Question about Logitech HARMONY 659 Remote Control
Display reads "system error 1. disconnect usb. remove and re-insert batteries. have completed this three times and keep getting same message.
  • brceac2navfl Sep 28, 2009
    All connections on all units in my system have been unplugged and replugged in. Is it possible there is a problem with the remote itself? Remote still shows system error 1.
  • 3,741 Answers
Replace the usb wire.then check.the problem is either the usb wire or the usb port where wire is inserted.first replace the usb wire and confirm whether its wire or port where wire is inserted.if port is faulty then it needs internal soldering.its not expensive.but needs to be opened to get the port out.it gets loose from its connections internally.so the unit does not detect the device.
you can get new parts/wires from
---- www.radioshack.com
thanks.this will help.please do rate the solution.thank you for using fixya.keep updated.
Posted on Sep 27, 2009
  • charlymonty Sep 28, 2009
    yes it can be possible that remote is faulty if all the connections are proper.actually there is a IR sensor in the remote and in the unit to which the remote operated.if any of the IR sensor is faulty then this error can be shown.but most probably the remote gets faulty then the opposite unit.but in some cases the opposite unit to which remote aims gets faulty.so first option is get remote replaced and check out.you can also take the remote to proper electronics shop they actually have device to check if the remote is faulty you can get it replaced but if not then opposite units IR sensor needs to be replaced.
    thanks.keep updated.
0xc18a0107
Try this
An '0x ...' Error Message Displays on the Front Panel When Printing
Issue
The product displays a '0x ... ' error message. The exact text of the error varies by product, but it is usually preceded by the word 'Error .'
Important: If your error message includes the words 'ink system failure ,' check your cartridges before reading this document. If you use any of the following cartridges, refer instead to 'Ink System Failure' Message Displays on the Control Panel (c01458034) (in English) to solve this error:
Solution one: Reset the product
1.
Without turning off the product, disconnect the USB cable from the rear of the product.
NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon
Figure 2: Example USB connection (your product might not look exactly the same as this example)
Description of disconnecting the USB cable.
2.
Remove the cartridges from the product.
3.
Wait for the 'Insert Cartridges ' message to display on the control panel.
4.
Disconnect the power cord from the back of the product.
5.
Wait 60 seconds.
6.
Reconnect the power cord. If the product does not automatically turn on, press the Power button
7.
Reinsert the cartridges, and then close any open doors on the product.
8.
If you receive a prompt to print a calibration page, do so.
9.
Reconnect the USB cable to the rear of the product, and then try printing again.
Solution two: Service the product
If you have completed all the preceding steps and are still experiencing a problem, service the product.
Determine if your product is in warranty or out of warranty. If you need help determining your product's warranty status, go to HP's Warranty Check Tool .
If your product is in warranty , contact HP.
If your product is out of warranty , click here to view additional printer support options starting as low as $20.
Your's Truly,
Christian from HP
Say "Thanks" by clicking the thumb icon in the post that helped you.
Please click "YES" in solution that solves your problem as "was this helpful?"
(Although I am employed by HP, I am speaking for myself and not for HP)
Apr 10, 2011 | HP Photosmart C5180 All-In-One InkJet...
Error 0x 18a0401
Try link below for specific steps in troubleshooting
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00489814&cc=us&lc=en&dlc=en&product=1153494&tmp_track_link=ot_search
Issue The product displays a '0x ... ' error message. The exact text of the error varies by product, but it is usually preceded by the word 'Error .' c01733891.gifImportant: If your error message includes the words 'ink system failure ,' check your cartridges before reading this document. If you use any of the following cartridges, refer instead to 'Ink System Failure' Message Displays on the Control Panel (c01458034) (in English) to solve this error: Solution one: Reset the product
  1. Without turning off the product, disconnect the USB cable from the rear of the product.
    NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (c01424575.gif ). Figure 2: Example USB connection (your product might not look exactly the same as this example)c01651067.gif
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Solution two: Service the product If you have completed all the preceding steps and are still experiencing a problem, service the product. Determine if your product is in warranty or out of warranty. If you need help determining your product's warranty status, go to HP's Warranty Check Tool .
  • If your product is in warranty , contact HP.
  • If your product is out of warranty , click here to view additional printer support options starting as low as $20.
Mar 28, 2011 | HP Photosmart C6180 All-In-One InkJet...
