Question about Sekonic L-358 Flash Master Light Meter
The sekonic 358 gives an 'error 6' message after multiple 'e.u' messages when trying to read flashes at night using the module.
3 Suggested Answers
Obertelli
  • 3006 Answers
SOURCE: meter is consistently a half to a full stop off
I've known this problem to occur if the wrong kind of CR123/CR123A lithium battery is used. They come as rechargeable and dry cell (i.e. non-rechargeable) versions. For sensitive devices like yours the difference is important as the internal resistance of the rechargeables is lower which affects the voltage characteristics.This meter is designed only for the dry cell version: see page 34 of the user manual, although the instructions don't make this fact clear enough IMHO. The reason for using the dry cell version is that the output voltage remains constant until the battery is nearly exhausted, but the rechargeable version starts at a slightly higher than nominally rated voltage and drifts down as the battery discharges. This means that you only get a truly accurate reading with a dry cell battery. There is no user adjustment to recalibrate the meter but you can use a different ISO rating to compensate or use the exposure compensation settings.
Posted on Jul 04, 2009
  • 7 Answers
SOURCE: Sekonic L-358 light meter will not trigger my
Hi Liz
have you checked your sync cable?
tried meter on another system (for comparison)?
Depends where you are.. Mamiya in the USA can solve the problem.
Posted on Jul 21, 2009
I hav a clarion auto cd/stereo displaying err 6 please explain, thank you
Error 1.Battery inside CD Changer needs to be replaced.
Error 2.CD error message. Mechanism has as eject problem or takes a long time to select CD.
Error 3.CD error message. The pick-up is out of focus during play mode due to scratches on the disc or contamination.
Error 4.Connection problem. Reconnect the data cable.
Error 5.CD error message. Could not read correct data due to CD ROM.
Error 6.CD error message. Could not read data from disc because it is upside-down.
For error code 6:
Try an original purchased cd with no scratches and see if the cd player reads it. If yes then lens is dirty or tired so try using a cleaning cd(has little brushes on it). If it doesn't read with the original cd try using the cleaning cd and if no go then look at purchasing a new cd player!
Nov 01, 2010 | Car Audio & Video
I use the settings recommended by my L358. However, when I set my camera to those settings in manual mode, my photos are dark. Why is this happening?
The fault is either with your camera/lens or with the meter itself. Try the meter with another camera, if the exposure error is still present then check that the custom compensation feature on your meter has not been set by mistake (page 26 of the user manual). If this doesn't cure the fault then try fitting a new CR123A battery. If the fault still remains then you can either compensate for the error by always using a longer shutter speed/wider aperture than recommended or you will need to send the meter for servicing.
Good luck, and please take a moment to rate my answer.
Aug 29, 2010 | Sekonic L-358 Flash Master Light Meter
L-358 light meter doesn't change modes
Most probably the switch under the Mode button went faulty. Try to operate the button many times, sometimes it helps, if the culprit is corrosion or small debris inside the switch. If not, have the meter repaired at Seconic.
Oct 12, 2009 | Sekonic L-358 Flash Master Light Meter
Get multiple error messages that a particular
download the mccafee remover some installer of mcafee cont uninstal but they have mcafee remover..
Sep 11, 2009 | Mcafee 2009 Internet Security - 3 User...
Sekonic L-358 light meter will not trigger my photogenic lights anymore? Thanks, Liz
Hi Liz
Jun 08, 2009 | Sekonic L-358 Flash Master Light Meter
Meter is consistently a half to a full stop off
Apr 19, 2009 | Sekonic L-358 Flash Master Light Meter
Does Not Play
Dvd drive needs to be serviced or replaced.
Jan 28, 2009 | Microsoft Xbox 360 Console
I can not access to play
try reinstalling the program you are using, also contact the support of your digital camera company and give them the error message they know there better about it.
Jul 23, 2008 | Cameras
Sekonic L-358 Flash Master Light Meter Logo
253 people viewed this question
Top Sekonic Cameras Experts
Are you a Sekonic Camera Expert? Answer questions, earn points and help others
