I have a canon pc-25 color printer/copier and i need the plug ins,are they ac adapters.
My canon mp830 do not turn on what maybe the problem can u help please
Plug in another device like a lamp in the power socket to ensure you do have power available on that receptacle.
Make sure the power cord is connected securely.
If the printer does not power on, maybe you need a new power adapter.
Here is one that is available:
http://www.ebay.com/itm/Canon-Pixma-MP830-AC-Adapter-Power-Supply-Adapter-K30263-QK1-2228-/301972155607?hash=item464ef16cd7
Apr 28, 2016 | Canon Office Equipment & Supplies
It will not trurn on does the ac adapter need replacement it is over 10 yrs old
Look at adapter, see what output is supposed to be- maybe 12 volts DC? Find a multimeter that will measure DC voltage, and see if the output plug has that across the connector. If you have an ordinary power cord without an adapter, it will have 120 volts AC like any other cord, which you can also measure on AC scale, but be careful as you can get a dangerous shock, just like you can from an ordinary household outlet.
Note: AC voltage may vary by country.
Apr 09, 2014 | Canon PIXMA iP3000 InkJet Photo Printer
Need to find source to buy canon ip4300 ac power adapter
press canon smarthead button .reports , then print user config page
Feb 19, 2013 | Canon PIXMA Office Equipment & Supplies
My canon i560 printer cable is a 25 pin connector , my HP Pavillion a1630n does not have where to plug the connector in the back. What do I do?
if the 25 pin cable is centronics or paralell you're in trouble scrap the printer. if its a serial cable purchase an 25 to 9 pin serial adapter. your pc should have a 9 pin serial interface.
May 13, 2010 | Canon BubbleJet i560 InkJet Printer
Colorize drawings on Canon Lide 25 scanner?
Open Jpeg in a paint program or photoshop, add color and save as *.jpeg, so you keep the original
May 03, 2009 | Office Equipment & Supplies
Does Anyone know how to test Canon i860 AC Adapter??
Yes I know. put the adapter into the plug and switch on, and put the another side in a glass which contains water, then you can observe water avaporate or not. If water avaporate it is working otherwise it is not working. Just try and send me reply pnbab@hotmail.com
Nov 04, 2006 | Canon i860 InkJet Photo Printer
jasbo
jasbo
