Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
1995 Chevy K1500 Z71,Engine L05 5.7L,starts cold fine,runs great,but after it is warmed up and lets say 30 min drive shut truck off then sits for 20 to 45 mins it wont start,seems like it is flooding out,replaced all injectors,idle control valve works,checked timing,only way to get truck to start is the old school way of starting flooded engine,by holding peddle to the floor then turning over till she fires.then runs fine again.I replaced all sensors and has no O2 sensor,replaced ignition control thing under Cap also.checked temp sensor on side of head also reads .144 ohms at 195 degrees
  • Chevrolet Master
  • 1,057 Answers
Check the ect switch by the thermostat outlet, it looks like a temp sw but it tells the ecm how much fuel to put into the engine at start up when hot and when cold. it may be reading the outside temp incorrectly. Hope this helps .
Posted on Dec 08, 2015
I know it sounds simple minded but change your fuel pump relay on the firewall it is going out.(cost me $150 bucks for a $8 relay)
Posted on Dec 25, 2009
Done an alt. change after doing a tune up truck ran than just shut down now will not start
Truck ' DIY Forums
www.diyforums.net/truck-2418/
My 2003 chevy Silverado V6 truck turns over but will not start..it acts lik. ... iS IT HARD TO REMOVE AN OIL PAN ON A 4.3 VORTEC S-10 PICK UP TRUCK ...silverado 1500 ext. cab. my problem is while driving on the highway my truck ... mytruck then took off the terminal to see if the alternator was work and now i have no .
Chevy Silverado and GMC Sierra Stalling Problem - Car Forums at ...
forums.edmunds.com > GMC > GMC Sierra 1500
Apr 4, 2008 - 30 posts - ‎22 authors
I can feel the truck hesitate or bump while changing lanes on the highway (70-80 MPH) if it ... Now it idles ... My truck has a 4.3 with automatic. trucks runs great after about a hour it .... It will idle and drive just fine, but will simply shut down. ... the not firing problem, but shuts off after it finally decides to start. Chevy Silverado and GMC Sierra Gasoline Engine ...
Jun 14, 2010
Chevy Blazer Fuel Pump and Pressure Regulator Problems
Mar 10, 2010
Chevy S10 - GMC S15 and Sonoma Stalling/Dying ...
Dec 14, 2007
Silverado starting problem...
Nov 15, 2007
More results from forums.edmunds.com
Dec 26, 2015 | 2004 Chevrolet Chevrolet Silverado 1500...
I have a 1995 chevy k1500 idle is smooth. If you keep it under half throttle it is good you go over half it loose power and if you floor it the tac goes to about 3500 rpm and just sits there and start...
Is it setting any codes? (some 95's had OBD1 I think). Check vacuum and mechanical advance in distributor, and possible bad ignition module but they don't usually act quite like this. I'm betting bad distributor mechanical advance.
Dec 19, 2014 | 1995 Chevrolet K1500
2000 tundra v6 5-speed cold start truck runs great, park it for 20-30 min it will start fine but after going 1/4 mile it dies, looses power. pull over and it will backfire and sputter until it eventua
bad need of a tuneup? like new spark plugs, ?
172 , is 02 rich/ lean warning. this one is low oxy for rich.
this code can just be a victim. for sure , with misfire.
means 02 sensor stuck at rich,
what is water temp in engine coolant, at failure? less than 150F?
could be lots of things.
leaking injectors, bad fuel.
injector sticking> causing misfire.
id use a scan tool and watch all sensor when it fails.
too high fuel pressure.
misfires cold, but only luke warm cold starts not fully cold.
just one DTC, no P0300 or 30x misfire codes, not even P0300 pendings?
Jan 31, 2014 | 2000 Toyota Tundra
Wont start warm
CHECK OIL TO GAS MIX COULD BE BURNING TO MUCH GAS. IF NOT CHECK ALTERNATOR STATOR MAGNITO WHICH EVER ONE YOU GOT.
Jun 30, 2013 | 2007 Harley Davidson FLHTC Electra Glide...
Bike leaves me stranded after 15 mins
Check your ignition coils. Sometimes they fail with an open circuit, this can sometimes close up when the machine is cold and open again when it heats up. So. it will start when cold and fail when it warms up.
Apr 24, 2013 | 1982 Yamaha XJ 650
1996 mercedes c280 dies when put in drive
Engine stalls or RPM fluctuates at idle up and down or dies near idle.
This problem is commonly caused by a dirty automatic idle speed control valve and throttle valve but always run a OBD2 fault code as well as the cleaning procedure. Buy a can of throttle valve cleaner (do not use carburetor spray cleaner!) from NAPA or Carquest (made by CRC chemicals) and spray it into the air intake while the engine is running, use up about 1/2 the can, engine will try to stall hold the speed up, shut it down and let it soak for 30 minutes, restart and blow out the remaining fluid, shut it down and disconnect the negative battery cable for 5 Min's to reset the base idle control
Oct 15, 2012 | 1996 Mercedes-Benz C-Class
2002 Chevy Impala wont start after letting sit after it warms up
Almost sound's like vapor lock , the fuel boils in the fuel injector rail , turns to vapor ! That was a common problem with carburetors , letting the vehicle hot soak after shutting down the vehicle an letting it sit for 10- 15 mins. The fuel would boil away ! Are the cooling fans working ? After turning off a hot engine the cooling fans can run on without the key being on , do you hear fans run ? What engine does your impala have ? 3.4 or 3.8 L . Has the check engine light come on ? The fuel pressure regulator could be leaking fuel . Pull the vacuum hose off the regulator after shut off the vehicle , is there fuel coming out of the regulator ? Dribbling out the end of the hose ? This could be bleeding the fuel from the fuel rail ! Good luck , hope i've given you something's to check that you haven't already .
Mar 29, 2017 | Cars & Trucks
My 1997 Chevy c1500 5.0L misses very bad with loud poping noise coming from underneath truck. This happens only after I drive for about 30 min. And turn off truck and restart. After I start it back up it...
Test that the temperature sending unit in the water system is working properly. When the engine is cold, the computer puts it in cold start mode. Once warmed the temp sensor tells the computer to stop sending excess fuel to the engine and taking the cold start mode to off position. If the sensor is faulty, it stays in cold start mode and keeps dumping excess fuel into the engine causing your situation. Like your running with the choke on after warm-up.
Nov 11, 2017 | 1997 Chevrolet K1500
I own a 1999 chevy silverado z71 4x4....just moved to north dakota....the truck sits outside, started every day runs for 20-30 minutes, however no longer (last 2 weeks) goes forward....reverse is...
maybe cold got a vavle stuck in the vavle body maybe will come unstuck if dont have to go into it .is it a 700r-4 trans.??if is check detent cable maybe out of ajustment .
Dec 26, 2010 | Chevrolet Silverado 1500 Cars & Trucks
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
1,296 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
