Diagnosict code for a samsung intellect
I want to know what dE means when it comes up on my washing machine?
  • kcsakcsa Dec 19, 2007
    continue receive "de" error code. Door is closed. Have had main board replaced 2 months ago, "de" error code back again. Is this a recurrent problem with LG WM0642H?
SOURCE: samsung b1245s washing machine
Error code is actually 5e and is to do with your drainage being blocked. Check the flap in the lower right of the machine. Open and unscrew the big black wheel/cog thingy (make sure you get lots of towels or drain all the water first with the little pipe to the right of the big black wheel/gog). I found a few coins trapped in my pipe and its working a treat now I cleared them out and spent them on lots of sweeties. Yummy. :D
Posted on Aug 19, 2008
SOURCE: samsung washing machine reset code
solved this problem in 1 min lol just push the door in a little wen u press start so it can form an airlock
Posted on Aug 26, 2008
  • 3 Answers
SOURCE: error code de on samsung front loader J845
The door lock is the problem... try to push the door harder... or change the door lock! It is usually done in 5 minutes.. .... if it is only 5 months... you have a warrenty!
Posted on Jan 26, 2009
  • 351 Answers
SOURCE: Washing machine problem
"dE"
- Lid open error Lid is open during wash cycle. Close lid.
· Check wiring harness
· Check lid switch
· Check unbalance switch
· Check circuit board "OE"
- Water overflow error Water supply does not stop after sensing an overflow condition. Turn off household water supply to washer and unplug power cord.
· Check water inlet valve
· Check pressure sensor switch
Posted on Apr 30, 2009
zaldyboy01
  • 293 Answers
SOURCE: washing machine won't drain, LD code comes on,
drain pump malfunctioning, needs to replace or juct cleaning
Posted on Jul 29, 2009
What does DE in red mean on a samsung DV400 washing machine
There is a door problem.
The following link may provide helpful information.
One can also search the internet using the following:
"DE error code, Samsung DV400"
Jun 02, 2017 | Samsung Washing Machines
Can I change the tune that plays at the end of the washing machine cycle? It is a Samsung Intellect SW55APP3.
some washers may/may not allow you to change the sound but you can look on youtube for your washer model or google as well
Dec 29, 2016 | Samsung Washing Machines
What does the error code dE MEAN
you have not said what your washing machine you have.so this is for the samsung.
If the Machine is displaying "dE" error, kindly check for the following : First and foremost the door must be properly closed. You can check the end of the drain hose is too low (Make sure the holder of drain hose in the back is intact). Also, you can check the end of the drain hose is submerged in water.7 Mar 2014
'dE' Error is displayed on the panel of the Washing Machine? - Samsung
www.samsung.com/in/support/skp/faq/135992..if yours is not a samsung then please let me know.
Nov 20, 2016 | Washing Machines
I've got a samsung top loader washing machine, it's giving me a DE error code. The door is closed and the message only comes when it's about time to spin
DE = Door Error
• Check the Door-Lock SW terminal connections and contacts.
• Bring the probe of tester into contact with two terminals of Door-Lock SW.[dE Error]
What Samsung is attempting to say is: check the door lock assembly, your machine will not spin if it "thinks" the door is open...
May 02, 2016 | Samsung Washing Machines
I want to know what de code stands for on a SAMSUNG WA13F5S2UWW 13KG WH T LOADER Washing Machine
The error code is presented when a "child lock" error has occurred--you will see either "CL" or "DE". You can clear the error after the washer drains. This error condition prevents a child from drowning if he or she should fall into the tub. After the washer drains and the alarm has sounded, close the door, turn the power off, then back on. This instruction set comes straight out of the user manual. This user manual can be found at http://downloadcenter.samsung.com/content/UM/201408/20140828102900808/F500S_GOOD_DC68-03273M-02_EN_FA_NQ_20140512.pdf
Aug 21, 2015 | Samsung Washing Machines
What does dE mean on the samsung sw5asp top loader washing machine
dE means the door its detected as closed
a quick look at THE USER MANUAL
tells you the error codes
http://downloadcenter.samsung.com/content/UM/201409/20140922144717463/WD8704RJ-02718A-07_EN_XEU.pdf
here is the link
if the door closes firm
then you get the DE error then the door interlock has failed
and will need to be replaced
Feb 07, 2015 | Samsung Washing Machines
Code de will not go away
You have not included the Make and model of your washer. Below is a google search for Washing machine error code de
This refers to a Samsung washing machine.
I suggest that you edit your question to include both the Make and model number. This question has been answered before on FIXYA for a samsung washing machine. Link included below. dE
dE1 Ed Door issue ·Check that the door is closed fully.
·Check nothing is trapping in the door.
·Check unit is not overloaded.
· If problem persists please call the customer support team.
Samsung washer machine error code dE
Aug 16, 2014 | Washing Machines
Samsung intellect sw55app users manual
if its new just go back to the shop
Jul 29, 2012 | Washing Machines
I have a Samsung Washing Machine Intellect SW65ASP2 The error code is E. Filled with water and not draining. I undid a hose at the back and removed a coin which I thought was causing the problem. Any...
you should check the impeller, the thing that looks like a fan, when the coin got in there it would have popped the impeller of the shaft, it does this to avoid burning out the motor. it just pushes on
Jan 29, 2011 | Washing Machines
Error code de on samsung front loader J845
Jan 26, 2009 | Samsung WF337AA Front Load Washer
Washing Machines Logo
219 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
