Question about LG Flatron L1750S 17" LCD Monitor
Dell 1905 stayed in analog power mode, bought a new LG2250 set it up and it stays in analog power saver mode. I can't see anything on the computer
  • 3,741 Answers
Firstly check the connecting cable from the screen to the computer at both ends. Ensure that the thumbscrews that keep the connector in place are tight. Has the PC been moved recently? Any chance the cable could have been put in the wrong place?
You can get the installation manual on the following link to see where that cables should go:
http://us.lge.com/filedown.do?filepath=1...
Try resetting the monitor by pressing the "Auto/SET" button on the front panel for a few seconds with the PC on.
If that fails you can do a full factory reset on the monitor by using the on screen menu and navigation to the "reset" function on the setings (gearwheel) page. This is described in the manual page A12.
If all this fails then disconnect the cable to the monitor, the monitor should display "no input signal" if it does suspect the PC graphics card is faulty.
remove the case of the computer and make sure the graphics card is in tight, and while you're at it, make sure its clean
also try Go to display settings. Click on the checkered monitor. Hit the check box for extend the desktop onto this monitor.
This will help. Thanks please keep updated.please do rate the solution if helped.thank you for using fixya.
Posted on Sep 28, 2009
I have a dell studio 540 desktop, I need to restore to factory settings but my monitor will not stay open. It opens for a few seconds then immediately goes into power saver mode and turns off, how can
I see two things here, but need clarification;
1) Monitor goes to Power Saver Mode, then turns -> OFF?
Sure that monitor didn't go into Standby Mode?
2) Why are you performing a restore back to factory settings?
Pick up a virus?
Primer;
The monitor receives a signal. A video signal. The video signal comes from the computer.
If the monitor is NOT receiving a video signal, then the monitor will state No Signal.
This is for older monitors.
New monitors do not state No Signal anymore.
It's Power Saver Mode, or Sleep Mode.
If the monitor is truly OFF, the Power On button will Not be lit up.
Or the Power On LED light on the monitor.
Monitor power on LED is lit, or Power On button is lit?
Monitor is not receiving a video signal;
Use a monitor cable from a KNOWN to be working monitor, for a temporary test.
OR,
Use a Known to be working monitor, and it's monitor cable.
Need to find out if monitor cable is good.
Monitor cable checks out good?
Then problem is computer.
The two leading issues with desktop computer failure, is;
1) Computer is dirty inside
2) Power Supply inside computer is bad.
Please post back in a Comment.
Regards,
joecoolvette
Mar 27, 2013 | Computers & Internet
My 65" samsung turns off when i connect my laptop
Hi Spence,
Is the TV set to "VGA"? If the TV does not detect a signal, it won't stay on, only go to a sleep mode. Make sure the cable is securely connected to the TV as well. You may go to the settings and check the power saver settings, but I don't think this has anything to do with it, I only offer it as another avenue to pursue.
Best luck
Joe
Sep 20, 2011 | Dell Computers & Internet
How can I disable my monitor's sleep mode? I don't want the screen to go black, I want to be able to see the screen saver as it cycles. Thank you.
You can do this in the Power Savings options with Windows. For Windows 7, rght click on the display (anywhere with no icons or running programs) and choose Personalize. Click on Screen Saver in the lower right hand corner. Adjust the Wait time for the screen saver if desired and click Apply. Then click on Change Power Settings. This brings up the Control Panel > Hardware and Sound > Power Settings. Then click on Edit Power Settings for the active power plan. (For desktops it is usually the balanced power). Then change the setting for Turn off monitor to Never when plugged in. Also change the Sleep time for the computer to Never. You can do the same for when on battery but it will shorten the length of time that the computer will be able to run on the battery for laptops. Then Save Changes and close the windows.
For older versions of Windows, these advanced power settings are also available from the Screen Saver settings page but details may differ.
I hope this helps.
(for most monitors, as long as the computer is sending a signal the monitor will stay on)
Dec 23, 2010 | Dell 22" SP2208WFP Widescreen Flat Panel...
Lg monitor - ''Analog Power Saver Mode''
Kindly check the power supply inside your system, when you power on does the fan rotates. if not then you need to replace the power supply of the system.
i hope this will resolved the issue
May 25, 2010 | Computers & Internet
Out of the blue one day, monitor started displaying "anaolog power saving mode." This is a stand-alone computer which has never been hooked up to internet.Took tower unit to PC World to see if it was a...
you go to control panel starting your pc ,, then display settings,, from there,, screen saver tab, then make screen saver to none, and click on button power,, there you make everything to never,, and then see. it should work good
Sep 27, 2009 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Monitor stopped working...checked all connections...light won't stay on green. bought a new monitor to replace it and that monitor says "no signal". is this a problem with the dell computer and not the...
Your monitor is going into power saving mode. When it receives no video signal from the computer, it will stay powered for a few seconds before giving up and presuming the PC is off hence why it stays green for a while, then goes orange.
The problem is with your PC not the monitor(s)
Jul 07, 2009 | Dell Computers & Internet
Cant seem to turn on
Gp to Bios Set-up and look for set-up default. Then save and exit.
Apr 07, 2009 | Dell Inspiron 530s Desktop Computer
Dimension E521 stuck in power saver mode
OK, I am sorry to say that it seems to be more than I thought. Here is a link to a forum where other people are having the same problem. I expected it to be a setting but this sounds like I'm wrong. I sure wish I could be more helpful. Here's the link though. Good luck, I know how frustrating it is.
http://forums.techguy.org/hardware/541286-monito-stuck-power-save-mode.html
Jan 31, 2009 | Dell Dimension 2400 PC Desktop
Dell 17" flat screen monitor
When they stay in power save mode the logic board is usally the problem. Cneck out www.lcdrepair.us they sell all the parts for that unit.
Dec 10, 2007 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
Denon avr-1905
Yes...and no it's not worth saving,,,,don't ever buy another Denon....! Worst Warranty, Worst Tech Support!!!! Cheap units...
Nov 28, 2007 | Denon AVR-1905 Receiver
LG Flatron L1750S 17" LCD Monitor Logo
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
