Question about LG Televison & Video
Not enough av ports on t.v to connect dvd player and austar
My t.v only has 1 AV port on the back, Austar box plugged into it working fine.
Want to plug sony surround sound dvd player (DAV-S500) in but how? Have component in 1 & 2 ports on back (Blue, green, red) but dvd is about 4years old and choices are video out & video in, red, white, yellow. Can you please tell me what goes where? I have tried every combination the best i can get is sound no picture or blurred picture and crackle. I have dvd player plugged into austar box and the sound is fine on normal t.v and austar.Can you help? I"M Nearly Silly!!! The T.V is a LG HDTV 47LB2DE 119cm flat screen. Michelle.
  • LG Master
  • 3,828 Answers
May need to go to an DIY electronic store and get adaptore extenion boards
LG Support Search Results LG AU
Posted on Apr 10, 2017
  • 52 Answers
SOURCE: hook up vcr
Unhook the dvd cables from the AV1 ports on the tv. Then hook these DVD outputs to the inputs on the vcr. Then hook the vcr outputs to the tv inputs (AV1). The tv and the vcr must then be set to channel 3 in order to watch the dvd (and possibly also some menu settings such as setting everything to "component video" and/or setting the tv/vcr button to "vcr. Also set all "3 or 4" switches on the back of all equipment to channel 3. Also, don't forget to go into your tv menu and choose AV1 when you want to watch the dvd and/or the vcr.
You can also try connecting your dish to the vcr and then the vcr to the input on the tv where you HAD the dish connected. There are several combinations you can try, but just remember to always put output cables to the INPUTS of the next piece of equipment in line, and set your menu settings appropriately on all equipment whenever you change from one machine to the next.
If all this fails, then here is a 100% positive solution. Buy an "A/B" switch. It has two inputs and only one output. You could leave the dvd connected as is and connect the dish and the vcr to the two inputs on the A/B switch. Then hook the one output of the A/B switch to the tv. When you change the position of the A/B switch back and forth, you will be changing over back and forth from dvd to vcr. You can move the A/B input selection switch manually or you can buy a remote controlled A/B switch and do your switching with the remote that comes with the switch.
Keever
Posted on Mar 04, 2008
freetek
  • 5568 Answers
SOURCE: LG 42'' TV has no sound but great picture. How do I get the sound?
You shouldn't need anything plugged into the accessory jacks to get local sound from your set. Go through the main setup menu and check audio settings; they may be set to turn off the internal speakers to send the sound to a home theatre that you apparently don't have. Most sets have that as a selection and supply L-R audio for an external system and mute the internal speakers.
FYI: The three connectors you mention are coded as follows:
Red - right channel audio White - left channel audio Yellow - composite video (contains synchronization signals and video)
These may be input connectors (for external VCR/DVD decks) so check your owner's guide to verify.
Posted on Nov 23, 2008
SOURCE: DVD plays only in black and white
Hey, I had this problem on Thanksgiving Day, trying to watch a dvd on my mother's HDTV. You should be able to hook up most standard dvd players to hdtvs. First you have 3 cords, mine were red, yellow, and white. The connections go as follows:
HDTV:
Audio| Component. The white cord should be in a white audio slot. The yellow cord should be in a yellow component slot (video) and the red cord should be in a red video component slot labeled Pr/Cr. Make sure you match the component numbers. For instance, if you want to use component one, then hook all of the cords into the slots for component one. Most hdtvs have multiple component hookups ( think multiple "channels" for your game system, dvd player, etc) so it's important that the corresponding cords go to the correct component slots.
DVD:
Match the yellow and white cords to the appropriately colored slots. The red cord should go into the slot labeled component video out Cr/Pr. Not the red audio out. This worked for me. Hope this helps.
Posted on Nov 29, 2008
  • 453 Answers
SOURCE: HDMI outlet seems to be bad/ no picture
u need a main signal board replacement
Posted on May 08, 2009
SOURCE: lcd tv hookup
Ive got 3 samsung tv's (lcd, plasma, DLP) and I use HDMI cables on all of them. Its the only way to get the full potential out of the tv. When you use the red/white/yellow RCA cables the signal is anolog aka "old technology". Component cables are good but HDMI is the best. HDMI is a digital signal and thats what all the components that go with the tv should be run on. If your dvd player does not have an HDMI output I would suggest getting one that has that output. As for the cable box most require you to upgrade to digital cable in order to get one with an HDMI output. If you dont want to spend the money on new components and run what you have now the picture will stay mediocre at best. Good luck hope this helped
Posted on May 11, 2009
Moved into new home & it has 3 port Austar connection but no tv aerial connection. How do connect my tv to the Austar wall port without an Austar box
You can't. You either pay Austar for the service, or you put an aerial on your roof and get over air stations and run a cable, or you get another cable or satellite company to hook you up,v or you experiment.
This might help you though
Austar Wall Plate Help Me Understand It
and here
Anyone hooked up their free to air TV through Foxtel wall outlet australia
lots more here
connect my tv to the Austar wall port Google Search
Apr 01, 2018 | Televison & Video
How do I connect tv to Austar box
Hi Anonymous, Connect your austar to your television AV the turn the television channel to AV.............CHEERS..
May 07, 2016 | LG 50pt250 50" Multisystem Plasma Tv For...
Is HDMI4 correct or HDMI1?
how many jacks do you have . I would think it will be 1 or 2
Feb 22, 2016 | Dynex Televison & Video
WHAT DO I PLUG IN THE BACK OF THE TV/DVD COMBO?
You may not have AV ports, AV ports being the ports that you would plug in a yellow video and a white audio cable into, so you may want to take a look at some adapters. Maybe an HDMI to AV adapter?
Tmvel mini RCACVS 3 RCA Composite Video AV to HDMI Converter for TV PC PS3... This one may cost you a bit, but if you don't have AV ports, but do have an HDMI port, this should work.
Dec 09, 2015 | Video Game Consoles & Games
Teac DVD combo - Austar was working fine and now says no signal?
what is "Austar"? Is the drive listed in My Computer"?
Jul 04, 2014 | Computers & Internet
Low volume output signal.
Have you tried a different cable.
Jul 08, 2017 | Sony DVP-NS57P
How to connect austar and a blue ray DVD player to tv
your connection is wrong. Get a RCA wire. Yellow is video and white & red are audio.
Connect the wires to Output from the DVD. Video out and audio out. All that will be connected to the DVD will be output. The DVD is feeding out to the TV, so it is giving.
Now the all connections to the TV will be input. Because the TV is receiving from the DVD. Connect from the DVD to TV respectively.
Turn on the TV and DVD, then press Souce/AV on the TV. Now you should see a display and hear sound from the DVD through the TV.
I hope the above is clear. If not, please let me know.
Good luck.
Jan 04, 2012 | Televison & Video
I have a Samsung PS42D5S TV. Everything will plug
Why don't u plug it in HDMI connections.Take off the presure to the AV -In.To much AV-out that the cause.May could be the cable is bad also.
Sep 06, 2009 | Samsung PS42D5S 42 in. EDTV-Ready Plasma...
Pay tv reception
Austar recently made changes that prevent the use of their smart cards in decoders other than Austar boxes.
Assuming you are using a legit Austar smart card, you will need to use it in the Austar decoder it was supplied with, for it to work now.
Apr 25, 2008 | Humax DRT800
Televison & Video Logo
540 people viewed this question
Computer Repairing
Computer Repairing
