Question about Sharp 13VT-N100 Combo
Adaptor broke off
"Cable in" male adaptor broke off, Is TV worthless now?
  • Sharp Master
  • 458 Answers
It wolud require a new tuner as trying to fix this part back in normally does not last or if the end tag piece is too short to re-solder back on then the part needs replaced. You could try getting a local repair shop to give you an estimate on the cost before condeming the TV.
Posted on Sep 27, 2009
What Auxillary cord model will fit in my alpine cda-9853 stereo model?
Peripheral stereo mini plug cable (3 foot cable, male to male miniplug). around $20
Monster portable music player cable (stereo mini-to-RCA adaptor) around $20
Arista stereo mini-to-RCA adaptor (6 foot cable with mini and dual RCA plugs) around $5
Hope that helps.
Mar 30, 2011 | Alpine CDA-9853 CD Player
When hooked up led 46" aquos it is black and white
You must only connect a yellow to a yellow a green to a green and etc. You must have a yellow cable going into a green hole. You need an adaptor. The adaptor goes into input 2. The other side of the adaptor is a yellow red and white male cable that will fit into your device.
Sep 28, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
On the Magnavox ZV427MG9 A, there is not an antenna in and out connection slot; how does this unit work without that?
My TWC connection is a female onto a male. The Magnavox Model
ZV427MG9 A does not allow the cable connection to screw on to it's terminal. Is there an adaptor with a female connector on one end and a male adaptor on the opposite end.
Nov 11, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Downloading from digital camera
Serial data bus interface 9 pin to a 25 pin are they still available. may be a computer salvage place the adaptor is shaped like a flat flask I rember them from the late 80. serial bus cards use to have them as standard features.
I have the adaptor and saved it for someday I may need it. have not yet .
Jul 29, 2009 | Cameras
Vga cable and power cord for monitor
The vga cable is a DB15, 3 ranks with male connector at each end,
(you can use a vga extention and add a little male to male adaptor at the female end to get finaly 2 males connectors)
And, the power cord is in fact an ac/dc adaptor, the replacement part is: 12b27-0428 (12v 5A 60w 4 pins) ...
just type de number 12b27-0428 on internet and you're on ...
Mar 12, 2009 | ViewSonic VG900b 19" LCD Monitor
I have 3in1 USB 2.0 to IDE & SATA Cable but nothing to show me how to use this kit
SATA 3.5" 2.5" IDE 3 IN 1 TO USB 2.0 CABLE ADAPTOR KIT
1 external connection kit
1 internal connection kit
The internal connect kit consists of 1 red USB connector cable
and 1 internal white male molex connector to SATA female power connector
( 1 yellow wire , 2 black wires , 1 red wire )
the external connect kit
consists of a 3 pin power adaptor (with a tiny plug to save space) feeding a power supply which powers either IDE thru a Molex connector or SATA through a supplied adaptor. Supplied also are data connectors to link the IDE or SATA hard drive with a USB port. Use this adaptor set to retrieve data from a hard drive when it is not mounted in a computer.
Selah :-)
Sep 14, 2008 | Computers & Internet
Needing usb adaptor for espon r340 printer to inable us to go wireless
Here is the usb cable:
USB Type A Male / Type B Male Cable, 2.0 Version, 6 ft
or here
3ft USB 2.0 Printer/Device Cable A Male to B Male
If you additionally need to get morte USB plugs you can use an USB hub:
Micro Innovations Hub
Do not forget to rete the solution appropriately.
Many thanks.
Aug 29, 2008 | Epson Office Equipment & Supplies
I have a phillips 26pf5520d/10 model number, ive connected a dvi cable and hdmi cable to my playstation 3 and tv, but i have no sound, please any ideas. many thanks steph
I'm assuming you mean you have HDMI coming out of the PS3 and going in to the DVI port on the back of the TV, via an adaptor or cable with a different connector on either end.
I have the same TV, you need a separate audio connection between ps3 and tv. HDMI can transmit audio and video but DVI (which is what the TV has) can only do video.
You'll need a 2 x phono female to 3.5mm jack male adaptor cable. like this one to make the audio connection.
you could also try this adaptor but its a bit big and therefore may not fit into the space available.
after getting an adaptor do this (keep your original setup the same)
1. Put the ps3 AV cable into the back of the ps3. 2. then connect the red and white plugs (ignore the yellow) from the ps3 AV into the adaptor (discussed above). 3. then connect the 3.5mm jack (from the adaptor) into the small audio port right next to the DVI port on the back of the TV (I believe its called 'DVI Audio')
I've not tried this and I don't have a ps3, yet, but in theory it should work, as long as the ps3 will send audio to the av output at the same time as to the hdmi output.
if it works, then post a response, i'd like to know for the future.
good luck
Aug 01, 2008 | Televison & Video
RJ45 Cable Adaptor for a NetGear FA410TX
You can get replacement dongles for your card at http://www.buynetgear.com or you can call cb_transparent_l.gifus.gifspace.gifspace.gifarrow.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gif1-888-305-7440cb_transparent_r.gif Monday - Friday 8AM to 10PM Eastern Standard Time.
Jun 05, 2008 | Computers & Internet
Sharp 13VT-N100 Combo Logo
64 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
