Question about Sanyo Computers & Internet
Sanyo avm2508g tv. 14yrs old. cant get dvd hooked up to play. doesnt seem to have tv/video button have tried hooking up thru cable box, no luck. have tried hooking up direct, no luck.
  • rdvanross Sep 28, 2009
    no. reg rca plug-ins.
  • Ian White
    Ian White May 11, 2010
    Are you connected via Scart (21 Pin)?
bmwrider
  • 215 Answers
SOURCE: Hooking up external DVD player
If you only have the one Audio/Video or AV input then pop into a TV store and buy a cheap AV switch. Plug your Dish Box into one set of inputs and your DVD into the other. Then run another lead from the switch box to the TVs AV inputs. That way all you do is match the switch to whatever it is you want to watch. If your TV does have two AV inputs just run each unit to a set of inputs and change the TV to AV1 or AV2 depending on which you want to watch and which unit is connected to which AV input. I hope you understood that :-) BMW
Posted on May 27, 2006
SOURCE: DVD Plays in Black and White
Depending what cables you have, try plugging only the yellow cable into "video out", I previously had red, white, and yellow cables plugged into "comopents out" and only got black and white. Doing only the yellow into video out gave me color.
Posted on Apr 07, 2008
welcomejee
  • 10594 Answers
SOURCE: sony str-dg820. having a problem getting video on tv
Hook up Composite / Component Monitor Out wire from receiver to TV video input because receiver will not change analog input into HDMI
You need to connect receiver and TV through analog video terminals as above.
Actually you are expecting that receiver will convert DVD player and Xbox analog video input into digital HDMI signal for TV and This is incorrect.
Posted on Jan 04, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: Problem hooking up DVD player to TV thru my cable box
Chances are you've got your DVD player hooked to OUPUT jacks on the cable box, not inputs. I haven't yet seen a box that takes any kind of an input other than the cable line, but they will have RCA jacks for audio and video outputs on the back. So your cable channels are fine, but the DVD signal is hitting a dead end.
The only solution if your TV doesn't have RCA inputs for video and audio is to get an RF converter (around $10-$20). This takes the A/V signals from your DVD and turns them into a channel 3 or 4 signal that connects to your TV's antenna input.
The converter also has a connector on the back for the cable coming from the cable box, since you'll have to disconnect that from the TV. When the DVD player is off, the cable box signal gets passed to the TV as normal. Turn on the DVD player and the RF converter switches on; put your set on channel 3 or 4 and you'll see your video.
One final thing: The converter will need an AC outlet for its power adapter or power cord, so make sure you have a spare. If you don't already have your TV and DVD player connected to one, this would be a good time to pick up a surge-protector outlet strip. Then not only will you have enough outlets, you'll be protecting your equipment as well.
If this solution has given you what you need, please take a moment to rate it appropriately. And thanks for asking here!
Posted on Mar 01, 2009
Testimonial: "Thank you. I forgot to thank you when I first read this response. Works fine now though :)"
bluecrash
  • 106 Answers
SOURCE: can i hook up my ps3 thru the cable box? i have an
are you using the HDMI? If you are, the HDMI cable can carry both audio and video signals on it. But, you have to change the settings in your cable menu, and in your tv to detect audio from it.
Posted on Jun 25, 2009
The converter box is hooked On the TV and working. I have the TV with the rabbit ears and only video n audio in the front (yellow n white). I recently purchase a DVD player n I am trying to hook it on the...
you have to change the input on the tv to AV. there should be an input button on the remote, but if your remote doesnt work you might not be able to change the input. you can try to use the channel up and down on the tv and once you get to the end of the numbers, some tvs will change inputs before restarting the number list. make sure you hook the yellow cable to the yellow plugs on the dvd and the tv and either of the red or white ones to the white one on the tv. red and white are left and right audio and the yellow one is the video
Dec 24, 2010 | Insignia Digital-to-Analog Converter for...
What channel does it need to be on to play a dvd player I have the converter box
Ur tv have a video input holes R,Y,W.?Use the RCA cable R,Y,W to hook up to play the DVD player.Use the tv video 1 input to watch dvd movie.
May 27, 2010 | Sanyo DS25390 TV
Can we record with our sanyo drw 500 and a digital tv? If so, how do we do this?
If cable/SAT box, hook-up that box video/sound output to DVD video/sound input. If no cable/SAT box, hook-up cable from wall into antenna/cable in on DVD and tune DVD to channel wished, and hook-up DVD TV antenna out to TV antenna in. If DVD has no antenna/cable in, TV must have video/sound output. Hook to DVD video/sound input. Hope this helps.
Apr 18, 2010 | Sanyo DRW-500 DVD Recorder
Trying to hook up magnavoc Dv220mw9 to my cable box & tv
Sorry, looks like it didn't load right with that last solution. Let me try again....
CONNECTING VCR
If this doesn't get it let me know I will try to walk you through it further.
Good Luck....
Jan 13, 2010 | Philips Magnavox DVD/VCR Dual Player
I am trying to hook up my dvd player to my sanyo tv
I have red, blue and green cables when I hook them up to the back to the Sanjo TV I can't get the Audio to work. She has basic cable with no cable box just a converter box that give her reception. Should I put the blue and red cable on Pr and Pb and take the green cable and put it into the video out?
Nov 03, 2009 | Sanyo DS19310 19" TV
Cant switch tv to play my dvd player. no button on menu for this
If the tv remote has a input control button(video/antenna), you should be able to play your dvd thru this .
Apr 29, 2009 | Televison & Video
Can't get new DVD player to play
On some sets there is a button on your remote marked "TV/VIDEO" or some such text. With your tv and player hooked up and working, pushing that button will switch from TV to video and back.
On other sets, if you keep changing channels, you will eventually come to one that turns off the video broadcast and plays the DV.
Good Luck
Mar 13, 2009 | Sanyo Televison & Video
Hook-up
first you do connect cable to your > combo VCR / DVD player & recorder then connect to > to your TV:
cable coax output or if that cable have video/audio ouput is going to INPUT >to combo VCR / DVD player video / audio output is going to INPUT > to TV,.that's the time you can record and playback;
click below for more information in hooking up:
DVD Players/Recorders: Home Theater Setup, Installation & Hook Up ...If i have helped,please click fixya,it is the only way i get paid for my work ,also please consider leaving feedback...
Good luck ,and Thank you in advance:
Jul 15, 2008 | Televison & Video
TV (Model DS27510) is stuck on Video2 setting, unable to change!!
Ours is doing the same thing except on Video 1. I called Sanyo customer service and they said I need the original remote. They were willing to sell me one for $20. Here is what I did instead. I used a cable box and hooked the cable in to it. Then I took the type of cables that will hook into my video 1 slot and plugged them in there and plugged them into the back of the cable box in the "cable out" positions. It worked ! If you do not have a cable box you might try a DVD/VCR combo or a VCR. Good Luck
Sep 16, 2007 | Sanyo DS27510 27" TV
Computers & Internet Logo
47 people viewed this question
Top Sanyo Computers & Internet Experts
kj henriksen
kj henriksen
William Alequin
Are you a Sanyo Computer and Internet Expert? Answer questions, earn points and help others
