Question about Cameras
Hi I have a I.T.Works DC-6370 Digital cam and have just found out that the flash is not working.Any ideas?
Model 6370. When I choose a pattern stitch, why does it only sew straight in reverse?
Hi Sally,
Looks like the slide block is bound up. Sometimes this is an easy fix for a technician, sometimes there are more problems.
Mar 26, 2016 | Husqvarna Sewing Machines
Why did the ac power quit working on my pr-d7? the dc still works fine.
there is a diode D301 must be opened, replace it should be ok, but have to check your AC adaptor in advance.
Nov 17, 2014 | Sangean PR-D7 Digital Rechargeable AM/FM...
Won't start and getting long beeps. compaq presario 6370
The beeps that you are hearing might indicate that your computer has a bad RAM or memory modules already. Reseating the memory modules might resolve the problem. That means you have to remove then place back the RAM. The full instructions in installing memory modules can be viewed from this LINK and should give you an idea how to remove and place them back. If the problem persists, replace RAM/memory module.
I hope this works for you. Kindly comment for further assistance. Thanks for using Fixya!
Mongkey
"Understanding explains better..."
Feb 14, 2011 | Compaq Presario 6370US (OBDA219A#ABA_1) PC...
Flash on vivicam 3188 doesn't flash
flash does work on your vivitar cam you just have to put it on.
when you want to take a pic with flash on you simply have to press the backwards arrow which has the lihtning flash arrow above it. now the flash should work when you take your picture.
Good Luck
hope it works-it should because i've got the same cam too.
Nov 18, 2008 | Vivitar Pink Vivicam 3188 Camera Great...
Mavica fd92
its DC to DC board is faulty.
Oct 26, 2008 | Sony Mavica MVC-CD350 Digital Camera
I have cam sony dsc-s650 " dark screen "
get a broke one off ebay and use the flash circuit and mainboard from it. or go to www.digitalcamrepair.com for help.
May 05, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Won't turn on
take out the batery and put it again until the led flashes. roberto fraga. argentina
Aug 30, 2007 | BenQ DC C500 Digital Camera
Cameras Logo
56 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
