HOW DO I GET ON LINE - Computers & Internet
  • 530 Answers
There are a few details you should include that would facilitate your on-line connection. Such as the type of connection, (wireless, cable, dial-up), and the OS you are using, (vista, xp, mac os 10).
However I can provide you with the basic requirements that are common with all hook-up's. For the purpose of this explanation I will use the most common type of hook-up, broad band/cable connection.
The first item is the modem. The cable feed coming in to the house will connect to the cable modem. From here it is connected to the computer's Ethernet plug by cable. Normally this is located at the rear of the computer and looks like a large phone jack outlet.
After the Ethernet cable has been connected to the computer. The computer and modem can be powered up. When the system starts it will see that new hardware has been installed and search for drivers. If it cannot find the drivers stored with in it's data base then you should load an software that you received with the modem at that time.
This is all the hardware required for hook-up. To create a network (when multiple computers need to share a single hook-up) the addition of a router may necessary.
FOR SOFTWARE PORTION:
If this is the first time this computer has been used to access the internet it will be necessary to create a new network connection. In Windows XP and Vista this is done by hitting the start button, clicking on the Control Panel, then clicking the Network Setup Wizard. This will lead you through the process of creating a connection step by step.
From here you should be able to open up the internet browser and access the web.
This does not always go this smoothly. In which case you will need to provide more detailed information for trouble shooting the problem.
I hope this helps.
Posted on Sep 28, 2009
How to switch the answering machine from line 1 to line 2 of a two line phone
The answering machine isn't smart enough to know which line it's answering so temporarily swap lines.
Aug 07, 2017 | The Office Equipment & Supplies
Repaired two fuel lines ,removed sending unit from tank, can't remember which lines go where three lines from engine .
Can you identify or remember which pipe on the sending unit, the pump module, is the main outlet from the pump?
The three lines are the main feed or pressure line to the engine, the return line from the engine to the tank-this line is often smaller than the main line. And the third line is not a fuel line, but the vent line for fumes from the enclosed tank to the charcoal canister. This line may be identifiable by pipe diameter being smaller, or sometimes using rubber hoses with it, or maybe just a little offstanding from the other two lines. The main line (pressure line) will be the line that has the fuel filter in it. You can identify the main line this way, then just figure out where it connects onto the tank, and sort out the other two lines-the return line and the (?smaller?) vent line.
May 08, 2017 | Cars & Trucks
What are the subsets of a line
A ray is a subset of a line which has one endpoint and extends only in one direction. The segment is the subsets of a line that have 2 endpoints.
Each point on the line, any set of point, sets of points and line segments, of points and rays etc are also subsets.
Subsets Defined
  • Subsets are an important part of mathematics in general, but they are especially important to geometry. In mathematics, a subset is a piece of something larger. For example, a piece of pie is a subset of the entire pie. Geometry deals specifically with shapes, making subsets an important idea to the field. Mathematicians use subsets to simplify complex problems by investigating the smaller parts of the problem one by one and connecting the pieces to determine a solution.
Subset of Rays
  • A ray is a part of a line that starts at one point and extends infinitely in a set direction. A ray is different from a line because it has a starting point or origin, and extends infinitely from there. In contrast, a line extends infinitely in two opposite directions. So a ray that starts on a line and continues in one direction on the line is a subset of the line.
Subset of Line Segments
  • A line segment begins at one point and ends at another. They are important because they make the mathematics of lines more manageable. Unlike a ray or a line, line segments are finite; they do not stretch to infinity in either direction. Line segments that share the starting
    Line segments are small pieces of a larger line.
  • point, ending point and all points in the middle with a given line make up a subset of that line.
