Question about Canon PIXMA MP150 All-In-One InkJet Printer
When I push scan it scan it in 5 pages not just one
It makes 5 pages out of one scanned page, I used to use it all the time but something must have changed in the settings
Fixe_You
  • 1800 Answers
SOURCE: scanning documents
try to adjust properly the before scanning option
make it scan the whole page
if this not help tell me so i can help u further
plaese rate this post
Posted on Aug 23, 2008
SOURCE: Incomplete Scanning
No, your paper hasn't slipped. This is an unresolved bug in the MP500 where it does not detect the size of what you are scanning. Luckily, this appears to only be a problem when attempting to scan from the machine itself. If you use the MPNavigator Software and MANUALLY choose the size of the document you are scanning, it should work. This caused me HOURS of frustration before I found the solution. Good luck to you!
Posted on Sep 02, 2008
gremlin11
  • 78 Answers
SOURCE: Canon MX-700 scan software hangs
Markspin.
The issue is not with your printer, rather it is with your pc. You might need to get your computer cleaned up as the normal situation with this is a lack of available memory for the processing required to translate the scan. Check to see what other programs you are running. You can do this by pressing ctl-alt-del and enter your task manager. you will see processes and the numbers will be flicking up and down, it is possable that one of these is causing you an issue. Do not end any of the processes. close this window and open start, run. type "msconfig" and press enter. This will open up a series of windows. the last one is your "start up" any and or all of these can be removed from start up. You will then have to reboot your pc and see how it goes. Don't be too concerned about removing them all, you can simply put them back into your start up folder by re entering this window and reticking it.
Once you have done this, you will find your pc will run a heap faster, however if you are still having issues with scans, it may mean that you need to upgrade the memory in your pc or up grade your pc.
Gremlin11
Posted on Dec 10, 2008
SOURCE: Canon MP500 keeps cropping scanned docs
i was having the exact same problem -- very annoying! just go to the following link and follow the instructions. VERY quick and easy!!!..... http://support-au.canon.com.au/contents/AU/EN/8000507501.html
Posted on Feb 10, 2009
SOURCE: canon mp500 onlt scans part of the page
I was very frustrated by this problem too, but just found a fix at last!!
Instead of focussing on the settings on the scanner itself. Use the MP navigator software to change scan settings and get around this problem. there you can set document size, colour or black and white and even DPI (quality) .
Posted on Mar 29, 2009
Step by step instructions on how to scan documents to my pc
In case you don't have the manual, check this online :
http://files.canon-europe.com/files/soft39530/Manual/Canon%20MP495_499%20EN.pdf
Assuming you have installed the software (from the CD-ROM) successfully, the scanning tools/program (MP Navigator EX) will guide you through the scanning process. See pp. 22-23 and pp 330-338 of the above document.
Mar 05, 2014 | Canon PIXMA MP495 InkJet Printer
Can i get front and back side of pages scanned at a time, if yes then how? how can i scan a book of 50 pages by giving one command?
What scanning software are you using? In Adobe Acrobat Professional 9, you can set up different scan profiles, including duplex scanning. The sheet feeder holds up to 50 pages; you just tell the software to make all pages one pdf.
Dec 02, 2010 | Kodak i1220 Pass-Through Scanner
The fujitsu fi-5110C won't scan all pages just takes the whole thing and just scans the first page. Is there a setting where you can make the scanner to scan each page one at a time? thank you :)
Please follow the information provided below:
If all the pages are being fed through ADF and if image format is TIFF, then you may require another application to view the multi page TIFF image. If you're using ScandAll 21 or ScandAll Pro application for scanning, you have to choose multi page scan option in Batch Scan Setting. Please follow the help contents provided in the scanning application.
Hope the above information is helpful. Please revert if you have any doubt.
Regards,
TechSatya
Jun 29, 2010 | Fujitsu fi-5110C ScanMaker Scanner
How do I scan in more than one page to a file? I would like to scan a 5 page document into one file. Can this be done?
You don't list the make and model of scanner, but if it's the type that comes with an automated document feeder, the software usually supports scanning multiple pages. If not, and you are planning to save it as a PDF, you can use Adobe Acrobat's "Scan to PDF" option--I believe it asks you after every scan if you want to combine that page into the same document.
Apr 01, 2010 | Epson Stylus RX500 All-In-One InkJet...
Can I scan multiple pages to a PDF?
1. Open the HP Solution Center 2. Click Scan Document 3. Document to PDF File 4. Change Settings 5. Save to File Save Options 6. Make sure One file per scanned page is not checked. 7. Click, OK > Scan 8. Ofter first page is scanned, position next page on scanner, then click Add Page. 9. Keep doing step 8 until all pages scanned. 10. Click Finish.
Apr 01, 2010 | HP Photosmart Premium C309A All-In-One...
Can't work out how to use the multiscan? I press scan and it comes up with multiscan and I put the first piece of paper in but don't seem to get asked for any more sheets and it therefore just scans one...
Anita,
Put the pages in the "multiscan" all at once, not just one sheet at a time. The Automatic Document Feeder (ADF) will feed one sheet of your document at a time untill all of the pages are scanned...
Thanks for using FixYa!
Oct 26, 2009 | Canon PIXMA MP780 All-In-One InkJet...
My scanner is scanning in panels, not full pages.
Hi try This
How to reset error 5B00 for Canon MP170 (Ink Tank Full Error):
1 - power off.
2 - hold stop/reset ,hold ON/OFF
3 - release stop/reset, push stop/reset twice, quickly, then release ON/OFF
4 - wait untill LCD display shows "Canon Idle",then push stop/reset four times, quickly
5 - then push power twice, quickly
6 - power off and power on.
All Best: Pineworks
Apr 17, 2009 | Canon PIXMA MP170 All-In-One InkJet...
MFC-9440 CN--Lines in my auto feed scanned/faxed copies
clean the thin strip of glass located under the document feeder with something non abrasive
Feb 06, 2009 | Brother MFC-9440CN Laser Printer
Scanning large documents to PDF takes a long time
Try to use Compact PDF or a lower resolution.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Jan 14, 2009 | Konica Minolta bizhub C250 All-In-One...
Awful noise
Please try the following to resolve your issue:
1. Unplug the USB cable and the AC adapter from the back of the scanner.
2. Toggle the Transportation lock (the plastic switch at the back of the scanner) back and forth 5 times, ensuring that the lock is all the way in the unlock position.
3. Reconnect the USB cable and the AC adapter cable, and then try to scan.
Oct 16, 2007 | Epson Perfection 4180 Photo Flatbed...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
26 people viewed this question
old marine
old marine
