Question about Canon PIXMA MP530 All-In-One InkJet Printer
On the canon mp530, I keep getting the error: CHECK INK U150 M All cartrages are full! Why the error?
I have put in new cyan ink cartridge but printer does not recog
are you sure you got the right ink cartidge put in? Also check if you took that piece of plastic that coverred your ink cartridge contact
Mar 20, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA MP530 printer repeatedly getting LCD Error Message: "CHECK INK U071 5Bk". I have removed, reinstalled, reseated the 5Bk and all other ink tanks multiple times. Usually when this...
I have Canon M560 printer installed 8 months ago. I replaced the CLI 221 Magenta and CLI221 Cyan ink cartridges, won't work and got this message Error 1411. Tried repeatedly to reinstall the ink cartridges and still have this message coming back. Any solution you could offer? I would appreciate it. Thank you.
ben
Nov 06, 2008 | Office Equipment & Supplies
U150 Canon no cartridge recognised
Because these a refills inks the Chip things they are full so you must replace the cartridge with a new Canon one and the fault will go. If not just replace the chip with a new one!
Then your error u150 will go.
Sep 25, 2008 | Canon MP610 Photo All-In-One Printer
I keep getting a U150 ink tank cannot be recognized message. I check the ink tank, it is full. It lghts when I put it in, but when I put the cover down, the light goes out and is not recoginzed.
YES- the solution is I had been sold a cartridge for the printer that was same series 8 it needs but it was PM Magenta not a stand M for magenta so I found out form Canon - this is not a photo printer and it cannot use photo printer ink attached Canon's reply to confirm. Went back 3rd time got the M in the 8 series and all is good alarm light out and no error saying it cannot recognize the ink cartridge. YEAH!!!
Thank you for your reply.
Yes, the PIXMA MP530 only uses the regular ink tanks and not the photo
ones. This is the reason that it did not work correctly. Glad to hear
that everything is working now. If we can be of further assistance with
your PIXMA MP530, please let us know.
Thank you for choosing Canon.
Sincerely,
Devin
Technical Support Representative
Aug 24, 2008 | Office Equipment & Supplies
Canon IP6600D Error Message U150
you need to reset the chip on the ink cartridge.......................
Aug 22, 2008 | Canon Pixma iP6600D InkJet Photo Printer
Refilling mp530 ink tanks
www.PrinterInkWareohouse.com @ 866-465-7334 has solutions to most of these printer issues since that's the way they have return customers, is to have these issues bypassed!
Aug 13, 2008 | Canon PIXMA MP530 All-In-One InkJet...
It appears U150 the following tank cannot recognized.. All ink are full
has anybody a solution for these crappy ip6600d canon printers constantly getting the u150 error, i've got a brand new canon catridge but to no avail, it still complains.
Jun 24, 2008 | Office Equipment & Supplies
U150 error on MP600 Canon printer
Canon should offer a product recall on all printers affected by this common U150 problem. I wonder though if they are even aware of it, or care. There are no forums (as far as I can see) on the Canon web site. Maybe they're clueless, and that's bad. Maybe they're NOT clueless and don't care, and that's bad too.
Mar 02, 2008 | Canon Pixma iP6600D InkJet Photo Printer
Error code: U150 The following ink tank cannon be recognized (Cyan)
U150 ink error fixed!
I too was getting the error for unrecognized ink cartridge. Then the little green circ board fell out of the end of the ink cartridge and it hit me that maybe if I put in the little green circ board from the old ink cartridge of the same color, then maybe the ink cartridge would be recognized. It worked! So don't throw out an ink cartridge that still has ink just because of that error and hold onto your empty cartridges in case you need the little green/gold circ boards.
This works!
Dec 26, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Alarm light on, Display indicates error message: Check Ink U150 M
I added my post today with the same problem, and thought I'd share what I since learned. Apparently this "Alarm light/U150" is common with several Canon models. The U150 indicates a faulty electronic chip (on the ink cartridge). Though I tried cleaning the sensor with isopropyl alcohol, and also tried removing all the cartridges, unplugging the printer for 45 seconds, then reconnecting,etc. as I had read might help, I still had the same frustrating problem. Contacting Canon was the solution that worked for me. First I emailed, but decided I didn't want to wait for their response. A call to Canon Tech Support (1-800-385-2155) was quick and painless. They will more than likely send you a new cartridge, but you'll need to have your serial # & date of purchase handy.
Oct 27, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
509 people viewed this question
old marine
old marine