Jun 10, 2011 | Computers & Internet
What is city area code of doha qatar
hello;
select your place codes with sub codes: 974284250 9741121127 XES Emergency Services 974124522094 XVM Voice Mail & SMS 97421738223 PAG Paging 9742244520 PAG Paging 974286 Fix Line MATS 9744137128 Fix Line MATS 9744289375 Fix Line MATS 9744341613 Fix Line MATS 97443041613 Fix Line Doha Central (DC3) 97443141613 Fix Line Doha Central (DC1) 97443241613 Fix Line Doha Central (DC2) 97443341613 Fix Line Doha Central (DC1) 97443441613 Fix Line Doha Central (DC2) 97443541613 Fix Line Doha Central (DC3) 97443641613 Fix Line Doha Central (DC2) 97443741613 Fix Line Doha Central (DC3) 97443841613 Fix Line Doha Central (DC3) 97444563138 Fix Line MATS 974440563138 Fix Line Doha Central (DC3) 974441563138 Fix Line Doha Central (DC1) 974442563138 Fix Line Doha Central (DC2) 974443563138 Fix Line Doha Central (DC1) 9744431599563138 Fix Line PSTN Testnummer 9744432599563138 Fix Line PSTN Testnummer 974444563138 Fix Line Doha Central (DC2) 974445563138 Fix Line Doha Central (DC1) 974446563138 Fix Line Industrial (IEC) 974447563138 Fix Line Doha Central (DC2) 974449563138 Fix Line Doha Central (DC1) 9744546098 Fix Line MATS 97446196683 Fix Line MATS 974460196683 Fix Line Industrial (IEC) 974461196683 Fix Line Industrial (IEC) 974462196683 Fix Line Airport (APC) 974463196683 Fix Line Rayyan (RYC) 974464196683 Fix Line Wakrah (WKSC) 974465196683 Fix Line Airport (APC) 974466196683 Fix Line Airport (APC) 974467196683 Fix Line Airport (APC) 974468196683 Fix Line Industrial (IEC) 974469196683 Fix Line Industrial (IEC) 97447252915 Fix Line MATS 974471252915 Fix Line Rayyan (RYC) 974472252915 Fix Line Khuratiyat (KRC) 974473252915 Fix Line Doha Central (DC3) 974474252915 Fix Line Doha Central (DC1) 974475252915 Fix Line West Bay (WBC) 974477252915 Fix Line Wakrah (WKSC) 974478252915 Fix Line Khuratiyat (KRC) 974479252915 Fix Line Khuratiyat (KRC) 974482826 Fix Line MATS 9744802826 Fix Line Rayyan (RYC) 9744812826 Fix Line Rayyan (RYC) 9744822826 Fix Line Rayyan (RYC) 9744832826 Fix Line West Bay (WBC) 9744852826 Fix Line Doha Central (DC1) 9744862826 Fix Line Khalifa Town (KTC) 9744872826 Fix Line Khalifa Town (KTC) 9744882826 Fix Line Khalifa Town (KTC) 9744892826 Fix Line Khalifa Town (KTC) 9744955072 Fix Line MATS 974507311 Mobile Mobile GSM 9745211796 Mobile Mobile GSM 97453192116 Mobile Mobile GSM 9745416281 Mobile Mobile GSM 97455548189 Mobile Mobile GSM 9745620766 Mobile Mobile GSM 9745825251 Mobile Mobile GSM 974593 Fix Line Fixed Telephone Cellular 97459383 Mobile Mobile GSM 97459393 Mobile Mobile GSM 97490097012 XAT Audio text Services
Feb 21, 2011 | Computers & Internet
Dial has 350 line, line, line, 450 Which line is 400
if it says 350 line line line 450 it would seem appropriate that the center line id 400,the one to the left 375 and the one to the right 425...right???
Jul 15, 2009 | GE Profile 30" Self-Cleaning Freestanding...
Ryobi 725R weedeater
First unscrew the bump line leter outer. Then remove the yellow line holder, you will see 2 line grooves for each of 2 lines you will wind into the spool. You will see an inlet area at each of the 2 line holders, you will take about 8-10 feet of line and thread the line into the the groove inlet it will poke out the top of the spool. You will see 2 small holes on the top of the spool, feed just the tip of the line into the hole and pull the line tight on the groove side. Do this on both grooves on the spool, once the line is secure, fish each line into the holes on the spool head and secure with the bump spool leter outer. After spool is secure take the entire spool and wind back into the spool head. you will see the line wind into the spool. make sure you wind the right direction. Once you have seen how this is done, look at the bottom of your assembled spool and you will see 2 arrows. If you have no line in the spool, line up the arrows and take 8-10 feet of line and feed as you did when you have the spool removed. The line should feed through the spool and the line will stick up from the bottom, turn the line and feed just the tip of the line into the retainer hole and pull tight from the spool let-out, once secure wind line back into the spool. Once you have done this once its very easy to do over and over!!!
Jul 21, 2008 | Electrical Supplies
Fuel line leak on 1994 toyota camry
stell line front to back you can put high pressure rubber line but mush more expensivedont remove the old one tie rap the new line to the old line if you remove thr line sometime other start to leak brake line are very close if gas line rusty brake line are rusty too hope it help fixya our post thanks pierre
Jul 16, 2008 | Toyota Camry Cars & Trucks
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
