Question about Mitsubishi WS-65869 65" Rear Projection Television
After power outage timer light is flashing and tv wont come on surge protector is ok
    Problem Solver:
  • 5 Answers
We had a similar problem with our Toshiba. It turned out to be that the mercury bulb was toast. Open the owner's manual & look in the Troubleshooting section. The blinking for us was indicitive of a bad bulb. Sure enough, we took it out & it was obviously cooked. Don't buy from a local store, buy it online. You'll save between $30-100 & our "cheaper" bulb has been working for 2 years. Hope this helps!
Posted on Sep 27, 2009
After power surge panasonic hdtv projection tv model # PT-53WX42F wont come on red light flashes
Bobbie, It dose not sound like surge protector was real effective, the TV will have to come apart to diagnose what has all blown, capacitors, boards etc. Google search can help show how it is done.
Enter all your TV's info, will not power on repair.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Apr 08, 2016 | Panasonic Televison & Video
My unit wont get cold, had power outage and think it needs to be reset. How do u reset compressor or unit?
See this video for the "reset" function of some refrigerators:
Easy Refrigerator Fix Reset Defrost Timer Switch if it stops running...
Does My Refrigerator Have Reset Button
How Do Reset My Frigidaire Refrigerator
Said this, I don't mean to "panic" you but if you can't find this "restet" function, your refrigerator suffered a surge effect and might have some electronic cricuir damaged; in best case, some internal security fuse, typical as result of power outage, when power returns.
If you can't find that "reset" call repair service.
By the way, get a surge protector for your refrigerator as soon as possible. See some typica protectors at Amazon, but you can buy one at your local home depot or outlet store.
1800 Watts Refrigerator Surge Protector
Sep 01, 2015 | Refrigerators
Why won't it start?
The computer is not producing a video signal.
The varistors in the surge protector are probably burned out, or there is some other problem in the surge protector.
The monitor is very likely OK.
Jul 25, 2015 | LG Computers & Internet
My standby/timer light is flashing and will not turn on.
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV.
The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. As per the two examples below, some of the issues may be resolved without the need for service.
If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Jun 02, 2011 | Sony KV-27S66 27" TV
I have a Mitsubishi projection model WS-B55 that is plugged into a surge protector. The power went off for about an hour or an hour and a half this morning, and the power light is flashing. I called...
First, to answer your last question, not all power outages and subsequent surges are created equally nor are all surge protectors. Also, after a power outage where the subsequent surge is so strong that it got past your surge protector and knocks out your TV and it's never done that before... REPLACE YOUR SURGE PROTECTOR.
However, that being said, in my experience it is unlikely that the TV is going to require a technician. Understand that the person that you spoke with in tech Support is not a technician and is reading off of a list of troubleshooting pages that are more extensive then what's in the manual. What the technician is probably not aware of is that your TV, like most home electronics, has a safety failsafe that requires the device to be separated from power completely before doing a system reset
First, after pressing the button it's supposed to flash for about a minute anyway but I'm assuming that after it's done pressing that the TV is still not firing up.
Unplug the TV, let it sit for an hour, plug it back in (to the wall, not the suspect surge protector). If the light is still flashing, press the reset button again and wait for it to stop flashing and attempt to turn it on again. If it doesn't work, unplug the TV, follow the same steps however, let it sit for 24 hours before plugging it back in. That length of time is not common but some sets do require it.
If none of this works, then I would say that it's time to call a technician.
Nov 22, 2010 | Mitsubishi WS-55819 55" Rear Projection...
Does my samsung tv keeping turning itself off because of not having plugged it into a surge protector or is it more a fault with my tv
It is a fault with your power supply module actually inside the tv...take it to a local service center or if its under warranty take it back. surge protectors help prevent issues like this occuring due to damage to the power supply from surges but not having one wont cause these problems unless it has recieved a surge.....in future i would use a surge protector on all your expensive appliances, surges and power fluctuations are very common in mains power i live near the mines and we have power problems all the time!! hope this helps,ben
Aug 11, 2009 | Samsung LE40R74BDX 40 in. LCD Television
After a momentary power outage Panasonic LCD TV has a flashing red light and will not turn on.
Try using a different outlet, the outlet or the tv may have been damaged in the surge. In the case of the tv contact the manufacturer and see if it's still under warranty. There may also be a way to 'reset' the tv by holding the power button down, try looking in the manual or calling customer support. In the future use a surge protector, many of today's electronics are still sensitive to power surges, older tv's were more resilliant than today's in this regard.
May 28, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Cannot turn on tv
it sounds like the power surge got past the surge protector and damaged one of the boards in the back of the tv. it may or may not be worth fixing depending on what you want to spend on it
Jan 08, 2009 | Televison & Video
TV won't turn on after power outage
LOT OF TIME WHEN YOU LEAVE IT OFF FOR THE NIGHT DISCONNECT POWER CORD DEFECTIVE SURGE PROTECTOR IS NOT GOOD FORE EVER PLUG TV IN THE WALL WITOUT THE SURGE PROTECTOR IF IT GOOD CHANGE THE SURGE PROTECTOR FOR NEW ONE CHEERS
Jan 17, 2008 | Hitachi 60UX54B/55K 60" Rear Projection...
Open Questions:
See all Mitsubishi WS-65869 65" Rear Projection Television Questions
Mitsubishi WS-65869 65" Rear Projection Television Logo
199 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
