3 back to rca?
  • 344 Answers
When you use the HDMIi used my ps3 on hdmi now I cant get it to work wi - 2.gif cable the system becomes automated, it detects that the HDMI cable is in use and with your help it sets up your audio and video.
RCA or Composite cables (same thing) are basic and dont communicate, so you have to go to your system settings in the XMB (cross media bar) and look for video settings, change them back to composite, and do the same for your audio. If that is too much work for ya you can do a master reset of the system. Hook the system up using your RCA cables while the system is powered off, then turn the system on wait 30 seconds and then hold your finger on the power button until it beeps twice, this will reset the system to its original settings
Posted on Sep 27, 2009
How do you use PS3 and DVD player with the Toshiba 32Dtu2 LCD TV?
The PS3 can be hooked up to the tv using either a HDMI cable or the old RCA (Yellow, Red, White) cables. If you are having problems viewing a picture or hearing sound, here is some trouble shooting you might want to try.
Connect the PS3 using both the HDMI and RCA cables. select the HDMI input on your tv. turn on the PS3. If you cant see a picture, press and hold the power button until you hear 2 beeps (this will take about 15 seconds). This resets the PS3 to the old RCA cables. Select the RCA input on your tv. Hopefully you can see the image and hear the PS3 now. Go to the settings on the PS3 and change the display settings to output video through the HDMI. Remember, your tv can only go as high as 1080i resolution, so you wont see anything if you select the 1080p resolution.
If this didn't work, you might have a bad signal though the HDMI cable. Unplug the tv and PS3 for atleast 30 minutes, and then connect the PS3 to the tv before you turn either one on.
If this doesn't help, then you might have a HDMI cable that isn't recognized by either your PS3 or your tv. Try replacing your HDMI cable.
Hope this helps!
Sep 19, 2011 | Toshiba 26HF84 26" TV
PS3 shows a blank screen when I use the RCA jacks but works well when watching DVD movies when using a HDMI cable. When using the HDMI cable the sound is distorted whe I insert a game disk
Well heres the problem when you set your ps3 to be on 1080p using a hdmi cable the rca jacks wont work. to reset it power down the console. Then hold your finger on the power button you will hear it beep twice i believe rca jacks should be working now you will have to do that everytime unless you change it with hdmi cable plugged in to where you can see.
Jun 06, 2011 | Sony Playstation 3 (PS3) Console
I have a HDMI problem with my PS3. I have it
You will need to turn on the PS3 and hook it up with rca so you can access the console menus. Turn it on and get to the main dashboard. 1. Go to Settings -> Display Settings (not video) 2. Select [ Video Output Settings ] 3. Select HDMI 4. Select Resolution 5. Select Screen Size 6. Save the settings 7. Reboot the console. This should resolve the problem. We've seen PS3 consoles that would not reset by performing a hard reset. We were able to resolve this issue through the settings menu though. Let me know if it is still giving you issues.Hank GATpro Repairs
May 14, 2010 | Sony Playstation 3 (PS3) Console
Try entering Recovery Mode and choose "Restore Default Settings".
If that doesn't help, you may have an HDMI port failure - which will require returning the unit to Sony or sending it to a third-party PS3 repair shop.
Mar 25, 2010 | Sony Playstation 3 (PS3) Console
Ps3 works on hdmi but not on rca jacks ???
Sometimes its a pain to re hook up the cords if you are stuck in HD mode and tryin to go back to Regular or Vise Versa, power off the ps3 press and hold the power button for 3 seconds. that will switch the video card back to default settings.
Oct 17, 2009 | Sony Playstation 3 (PS3) Console
My ps3 won't work with rca jacks
when you use the HDMI cable the system becomes automated, it detects that the HDMI cable is in use and with your help it sets up your audio and video.
Sep 27, 2009 | Sony Playstation 3 (PS3) Console
Need Help
try connecting A/V rca cable first. go to ur diplay settings and then to video output settings in it select av multi. don't use HDMI settings let it automatically ask u when u plug in hdmi cable. Then switch to HDMI cable. I had a problem like this before with a ps3 that i had bought used. hdmi was set up and it took forever to set it up with rca cords. took many times power on and offs and unplugging video cords for it to reset. . not sure. Now when u plug in your hdmi on any tv it should automatically set up. and you have settings for a/v as backup. the other thing is it could be the just the port or cable.
Apr 22, 2009 | Sony Playstation 3 (PS3) Console
I want to hook up external speakers to my Acer H213H for when my PS3 is hooked up to it.
What method are you using to connect to the monitor?
If you are using the HDMI -> DVI adapter it does not support sound. HDMI does, but DVI does not.
If that's the way you are set up then all you need to do is use the HDMI -> DVI adapter for your video and use the regular RCA connections for audio.
You can set the video and audio settings in the PS3 with the "Display Settings" and "Sounds Settings"
That way you just use the red and white RCA ends to connect to a speaker system, the yellow won't be in use at all.
Dec 10, 2008 | Acer Computers & Internet
No sound through ps3 hdmi
I have sound on video 2, and when on a static channel but not on the usual channel 3 which is TV. Just stoppen working one day and cant figure it out... Please help!
Oct 19, 2008 | Televison & Video
Problems getting my ps3 to work with the reciever.
cheak setting in ps3 and use 720 p not all sterios handle 1080 p tranfer best u put ps3 directto tv then optical cable from tv back to sterio on a ch ok
Jan 20, 2008 | Pioneer VSX-84TXSi 7.1 Channels Receiver
Sony Playstation 3 (PS3) Console Logo
81 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