Hp photosmart c6188 PRINTER ERROR 0XC18A0106
  1. Without turning off the product, disconnect the USB cable from the rear of the product. NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (c01424575.gif ). Figure 2: Example USB connection (your product might not look exactly the same as this example)c01651067.gif
  5. Wait 60 seconds.
Solution two: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product
Dec 27, 2010 | HP Photosmart C6180 All-In-One InkJet...
Error cod 0xd0620230
Issue The product displays a '0x ... ' error message. The exact text of the error varies by product, but it is usually preceded by the word 'Error .' Important: If your error message includes the words 'ink system failure ,' check your cartridges before reading this document. If you use any of the following cartridges,Cartridges 564, 364, 178, 862, or 920
    Figure 1: Example 564, 364, 178, 862, or 920 cartridgesSolution one: Reset the product
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
Nov 02, 2010 | HP Officejet 5610 All-In-One InkJet...
My HP Photosmart C6380 All in one printer , won't print. It reads ink system failure. With a code 0xc19a0036 Could you tell me what might be wrong.
  5. Wait 60 seconds.
Solution two: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
Oct 26, 2010 | Computers & Internet
Photosmart 8250 0xc18a0207 carlitosfop
This is a general printer error which occurs when ..........
a> cartridge/s are changed
b> defect in integrated printhead
HP Single-Function and Multi-Function Printers - An '0x ...' Error Message Displays on the Front Panel When Printing (c00489814) Issuegtabtop.gif The product displays a '0x ... ' error message. The exact text of the error varies by product, but it is usually preceded by the word 'Error .'
  • Cartridges 564, 364, 178, 862, or 920
    c02264161.gifIllustration: 564, 364, 178, 862, or 920 cartridges
Solution one: Reset the productgtabtop.gif
    c01651067.gifDescription of disconnecting the USB cable.
  5. Wait 60 seconds.
Solution two: Service the productgtabtop.gif
gtabtop.gif If you have completed all the steps listed above and are still experiencing a problem, service the product.
Jul 16, 2010 | HP Photosmart C7180 All-In-One InkJet...
HP PSC 1610 has message: "Error: 0x880e9b5e1:08..." What happened? I also have message, "No Mech mode."
Hi there
This some times works can only gave it a go.
1. Remove the cartridges from the product.
2. Wait for the 'Insert Cartridges ' message to display on the control panel.
3. Disconnect the power cord from the back of the product.
4. Wait 60 seconds.
5. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
6. Reinsert the cartridges, and then close any open doors on the product.
7. If you receive a prompt to print a calibration page, do so.
8. Reconnect the USB cable to the rear of the product, and then try printing again.
9. If you have completed all the steps listed above and are still experiencing a problem, you need to service the product.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 01, 2010 | Office Equipment & Supplies
Changed all the ink - all new - still makes a rachet sound and shows Error Oxc18a0106 - will not print - what do we do now to have it print
Issue The product displays an '0x ... ' error message. The exact text of these error message varies by product, but it is usually preceded by the word 'Error .' If your error message includes the words 'ink system failure ,' and you use cartridges 564, 364, 178, 862, or 920, please refer to 'Ink System Failure' Message Displays on the Control Panel Common '0x...' error codes
  • 0xc18a0201
  • 0xc18a0206
  • 0xc18a0306
  • 0xc18a030a
  • 0xd0620130
  • 0x887dd03a
  • 0xd05d010d
  • 0xf0af8004
  • 0xc19ac3ff
  • 0xc18a050a
These error codes indicate that the product has an internal error condition. Solution one: Reset the product
  1. Without turning off the product, disconnect the USB cable from the rear of the product. NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (c01424575.gif ). Figure 1: Example USB connection (your product might not look exactly the same as this example)
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
Jan 19, 2010 | HP Photosmart C6180 All-In-One InkJet...
The unit displays the error message "System Error 1" and "1. Disconnect form USB 2. Remove and re-insert batteries". I've done that and can't get error message to go away. The remote seems frozen.
Hey!
I had this same issue and when I contacted Logitech, they told me it was a memory failure and I needed a replacement harmony remote. I was still under warranty so I got a replacement.
I would advise you contact Logitech to see if you are still in your warranty period so you can get a replacement!
-Kennedy
Oct 29, 2009 | Logitech Harmony 676 LCD Remote Control
Installed new computer - keep getting error - HP Photosmart C6150
Try
Reset the product:
  5. Wait 60 seconds.
Jan 10, 2009 | HP Photosmart C6180 All-In-One InkJet...
Logitech  HARMONY 659 Remote Control Logo
49 people viewed this question
Top Logitech Televison & Video Experts
Greg Ulan
syspro
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
