Question about Magellan Maestro 4040 GPS Receiver
My screen is lock on a site 30 miles away. It finds the satellites and even caculates my speed but won't move off that spot
  • kazi-hotmail May 11, 2010
    Is your GPS still stuck? Perhaps I can help. Please directly email me the steps you have taken until you got stuck. My email is kazi at hotmail dot com.
    President:
  • 1,111 Answers
Hi abzellar, one of two thing could be wrong with it.
if the menu button on the main screen says Esc instead of menu, then it is in the search/view map function. just press the esc button and it should go to the main map.
if not, then just reset it and let it in clear view of the open sky outside, this could take up to 30 minutes depending on the conditions but normally they (the satellites) will lock on within 5 minutes.
there are 2 ways to reset your 4040
  1. turn it on and then hold the power button for 15 seconds. after it turns off, hold the power button until it starts. let it sit outside as explained previously.
  2. start the gps and once its booted up, using a paper clip, insert it in the rest hole on the side and let it restart. let it sit outside as explained previously.
if you need further help, just ask.
bill
Posted on Sep 29, 2009
How do I fix my F150 Ford from squeaking on the front driver side.
It's your universal joints. Your universal joints have become warn and what's happening is as you accelerate its moving and the loose universal joints are moving which is causing the noise. It occurs at low speeds because of a slight wobble as speed increases the wobble goes away and so does the noise. It's best to change the font and back at the same time you can find them at your local part store starting at $19.99 each. As for your front end lubricate it real good. Hope this was helpful.
Apr 08, 2015 | 2004 Ford F150
Buick regal gear shift
Speed sensor gone bad .
Aug 25, 2017 | Cars & Trucks
Runs ruff amost like a miss . Has a dead spot between 0 and 30 miles per hr .
Vacuum leak probably.Find it and problem may go away.
EGR can be stuck or plugged and cause similar symptoms.
Also,if spark plugs and wiring have over 50,000 miles on them,replace them. don-ohio
Nov 06, 2011 | 2000 Ford Taurus
A boy is sitting in front seat of bus moving with 30 miles per hour he throw a ball with a speed of 30 miles per hour. With what speed will it move?
this is not a place to solve your home work. and definately its not a problem with website.
however, the answer depends on the direction of the ball thrown
Jun 12, 2011 | Computers & Internet
I have a cobra 7700 pro. it worked fine till to day. I intered and adress when it caculated the route it gave me a message (route calcuate failure , Check Truck Restriction) i have tryed resting back to...
Have you got a satellite lock ?
It needs to know where you are to calculate route.
Please dont forget to vote if you liked my answer
thanks
Feb 12, 2011 | Cobra GPS
I own 2001 Kia Optima LX, it has 121k miles on it. The check engine light is on, and recently it jerks when moving. It does not pickup speed. It moves at 20-40 miles/hour, then after a while it picks up...
The locking steering wheel is a mystery to me , but the poor performance and check engine light make me think fuel filter / fuel pump.
I had a very bad experience with an 02 kia , only had 50,000 miles on it when the timing belt went and destroyed the engine , so........ i always mention to people with kia's to have the belt adjusted and inspected or replaced if you don't know how old the belt is.
Nov 08, 2009 | 2001 Kia Optima
My tom tom cant read where we are and it is indicating our position on a road which is 15 miles away.
it sounds like it lost the satellites.
take it outside in clear view of the open sky and restart it and let it outside for up to 30 minutes or untill it locates and locks on to the satellites again.
Oct 19, 2009 | Tomtom ONE GPS Receiver
Problem with Caculator
You can download the manual from http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=346&modelid=15431
Jun 08, 2009 | Canon P23-DH Calculator
Magellan gps 2000 won't lock in on satellites even after 3 hrs of trying- searching is on the screen telling me its searching
Possible solution, at least my GPS2000 finally locked up. Initialize; enter current location and time; wait until there are more than four (I had seven) satellites available; find a location nearby that has a clear view nearly to the horizon in all directions; place the GPS2000 on a stationary base with the antenna as horizontal as practical; wait; mine finally locked up after perhaps 30 to 40 minutes. Patience and an abundance of satellites, I think, are the answer. Good luck.
Jun 29, 2008 | GPS
Magellan Maestro 4040 GPS Receiver Logo
66 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
