Question about Dishwashers
I have a Whirlpool Dishwasher model number DU8400XB-1 it has leaked at the bottom left side for a while and now all the way across. I removed the inside of the door and saw that the splatter shield had come loose. I put it make in place but still have leaking. any advice
    Scholar:
  • 61 Answers
Drum maybe the problem
Posted on Sep 27, 2009
How-to I replace facing on older whirlpool dishwasher
  • 1. Place your hands at each end of the retainer trim piece that runs along the bottom of the dishwasher door panel. The piece may be metal, black plastic or another color, depending on your dishwasher model. Lift up on the retainer section and pull it toward you to remove it. Set the retainer aside.
  • 2. Press the palms of both hands on the old facing and slide it down until the top is free. The facing flexes easily to allow you to slip it out from under the trim along each side.
  • 3. Hold the replacement door panel, or reverse the old one, so that the desired color is facing you. Turn the panel, if needed, so the dimensions line up with the dishwasher door.
  • 4. Slip the side of the facing into the left side of the frame on the dishwasher door.
  • 5. Secure the other side of the facing into the right side of the dishwasher frame by bowing the panel gently and sliding it into the frame.
  • 6. Slide the new facing up and into place so you can reposition the retainer.
  • 7.Hold the new color panel and the spacer behind it up over the lower edge of the frame about 1/4 inch.
    8. Snap the retainer into place. Push down on the horizontal piece gently to ensure it is securely connected.
  • 9. Adjust the new panel down a bit with the palms of your hands to cover the 1/4-inch space.
Oct 19, 2014 | Whirlpool Dishwashers
Newly installed. From day one, front door seal leaks slightly. Mostly on the upper left side of door. With door latched, I can still push door in another 1/4". I can not find any adjustment on the...
Most likely the dishwasher is not properly levelled. You will need to adjust the springs at the base to ensure balance on the door is maintained. One side of the door is probably getting pulled more than the other.
Refer page 14 in this manual. if you cannot open the link then got the whilrpool site and select Manuals page and type the model number and go down to the installation manual.
Hope this helps.
Oct 18, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool dishwasher du915PWP leaking
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
hk
Nov 07, 2009 | Whirlpool 24 in. DU915PWP Built-in...
My whirlpool dishwasher is leaking water from the bottom of door
Water is being forced out under the bottom door seal. Is the lower spray arm melted on the bottom? Or is there something directing the water flow toward the bottom of the tub instead of up toward the dishes?
Sep 03, 2009 | Whirlpool 24 in. GU3200XTP Built-in...
Dishwasher leaks water as it fills
  • Step 1 Remove the front access panel (see step 1, "Tightening the fittings"). This will give you access to the dishwasher's adjustable feet.
  • Step 2 Open the door completely and remove the bottom dish rack.
  • Step 3 Unscrew the dishwasher from the kitchen countertop so the dishwasher can move freely as you adjust the feet.
  • Step 4 Check to see if the dishwasher is level side to side. Place a small level inside the dishwasher so it's sitting on the bottom pan and facing parallel to the front lip of the dishwasher. If the dishwasher is not level, use adjustable pliers to turn one of the dishwasher's front feet up or down until you hit level.
  • Step 5 Check to see if the dishwasher is level front to back. Turn the level perpendicular to the door, and place it on one of the bottom ledges that run along the side of the cabinet. Check the level again. If the dishwasher isn't level, use your adjustable pliers to turn the back feet up or down until you hit level.
  • Step 6 Reattach the dishwasher to the countertop and reinstall the front access panel.
    Fixing a leaking door
  • Step 1 Inspect the door gasket. As it ages, the gasket can crack or become hard, preventing it from sealing completely.
  • Step 2 If the gasket appears solid, adjust the door latch so the door seals tightly. Loosen the screw that holds the door latch to the cabinet. Push the latch in slightly and retighten the screw. Test the door and readjust the latch if necessary.
  • Step 3 Replace the gasket if water continues to leak after you've tightened the latch. Most gaskets are held by compression in a groove on the door or on the dishwasher cabinet.
  • Step 4 Pull the old gasket out of its groove, using adjustable pliers (see illustration). Take the gasket to an appliance store to get a replacement.
  • Step 5 Soak the new gasket in warm water to soften it, then press it into the groove. Start at the top, then work your way down the sides and across the bottom.
  • May 14, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
    Whirlpool dishwasher leaks everywhere
    CHECK YOUR HOSES FOR CRACKS. BE SURE THEY ARE ATTACHED SECURELY TO THE PUMP OULET.
    THERE IS ALSO A BLACK HOSE FROM THE VALVE THAT GOES UP THE LEFT SIDE TO A VACUUM BREAK ON THE SIDE OF THE TUB. BE SURE THE HOSE HASN'T BEEN DAMAGED OR DISCONNECTED. IF THERE IS SUFFICIENT SUPPLY HOSE, PULL THE DISHWASHER OUT OF IT'S INSTALLATION AND TURN IT ON. WATCH FOR WATER DRIPPING ON THE FLOOR AND TRACE IT BACK TO FIND THE PROBLEM.
    Mar 25, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
    Whirlpool adg 7560
    on must hirlpool the top console has control on front upper side,,if so you must remove console and bottom panel,,because your panel will be thicker you must get 1 inch counter screws remove diswasher orginal panel than add you bottom,,,,if it dishwasher that has control bottons on top side of doorplace panel over hold door the remove 4 inner panel screws and replace with 1 and a half in screws ,and mount straight through
    Mar 22, 2008 | Whirlpool 24 in. ADG7540 Built-in...
    LG Dishwasher
    according to the manual that i have just downloaded from the net,E1 code means.water leakage in Hose connections.
    .water is leaked by damages
    hope this helps,
    keith
    Sep 20, 2007 | Dishwashers
    Whirlpool built in dishwasher. not aware of model number
    Putting vinegar in the bottom of the dishwasher is not going to help because it has nothing to do with the FILL cycle. The bottom (or sump) actually is used during the WASH and DRAIN cycles. I would check the fill port where the water inlet hose goes into the side of the wash tub. You will need to pull the unit out and locate the inlet hose on the SIDE of the dishwasher. The hose should be a black rubber hose located on the left-hand side of the machine. I had a very similar problem that turned out to be calcium deposits clogging the fill port BEFORE it got to the fill valve. With the unit turned off, I removed the rubber hose and used a small screwdriver to poke straight down into the fill port and break up a bunch of calcium. The unit worked fine after that. It is normal for some dishwasher models to drain if they do not detect enough fill water, or if they detect a leak. Usually when the fill port becomes restricted or clogged you will find puddles of water forming under the dishwasher. You might want to remove the bottom panel and check for leaks as well (if you haven't done so already). If you check the fill port and it is clear, the fill valve could be a possibility as well. However, you mentioned you could hear water running which leads me to believe that you have a simple clog somewhere...but, the valve could have accumulated some deposits as well. Check the fill hose and let me know. Good luck and I hope this helps you. PS Another common mistake people make is to put drain cleaner in their dishwashers. This can damage the pump and chopper assembly. Not to mention, it could be harsh on the some of the rubber seals. Not a good idea.
    Jul 30, 2007 | Whirlpool 24 in. DU1055XTP Built-in...
    Dishwashers Logo
    167 people viewed this question
    Top Dishwashers Experts
