Question about Harman Kardon AVR 320 Receiver
Subwoofer can't get my powered sub to work, the sub works the HK doesn't seem to be giving it anything. It worked before but when we unplugged it to move it can't get it to work again. Seems like it took a lot the first time.
  • 39 Answers
First isolate trouble by giving audio signal to your power sub. by your finger.you know when we put our finger on input signal the noice is amplified and you can listen sound.if nothing is noticed on sub that menas sub has problem.
Posted on Dec 18, 2007
Aperion bravus 10d subwoofer no sound
The amp inside the sub has failed. Basically a sub is a mono power amp with a speaker. Though it seems to be getting power it could be that the main semiconductor that does all the work has gone open circuit. If it went short-circuit it would have killed the fuse and power.
Nov 20, 2017 | Aperion Audio Players & Recorders
MX6050D Subwoofer Issues
Hello, welcome to Fixya!
Fault is either from the main system or the sub-woofer itself.
You need to test both unit in order to detect which of the two is giving the fault, so that you can concentrate on the faulty unit.
Test the woofer with a AA battery or any other battery. Put your ears close to the woofer and observe if you will hear any sound. If the woofer makes sound, then it means the woofer is working, but if it doesn't make sound, then it means the woofer is defective. Or you can disconnect one of the working speakers and connect the woofer to that part. If there is no sound, then obviously, the woofer is defective.
If the woofer seem to be working, then the unit needs to be tested also.
Connect one of the working speakers to the sub-woofer's section of the main unit. If the speaker doesn't bring out sound, check the system's menu settings, check the volume and make sure the sub-woofer volume is raised to the highest level and not on mute. ( Note that most Theater systems has separate volumes for each speakers). If the volume is raised to the highest level and there is still not sound from the woofer part, then it means the woofer channel has burnt. It could be a fuse or a defective channel. At this point, I think you need help from a repairman.
I hope the above is clear.
Regards.
Nov 17, 2011 | Audio Players & Recorders
I have a 12 inch rockford fosgate subwoofer. It just completely stopped working. cosmetically, there is nothing wrong with it to the ***** eye. My amp works just fine, but the sub doesn't do...
First, switch channels to make sure it's the sub. Check to make sure the tensil leads that go from the + and - posts to the voice coil have not come loose. If that's not the case, the voice coil may have failed.
Aug 31, 2011 | Rockford Fosgate Car Audio & Video
I have a 705 receiver hooked up with HK speakers.
'the best way' is highly subjective.
if you are testing with a 'real' 5.1 or 7.1 source such as a dvd or bd there should be signal getting to the sub, depending on the source content (play a scene with explosions or something). if this is the case and you are not getting signal check all connections. is the sub powered or passive? if powered is it on? maybe try turning down or disconnecting other speakers so you can tell for sure if the sub is making any sound?
if you are using 2 channel playback like a standard cd or an input from an mp3 type player then the sub may not be in use depending on the receiver setup - in order to get 2 channel info to more than 2 channels - 2.1 or 3.1 or 4 or 4.1 or 5.1 etc - the receiver has to do some processing such as "pro logic" to interpolate the 2 channel info to the extra speakers.. you may experiment with these 'enhanced' settings..
Dec 24, 2009 | Onkyo TX-SR705 Receiver
Popping harman kardon subwoofer
Mine did the same thing all of a sudden. The problem is a AC mains detection circuit that seems to affect many previous HK sub models. The solution that worked for me was to replace capacitor C112 on the main pcb of the subwoofer amplifier. You need to remove it from the circuit board with a soldering gun and replace it with a higher rated capacitor. I used a 2u2 40v and the subwoofer is working perfectly again! :)
Dec 23, 2009 | Harman Kardon HKTS 12 System
Confused with answer....
I recomment you ask this question from the expert named ginko. thanks.
give me a fixya rateing anyways thanks :)
Apr 06, 2008 | Bose Acoustimass 15 System
Sub Woofer Won't Work
Connect the input from the powered subwoofer to the rca jack on the VSX-409D labelled 'sub woofer preout'.
Dec 24, 2007 | Pioneer VSX-D409
Harman Kardon AVR 320 Receiver Logo
158 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
