Question about Canon NP 6050 Copier
I bought a secondhand drum taken from a Canon NP6050-220v machine. My copier is a NP6050-110v. Can I use this drum for my machine?
    Problem Solver:
  • 6 Answers
Yes you use it. But when you start the machine leave it for 10 min
Posted on Oct 10, 2009
    Sniper:
  • 153 Answers
Yes you can
Posted on Sep 28, 2009
Canon imageRUNNER C3170 Color Copier
http://www.usa.canon.com/cusa/support/office/color_imagerunner_copiers/imagerunner_c3100_c3170/imagerunner_c3170i if you print out the configuration page from the printer menu screens it will tell you the languages supported this tells you if pcl5 or ps drivers. Where you may come to grief is getting the fax and scanner to work which I have no idea on how this is achieved.
Apr 15, 2014 | Canon imageRUNNER C3170U Color Copier
Colour Laser Printer Problem
Don't use refurbished drum. Proceed with new.
Nov 21, 2013 | Canon LBP5200
I have a cannon i9900 bought in US can I use it in Uk, do I need a adaptor
Check the mains input voltage on the printer. If it is 110v then you need a step down transformer 240v to 110v.
Apr 03, 2013 | Canon i9900 InkJet Photo Printer
I just bought a secondhand Canon Powershot A3100 and it has bad scratches on the LCD screen. Will this affect the pictures I take?
Scratches on the LCD screen will not affect the performance and quality of your pictures that will be taken using this camera , so everything should be fine with it.
Mar 21, 2011 | Canon PowerShot A75 Digital Camera
Canon CLC 4000 won't Power Up
hi first of all cheq the required power for clc 4000 is tis 110V AC or 220V AC, secondly verify the outle of power from wall plug may yor machine 220v and you are putting on 110V
thanks
May 11, 2010 | Canon CLC 4000 Copier
Where is water tank? ( bought secondhand). Thank you.
if its' drum you are talking about, then its outside enclosure of your rotating perforated drum.
Nov 05, 2009 | Hoover Nextra 160 HNWF 3137 Front Load...
I have a PC 25 copier. I am getting black streaks
Run a copy and shut the machine off when the copy is half way through. Open the machine up and remove the toner cartridge. Turn it over and slide open the flap that covers the drum. If you see toner streaks on the drum surface similar to what you see on the page you have a defective toner cartridge. Most likely the toner you bought is remanufactured as this machine is very old. Maybe you can return it for another.
Oct 18, 2009 | Canon Office Equipment & Supplies
Canon iR 2016 copier problem E019
Product : imageRUNNER 2200/2800/3300(i)/2220N(i)/3320N(i) Title : E019
Error :
E019-0000 is displayed on the control panel.
Workaround :
This error code is the indication of the waste toner container being full or a problem with the detection mechanism. Actions to be taken are:1. Turn the machine off and check the waste toner container. If the container is full, empty the container. Clean the inside and outside of the container's neck with alcohol. Be sure that the neck is clear and not soiled with toner before placing it back into the machine. Turn the machine on and check to see if the code went away.
2. If the container isempty and the code is still displayed, check the neck of the container. Turn the machine off and check the container,if the neck is dirty, clean the inside and outside with alcohol before placing it back into the machine. Turn the machine on and check to see if the code went away.
3. If the machine still displays the code after the bottle is emptied and the neck clean; check the sensor, the sensor connections to and from the DC controller PCB for continuity, and the proper positioning of the sensor. Replace the sensor if it is damaged or excessively soiled with toner.
Apr 25, 2009 | Canon iR 2016i Black and White Copier
NP7130 drum problem
hi im jules_09,you should not use compatible consumables for the copier sometime np7130 copier are nasty specially with opc drum,if the copy is blnk the problem is in the high voltage unit or in the transfer unit and drum charge unit you might have the wrong process replacing the drum.re install the drum then try it again .
Dec 02, 2007 | Canon NP 7130 Black and White Copier
Canon NP 6050 Copier Logo
104 people viewed this question
old marine
old marine
