Question about IBM ThinkPad 570 Notebook
Bios reset for ibm thinkpad 570 - IBM ThinkPad 570 Notebook
    President:
  • 2,600 Answers
If you have forgotten your BIOS or system password, there are no software tricks or magical gimmicks that will get the password cleared. Laptops are different in that they are designed to not work with “backdoors” etc. for security reasons. There is one true way that works most of the time and that is hardware.
The Cmos (RTC) battery that is mounted on the motherboard in most cases holds the key, if your motherboard has the battery that is connected to the motherboard by using a two wire socket that plugs into the MOBO, then here is the procedure.
On the motherboard where the battery plugs into, you will see two pins sticking straight up, these engage the plug on the battery side. These two pins have to be “shorted” and then the motherboard powered up for approx. 30 seconds, then power down the system and replace the Cmos battery and reboot. Your password problem should be cleared up. The best way to “short” the pins is get another cmos battery and cut the wires from the battery part, bare the ends and twist together, this will short the pins. Make sure you tape the connection good on the jumper you just made….don’t want to touch anything else with powered up bare wires. Good luck.
Posted on Sep 27, 2009
4 Suggested Answers
kamal1984
  • 1383 Answers
SOURCE: forget BIOS Password (Laptop - IBM Thinkpad Lenovo R60)
For that you need to reset factory defaults settings for bios.
For reset bios u have to open back side of your laptop then u find motherbord circuit there.
pull cmos cell on motherbord for 15 minute then it reset to defaults.
Also u can reset with jumper settigns read carefully on mother bord there is 1 jumper near cmos cell u read there " bios reset or clear"
It is on 1-2 position right now set it in 2-3 position then power up then all bios settings are reset.
then again set it in 1-2 its original position.
Posted on Jul 29, 2009
SOURCE: bios
none of that basic stuff work on late thinkpad. solution.
flash/replace bios chip
build dongle to read bios chip using xternal monitor
all require an expert or parts and soldering skill
u can get the replacement on ebay about USD14-15 and i show you how but you must be able to solder
could also send you one but would take a little while i'm in jamaica
Posted on Apr 17, 2008
micromend
  • 748 Answers
SOURCE: how do I restore my IBM ThinkPad 570 notebook to
Hi
You'll probably need to take it to a reputable repair person or check my website www.micromend.com. The reason is that a program such as ERD Commander needs to be used to eliminate the password and then to restore the laptop is a 10 cd set with Windows and all the drivers. Good luck
Posted on Jun 03, 2010
How to do a factory reset on IBM Thinkpad 570
I think you have more problems than a factory restore. If the screen is white. But this may help: http://john.ccac.rwth-aachen.de:8000/ftp/mirrors/ps2supersite.homedns.org/pccbbs/mobiles/570usref.pdf ORhttp://www.ehow.com/how_4924378_restore-ibm-computers-factory-settings.html
Dec 07, 2012 | IBM ThinkPad 570 Notebook
My password has been forgotten,how do i unlock my ibm thinkpad 570,type 2644? please help!!
A Windows password reset bootable disk could do all the job for you, it can reset your lost or forgotten Windows password safely and quickly without login, you can create a Windows password reset bootable disk with the tool Windows Password Breaker, then use it to reset your password.
Jan 23, 2011 | IBM ThinkPad 570 2644 Notebook
My ibm thankpad 570 has a bios lock. wont let me in to bios or com.
To reset the BIOS read the information from this link.
In case of your IBM laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Dec 08, 2010 | IBM ThinkPad 570 Notebook
How do I restore my IBM ThinkPad 570 notebook to its original state. It has windows 2000 installed. It had a previous owner and it still asks for their password.
Hi
Jun 03, 2010 | IBM ThinkPad 570 Notebook
I CANT GET MY IBM THINKPAD TO UNLOCK
it depends on what you want to unlock:
for the BIOS, just remove the battery for 24hours then the BIOS will reset / else have the BIOS battery removed for at least 1 hour.
for more information:
http://sodoityourself.com/hacking-ibm-thinkpad-bios-password/
Oct 16, 2009 | IBM ThinkPad T40 2373 Notebook
Forget BIOS Password (Laptop - IBM Thinkpad Lenovo R60)
Jul 29, 2009 | IBM ThinkPad R60 Notebook
I'd like to upgrade the HD of my Thinkpad 570 2644-1AG from 4GB to 10MB or even more. IBM system FRU parts list only shows 6,10 and 12 GB as compatible drives. I have found a 40GB Toshiba IDE drive ,...
It most likely will work, but the BIOS (might be too old) may not allow you to access the full capacity of the hard disk.
You would normally lose approx. 10% of the capacity when you format the hard disk.
Apr 15, 2009 | IBM ThinkPad 570 Notebook
New harddrive
Check the connections and the drive settings (jumpers) to make sure its set to "Master, Stand alone". The IBM PC's autodetect's the HDD installed so if it doesn't read the HDD, there is a hardware problem.
Maybe is the Thinkpad interface faulty and the HDD you replaced is fine.
Feb 19, 2008 | IBM ThinkPad 570 Notebook
Bios password
ibm think pad r40 bios password cracker
Oct 11, 2007 | IBM ThinkPad A21m 2628 Notebook
IBM ThinkPad 570 Notebook Logo
193 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
