Question about Medion MD 96340 Laptop
NEED A NEW COOLING FAN FOR MEDION MD96340. FAN IS BROKEN AND DOESN'T RUN WHAT FAN DO I ORDER?
    President:
  • 2,600 Answers
You can probably find one at one of the many laptop parts stores at ebay either used or new.
Posted on Sep 27, 2009
Cooling fan inop 1995 mustang gt 5.o
you can check the cooling fan by disconnecting the plug at the motor and run jumper wires from the battery directly to the fan motor it should run if its working if it doesn`t run then the cooling fan motor needs replacing. if it does run then check the plug for a bad connection. other things can cause this like the cooling fan relay, the coolant sensor that sends a signal for the computer to turn on the cooling fan by sending a signal to the relay.
Sep 08, 2014 | Cars & Trucks
Replacing cooler fan on md 96850
http://www.mxm-upgrade.com/Medion_95257.html
Have a look at this guide..its a guide to upgrading the medion, but it will show you step by step instuctions on how to get the the fan then all you have to do is pull it out, give it a real good clean use tweezers if u have to or just buy a new fan and replace it
Feb 06, 2013 | Medion Computers & Internet
The fan on my 2004 Grand Prix quit working 2 weeks ago. Checked fuses and that doesn't seem to be the problem. Any ideas?
if its the cooling fan at the rad then your talking about then if you disconnect the plug on the fan and run jumper wires to it directly from the battery it should run.also check the plug connection to make sure its in good condition and no corrosion.if you jump the fan motor and it doesn`t run tap the motor it should run either way if it doesn`t then the cooling fan motor needs replacing.
Nov 03, 2011 | 2004 Pontiac Grand Prix
4.1 engine. cooling fan wont come on.How can I test the fan motor? Or is itthe sensor?
disconnect the fan and plug it direct to battery using some jumper wires(speaker wires do fine) and if it runs then there is a problem with a coolant sensor or a cooling fan relay. If it doesn't run, then u need a new fan.
Jun 27, 2011 | 1985 Cadillac Fleetwood
Pushclip on cpu fan/filter have broken so i need
u won't get spare clips...you have 2 replace the whole fan....which would n't be so costly..........but you will get satisfy rather than changing the clips
Feb 13, 2010 | Medion (MT8381) (40004683) Motherboard
I need a replacement fan for my medion computer the part# is cI5-9hdpb-m2 / mgt921ur-w25
You can use any generic 80mm fan, many local computer stores usually have a selection available.
Sep 30, 2009 | Magic Protechnic 80mm Sleeve Bearing Case...
Medion model;MD96340 Vista, home premium McAfee is disabled,what can I do?
First you may try checking the settings on your security system and simply enable it again. You can check the website and see if the coverage period for using this service has expired. You can also try to see if your current isp (internet service provider) has a security system. It should come with one and it should be free of charge. Hope this helps.
Jul 08, 2009 | Microsoft Windows Vista Ultimate Edition
Medion MD 96340 Laptop Logo
220 people viewed this question
Top Medion Computers & Internet Experts
John Anderson
John Anderson
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
