Question about HP OfficeJet 6110 All-In-One InkJet Printer
When i press the scan butten on my printer it says options not set?
  • 855 Answers
You need to go to your setup and follow the prompts to setup scaner. The printer may be setup but that doesn't set the scanner up. Do that and it should work fine.
Posted on Sep 27, 2009
Reset mp390
1. Press ON, ADDITIONAL FUNCTIONS, SCAN, COPY, SCAN
This will enter into Service Mode
2. Select Test Mode, last selection, use + button then press SET
3. Select #8 Printer Test, use + button then press SET
Printer will start and stop
4. LCD will shown 8-2, press + to move to 8-3, press SET
5. LCD will shown EEPROM CLEAR
Select Ink Count option 0 and press SET
6. Press STOP/RESET
7. Press ON
Dec 31, 2013 | Office Equipment & Supplies
I have a Alcatel one touch 232a and my 8 year old tried to set the pass words and now I get any calls out. Can u reset this from your office or talk me through how to do it. Thanks Genia Melton.
To do hard reset press
*+# and power butten same time
than phone will show you format menu after
then press option butten phone will be done.
Sep 15, 2013 | Cell Phones
I want to Scan a page on Lexmark X6150. Please guide me how to set the Options and Select buttons. I pressed the start button after pressing the scan button. It does do anything.
Find the "menu" button on your printers keypad and push it. Use the up and down areas on the printers keypad to advance from choice to choice. Find the option that says something similar to "scan settings" . Push the "ok" button or the "enter" button on your printers keypad to open this option. Continue scrolling with the up and down arrows and using the ok or enter keys on your printer and locate the "scan to" choices. Set up your software choice for scanning text documents and pictures. Most people want to open and edit text documents in software like "Microsoft Office" in your computer. Choose a photo editing software installed in your computer to send pictures scanned on your printer to. When these settings are set and saved, turn on both the computer and printer and try scanning from printer to computer again to check and see if the problem is solved. If you experience any other issues, pleas clarify what they are and I will try and help you solve this right now before I leave for work.
Sep 27, 2010 | Lexmark X6150 All-In-One InkJet Printer
J4580 OfficeJet All In One Printer Laser: the printers scanner is not working and when i pre...
Just check that can you scan from HP Solution Center, if yes. Then perform the steps given below to resolve the issue.
Open HP solution center:
CLick on settings:
select scan settings from settings.:
A Menu Appears.
select scan to setup:
a new page will appear:
you will see all options on the left side:
select all the options manually and click on the right arrow
to move all the options from left to right side.
after perfoming these steps.
Restart the printer:
and try scanning from printer now.
now will be able to scan from printer itself.
May 18, 2010 | HP OfficeJet J4580 All-In-One Laser...
When I press the scan button on my hp officejet it says options not set. How do I set the options??
If you have solution center installed
then open the Solution Center
Go to settings--- scan settings - scan button settings- Front panel scan button settings
configure the same over there and it will start working fine
Oct 16, 2009 | HP OfficeJet V40 All-In-One InkJet Printer
I am unable to send faxes or recieve faxes
Please follow the steps given below to check wheather the error correction is turned off.
You need to disable "Error Correction," please follow the steps given below:
1. Press "Fax Mode."
2. Press "Menu."
3. Press "Up" or "Down" Arrow button repeatedly until "Ringing and Answering" is highlighted.
4. Press "Select."
5. Press "Up" or "Down" Arrow button repeatedly "Error Correction" is highlighted.
6. Press "Right arrow" or "Left arrow" button until "OFF" appears.
7. Press "Select."
Please follow the steps given below to recieve the fax:
1. From the control panel, press "Fax Mode."
2. Press the "Menu" button once.
3. Press up or down arrow repeatedly until "Ringing and Answering" is highlighted.
4. Press "Select."
5. Press up or down arrow repeatedly until "Pick-Up On:" is highlighted.
6. Press left or right arrow to choose an option.
7. Press "Select."
If you want to set a schedule to turn "Auto Answer" "on" or "off:"
1. Press up or down arrow repeatedly until Auto Answer Scheduling is highlighted.
2. Press left or right arrow until "On" appears.
3. Press "Select."
4. Press down arrow button to select the time for "Auto Answer On."
5. Use the keypad to enter the date and time. Press 1 for AM, 2 for PM, or 3 for 24-hour mode.
6. Press down arrow button to select the time for "Auto Answer Off."
7. Repeat step 5.
8. Press "Return" button to save the settings and exit the menu.
9. Make sure the "Fax Auto Answer" light is on.
When the number of rings you set is detected, the printer automatically receives the incoming fax.
To scan a document, please follow the steps given below:
1. Go to "Start," "Programs," Lexmark printer, "Lexmark All-in-One Center."
To see how an image will look after it is scanned, click "Preview Now."
2. Click "Scan," "Send scanned image to."
If scanning an image, choose a graphics program such as "Lexmark Photo Editor," "MS Paint," etc.
If you wish to "Scan to OCR," choose a text program such as "MS Word," "WordPad," etc.
Once the image is scanned, the "Abbyy OCR" software will open automatically.
3. To begin the scanning process, click "Scan Now."
4. To view the additional options, click "See More Scan Settings."
To indicate what type of image is being scanned, select the "Option" next to the type of object you are scanning. Your settings will be optimized for that object type.
To indicate how the scan will be used, select the relevant option from the menu. Your resolution and other settings will be optimized based on your selection.
5. To revert back to the normal All-in-One main page, click "Hide Extra Scan Settings."
6. Under "Display Advanced Scan Settings"; you can see change settings, which will affect the outcome of your scan.
Mar 21, 2009 | Lexmark X8350 Print, Scan, Copy and Fax...
Scanning a document
i would like to know if you did completely install the printer software of this printer.if you did kindly locate the icon HP SOLUTION center,go to settings>>scan setting>>san to set-up>>restore to defaults.kindly check now if the front panel destination list has generated the options then click apply and OKAY.try to press now the scan button of the printer is the scan options are generated...
send feedback for further troubleshooting solution..
Aug 31, 2008 | HP Photosmart C6280 Printer
Hp printer scanning prblm
Are you able to make copies only (just press copy color or copy balck and check)
And are you able to scan pictures.
If yes then make sure you are scanning from HP Director as Scan documents and follow the on screen direction.
If you do not get the option to scan documents then in HP Director go to> Settings> Scan Documents settings> You will see a option saying promt for these setting at the time of Scan> Put a check mark on that and click on Apply and ok and then try scanning document.
If this does not work the go to Start> Control panel (or Start> Settings> Control panel> Then printer and other hardware or Scanners and cameras> then Right click on the Printer icon> and scan from the options there.
Good Luck
Aug 22, 2008 | HP PSC 1315 All-In-One InkJet Printer
Won't scan legal documents properly
Make sure that you set the paper size in the setup menu for legal - 8.5 x 14 for the manual paper feed.
Jul 01, 2008 | Samsung CLX 3160fn All-In-One Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
49 people viewed this question
Seeker5211
Seeker5211
