Question about Water Heaters
Rheem water heater 10 yrs old leaking from the top where cold water goes in
  • 252 Answers
You've reached the average death age for water heaters - once they start to leak all you can do is replace them
Posted on Sep 28, 2009
Found water in the pan under bottom of my 60 gal Rheem Marathon model CMR 75245 electric hotter tank. There is no other source of water goes in the pan. Tank is only 4 yrs old. Is the tank leaking?
Is it sitting in the pan or is it elevated over the pan? It is hard to see the leaking if it is sitting flat in the pan. Check all the connections, top and bottom. Wipe them dry and then run your hand over the connections and feel for water. Also check under the heating element covers for leaks. Good luck!
Dec 07, 2016 | Rheem Water Heaters
What causes water in the power cord connector box on the top of my water heater
must have leak on the tank. either above were hot goes out, or cold water goes in.
is there any water accumlted on botto, of water heatter?
Aug 29, 2014 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Rheem 41v850 leaking at bolt on top
just turn off the gas valve for pilot light, turn off cold water to water tank. drain system. when refilling open cold water to fill tank, wait at least a 1/2 hour to 45 minutes then relight water heater. you should be fine!
Mar 29, 2012 | Rheem 50 Gallon FVR NATGAS Water Heater...
I have a Rheem 40 gal. tank that is leaking water front the top where the vent stack is. It is pouring out. Can it be repaired?
A leaking water heater cannot be repaired, assuming it's the tank leaking and not nearby water pipe.
http://waterheatertimer.org/Water-heater-leaking.html
First thing is to protect your property from catastrophic tank failure where tank ruptures and water runs until it is shut off:
Tanks are under pressure when they are hot.
Close cold water shut-off located above tank.
Turn control knob to 'pilot' so pilot is lit but burner will not turn on.
Open hot side on tub for few moments to relieve tank pressure.
Now your property is safe.
You need a new water heater.
In mean time, gas water heater makes 41 gallons hot water per hour.
Shower used 5-9 gallons hot water.
Bath uses 10-15 gallons hot water.
You can turn on water heater for short stretches and limp by until you get a new heater.
Steps for installing gas water heater:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Dec 20, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Moved into brand new house March '06. The Rheem water heater has slow seapage/leakeage around bottom. What kind of warranty does Rheem offer? Under 5 yrs of use.
Please specify the exact source of the leak? If it is the tank drain then that can be resolved by replacing the boiler **** valve. If it is the lower element then it may be tightened. If it is the tank itself then you will be faced with replacing it. Sorry, but I am not familiar with the warranty on the Rheem WH. Warranties vary, usual 5, 6 or 10 year.
Dec 09, 2010 | Rheem Water Heaters
I have a forty gallon electic rheem water heater with a pipe going in the bottom and one in the top which wone is the cold water inlet the bottom????
The one with the pipe going to the bottom is the cold...cold water goes in on the bottom and the hot comes off of the top...hot water is lighter then cold water and rises to the top...
heatman101
Oct 11, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Rheem RHEEM 50 GAL ELEC TALL Water Heater 1.5 yrs old, power at the elements, new elements installed new thermostat installed, still no hot water.
Hello Check the red overtemp reset button at the temp control.Check for contintuity at the elements with a volt meter (pull one wire off first) they should have a reading otherwise they are open & shot.Last is overdrawing (busted pipe) shut off the cold water supply for a 1/2 hour and open it back up and feel the hot water supply pipe.Is it hot?The tank can't keep up with the demand.
Sep 16, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Storage hot water system sounds like its crackling when filling after water use.system is 7 yrs old
check your thermostats and see if they are set to highest setting. Sometimes if theya re they will pop and crack when filling back with cold water.
May 17, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Rheem tankless water heater error code C4 13??
check diaphrapm valve or micro/switch best of luck
Sep 13, 2009 | Rheem RTG-53PVN Indoor Natural Gas...
Water leak at top rheem 21v40s-2
you need to replace the water heater, the tank is cracked and under pressure so it is forcing the water to the nearest opening
Jun 03, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Water Heaters Logo
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
