Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
HELP! my vacuum hose is connected worng and i cant fix it!
Okay this is kind of a difficult problem to explain, but our long metal hose will not unlock from our vacuum and for some reason we cannot use the main part of the vacuum. We can only use the hose...it's brand new so i don't know what the heck i did but I am completely lost with the manual and am not about to go out and buy another vacuum!!!! ahhhhhhh HELP!
    Filmmaker:
    Uploaded 5 video answers.
  • 152 Answers
It most likely is the belt this might sound dangerous but with the vac on its side turn it on if the rollerbrush isnt spinning change belt real easy take screws off bottom cover pull it off and the belt is supposed to be hooked around motor pulley and the roller u can tell if it needs belt,
Posted on Jan 06, 2008
I have taken my dyson DC25 vacuums release handle off and can't get it back together. I need help
flexi hose has a release clip inside it, fix the hose back onto the pole. then the metal pole will return back down into position
Jul 13, 2017 | Dyson Vacuums
How to fix retractable power cord
this can be tricky and dangerous if you are not familiar.The cord winder had a metal coil system that spins very fast.Sometime people pull the cord too far out causing the coil to seize.To get to the winder slide off the "Electrolux" slide off[located on the sides of the vacuum] Your best bet is to take it to a vacuum repair shop.Before trying anything take a flat screw driver and puch it in the hole where the cord comes out and push it in,sometimes this fixes the problem sorry I cant tell you more as it is hard to explain the procedure....Please be careful.
Feb 08, 2015 | Electrolux Epic 6500 Vacuum
Hose difficult to extend
Hi June,
I'm sorry to hear you're having difficulties with your DC25. If the wand is difficult to remove from the cleaner, it may be due to the hose being twisted when you replaced the wand on the machine after the last time you used it.
This is easy to correct - please follow the steps shown in the video below.
If you have any further questions about using or maintaining your machine, please give us a call free on 0800 298 0298 (UK), or 1866MYDYSON (US) so we can help.
Kind regards,
Jack
Dyson Online Customer Support
Nov 28, 2011 | Dyson DC25 All Floors Bagless Upright...
Dyson dc17 hose will not come out/ handle wont release from machine. i've pulled the metal rod up all the way and the handle still won't come away from the machine so i can't use the hose and attachments....
Hi there, it is possible that you have a blockage in the wand/hose assembly which is making this difficult to remove.
If you are able to remove it to check for this, please contact our Helpline on 1866MYDYSON so that one of our advisors can assist you.
Kind regards
Darran
Dyson Customer Service
Mar 28, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
Telescope wont retract into hose
get a replacement hose witch is fairly hard to fit
Aug 23, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Connect hose to shop vac
Perhaps you should contact your contractor and ask him for assistance before you destroy his property or make a mess of yours.
Jan 22, 2018 | Shop Vac 201-13 Wet/Dry Vacuum
I need to reassemble my rainbow e series electrified hose handle
Yes, it is a ground wire. When you put it back together, make sure that the two halves of the hose handle are holding the wire up against the metal. I just had one apart the other day for the first time and if I recall correctly, the wire goes near the center for reassembly. Hope this helps!
Mar 15, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Fantom Canister Vacuum parts
http://geeksquad.fixya.com/ThreadView.aspx?prdid=12055&thid=723654
Posted by jaybird73 on Jun 30, 2008
Hi, Don. I'm in need of a part for my Fantom Canister. It's a little difficult for me to describe but here goes...the part is the small metal "pins" that are found in the connection between the hose and the motorized floor attachment. There are normally 2 found in that area, they are about an inch long and I guess they pass the electricity between the hose and attachment. Any help is appreciated.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It sound so me that it could be a lower wand with the pins in the end or the part of the power nozzle and the part that the lower wand fits into is called the gooseneck and that can be replaced as well. If it is part of the hose then you may have to replace the hose and that could be expensive or over $100.00 or more, as an estimate. The best place to get the information is the owner’s manual under trouble shooting or to cal the Fantom factory of which I will provide for you @ the bottom; or your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.fantom.com/ Customer Tech Support 1-800-798-7398
Hours are Monday thru Saturday from 9:00 AM to 6:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 30, 2008 | Fantom Vacums Lighting Canister Vacuum
Bissell Proheat Clearview water problem
The water comes out the hose at the same time. The diverter only diverts the suction from floor to attachment. If it is constantly spraying there is a problem with the attachment. Is it not spraying on the floor?
May 17, 2008 | Bissell 1699 ProHeat Clear View Upright...
Attachment probs
Hi- Do you have a manual for the vacuum? My manual says to raise the headlight hood and then flip out the l-shaped handle on the belt lifter and turn it until the red arrows line up. Turn the accessory lock all the way to the left and the front should lift off. Then take the attachment hose and hook the two hooks over the bar and then push the hose up against the vacuum and lock into place by turning lever to the right. Does this help? Its kinda hard to explain without the pics.
May 19, 2007 | Kirby G6 Bagged Upright Vacuum
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
104 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
